I’m new in this world
I have HA Supervised installed on a Pi4 in a Docker container.
I want to acces from outside with my phone, so I need to install DuckDns.
Add-on installation is good , logs after starts is okay but after that …
When I add these lines on my configuration.yaml and I reboot , I have the message: connection lost. Reconnecting , and nothing happen.
Maybe your isp uses something called CGNAT, which means you don’t have a public IP. I had to contact my isp and request a public IP and only then my duckdns worked.
Check if your IP address that is in your router settings is the same one you get when you google whatismyip?
I have the same problem in HA supervised installation (Debian) with addon Duckdns ( HA fails to load with http integration).
The internet accesss is based on 4G router with public dynamic IP
The CONFIGURATION/SERVER CONTROLS/CONFIGURATION VALIDATION shows :
validate your configuration if you recently made some changes to your configuration and want to make sure that it is all valid
Configuration invalid
Component error: ssl_key - Integration 'ssl_key' not found.
Component error: ssl_certificate - Integration 'ssl_certificate' not found.
yes i had the same issue, maybe you are lucky and your internet provider has thought about this and you can go on their website and try to find a public ip request form, otherwise you can email them and ask about it. They will ask for your MAC number and a ip numper, both you can find in your router settings.
I had this issue and they got me a public ip in a couple days and after that duckdns worked like a charm.
but when I click on the link …nothing because i’m connect to my wifi router.
if I go to this adress on my phone on LTE it’s ok , maybe the redirection not working ?
