I tried setting it to listen to port 80 butt after reboot, nothing’s changed.
If I run sudo iptables -t nat -A PREROUTING -p tcp -m tcp --dport 80 -j REDIRECT --to-ports 8300, will this break my Google mini since it’s running on port 80?
I wonder if that’s why I can’t get it to work running on port 80.
@swiftvic best guess is you have something else running on 80 or you ran in to permission problems. Connecting to the port or running netstat on the server may help you debug.
I also switched one of my highly used devices from a switch to a light - in case that had an impact.
After a few restarts and deletes I ended with the wrong names in Alexa app (and checking logs Alexa was still attempting to access old Hue ids, that no longer existed). So finally deleted almost every emulated hue device from Alex and renaming the ones I needed to the correct name and I’m back up and running withOUT the annoying voice problem.
@clach04 so I was able to get it to work after running the line: sudo setcap 'cap_net_bind_service=+ep' /usr/bin/python3.5 ,
Thank goodness.
That’s the good news, bad news I’m still getting the “device is not working, please check it’s power supply”. Even though the switch did turn on, it’s just not showing in the Alexa app that it turned on.
I did try the following:
Remove all the lights in my Alexa app, every single one related to emulated hue.
Delete the emulated_hue_ids.json file.
Reboot my pi
Rediscover my emulated hue lights
Configure each one
Everything looked good up until I click on them to “turn ON”.
Light turns on but I get the “Server is unresponsive” text, and I can’t turn off the light from the Alexa app… (not a huge deal since I use HA for everything. However, if I speak to the Alexa app, it will turn off the light with no issues.
I mean I can live with this… for now I guess. Just a bit annoying.
As @swiftvic noted, adding port 80 actually replaces the default of 8300. Emulated hue does not support listening on multiple ports but you can make emulate that with an iptables mapping like @swiftvic’s previous post.
I thought I could live with it too and then got fed up with the annoying voice which is why I ended up purging my old devices from Alexa. Its a day later and the annoying voices have not come back after the cleanup
I have the same issue but I have Echo v2 firmware 645583020. Is there any reliable solution how to solve it? I have read this post and suggestions, but no is working for me. I replaced port 8300 to 80 and something like Xiaomi plugs sometimes works but hue bulb not, so quite unstable.
My v2 dots updated yesterday morning and hue stopped working. I changed
listen_port: 8300 to listen_port: 80, restarted HA then went to the alexa.amazon.com website, not the app, and forgot all devices. Rediscovered devices and everything seems good. Glad this post was here
thanks
(MainThread) [homeassistant.components.emulated_hue] Failed to create HTTP server at port 80: [Errno 13] error while attempting to bind on address ('192.168.31.39', 80): permission denied
For me last night everything stopped working again… and suddenly there was old copies of all my lights (Royal Philips Electronics) deleting these using the Alexa website (“forget” them) and running discovery again added back working copies of each light.
so, i changed the listen port to 80 and restarted. no luck. Went to the alexa website and forgot all the devices. did a rediscover and now i have nothing. This really sucks…
