But they I would have the same issue in reverse? In my mind I need to use the raw data from the clamp to have import as one sensor and export as another. Maybe I’m misunderstanding something here but the energy setup wants a sensor for each.
did you find a solution, same issue overhere
still nothing in the graphs, after many hours.
Could I check some entries in the configuration.yaml?
Where in Australia do that do this? Most smart meters I have seen areare using cellular (3/4/5G) radios in Australia. Would be curious to get some more details on what unit you have
Have you tried to type over the EUR, that worked for me ?
I’ve managed to add total consumption / return / solar template sensors (using this as my starting point and this to set last reset time, thanks for sharing your config).
homeassistant:
customize_glob:
sensor.haenergy_*:
last_reset: "2021-08-05T08:05:00+00:00"
state_class: measurement
template:
# Home Energy sensors for HAEnergy
- sensor:
- name: HAEnergy Consumption
state: "{{ states('sensor.emoncms2_import_all_time') | float | round(2) }}"
unit_of_measurement: "kWh"
device_class: energy
- name: HAEnergy Return to Grid
state: "{{ states('sensor.emoncms2_export_all_time') | float | round(2) }}"
- name: HAEnergy Solar Production
state: "{{ states('sensor.emoncms2_solar_all_time') | float | round(2) }}"
Are they acceptable to use? In HA, they are new sensors and but doesn’t start from 0. I’ve set their last_reset
to when I set it up in HA. But they start from non-zero. I can reset it in emonCMS if it helps, it is arbitrary number from when emonCMS was setup.
It’s been a few hours and the dashboard is still completely empty. Hence the question above.
Is there any way to debug why it remains completely empty?
EDIT: upon checking again, it has sprang to life It’s beautiful!
On the tarif-aspects, too bad here in Flanders/Belgium we will be using a new method as of 2022 called “Capaciteitstarief” (capacity-tarif) based on “Kwartierpiek” meting (quart-hour peak measurement) so not a “fixed” X cents / kWh anymore.
Not so easy to incorporate in the calculation model I think.
No, continues empty…
I use the CircuitSetup 6 Channel board, esphome and cts to currently monitor my energy (see setup video from Travis (https://youtu.be/BOgy6QbfeZk). How do I add this to the new built in energy monitoring?
Really cool new addition. Solaredge works, although adding it was a little confusing since the solaredge lifetime energy is measured in Wh. The dropdown menu says it expects kWh. But it seems the conversion works.
Too bad though that I can’t add any of my smart plugs to the detailed section for individual devices. I have a bunch of Fibaro zwave wall plugs and tasmota flashed gosund plugs, but they do not show up.
You can remove them from the Integrations panel in Configuration
hi I have the same problem, any idea when the official growatt integration will be updated to support this?
i have 3 sonoff switch and energy meter… only 2 were grabbed by this tool, one is missing… but I can see on my dashboard…
energy: in my configuration.yaml did the trick
I wish there were easier ways of not loading things in the default_config: because of what you just encountered. I can’t currently make use of energy: and would like to hide it, but I’m concerned if something new gets added to the default_config: that I would like to use I’ll miss it if I remove default_config: and have everything individually listed.
This is a great initiative !
It’s as if you where reading our minds. Just two weeks ago I started a project to read my smart energy meter using ESPHome in my house. It’s almost finished and the new views and database capabilites will come very handy.
A small solar installation will be next.
Knx sensors have a device_class
set if you configured the appropriate type:
You can add the missing state_class
and last_reset
attributes with customize
for now.
@frenck This is super AWESOME! THANK YOU!
Is it possible to use the YOULESS integration here?
I have a youless LS120 on my energy meter and i have the integration already in Home Assistant since several years. And it would be super awesome to have this data in the Energy service.
Use this for your smart plugs:
Check part “Energy” at the end of the doc.
