Entity Icon color & custom icon color based on state (customise icon_color)
Couple of Questions :
  1. how can I set the icon color to theme accent color or theme Primary color ? (without using hard coded rgb value)
  2. how do I set icon color based on a another entity value?
thanks for the help
May I add to this thread?
I’d like to have my pictures elements card not to show up sooo yellow, esp. for closed windows. I tried thousands of things, but I cannot change the icon color.
Here’s my code? Anyone with an idea, what’s wrong with the code? That would be awesome.
Using 2022.2.5
homeassistant:
  customize_glob:
    binary_sensor.d01_zimmer5_motion_*:
#      icon: mdi:garage
      device_class: motion
      templates:
        icon: >-
          if (state == 'Clear') return 'mdi:garage';
          return 'mdi:account';
        icon_color: >-
          if (state == 'Clear') return 'rgb(0, 0, 255)';
          return 'rgb(255, 0, 0)';
I change the color of the picture elements according to the status in the card.
In the style, just add an ha-card and deifine a new variable.
This is working well for me.
      - type: picture-elements
        style: |
          ha-card {
            --my-switch_sdb1_router: {% if states('switch.sdb1_router') == "on" %} red {% else %} blue {% endif %};
        elements:
          - type: state-icon
            entity: switch.sdb1_router
            icon: mdi:radiator
            style:
              top: 23%
              left: 26%
              '--paper-item-icon-color': var(--my-switch_sdb1_router)
            tap_action: none
Thank you so much! Worked for me in a quite similar way.
Just added 2 lines of code for the styling. Needed to add the …-active-… property as well.
- type: state-icon
    entity: binary_sensor.e03_window_left
    style:
      top: 17.5%
      left: 97.5%
      '--paper-item-icon-color': red
      '--paper-item-icon-active-color': lightgrey
You are right, I forgot to mention the ‘–paper-item-icon-active-color’ as well.
Nice this could solve your problem.
How can I change background color of a card based on time?
type: custom:button-card
icon: mdi:basket
color: rgb(190, 240, 20)
styles:
  card:
    - background-color: |
            if (states["calendar.bringmeister_calendar"].attributes.start_time > ???
            return 'rgb(60, 120, 0)';
that depends on what start_time is. Is it a string or datetime object?
It’s a input_datetime object.
I usually thought bout starting a new/own feature request based on
As I found this topic and even it has a slightly other approach (doing stuff in YAML), I would like to show my idea (doing it in the UI which is more the modern HA way of doing things) here too:
Allow to change entity icon based on entity state (binary sensors)
For binary sensors this should be quite easy:
  • field “icon for state on”: mdi:led-on
  • field “icon for state off”: mdi:led-off
In a next iteration the “state” needs to be user defined, e. g. “15” or “running” etc.
As mentioned in Change entity icon based on state this already is implemented in the backend for sensors with supported device class, e. g. binary sensors like door, window etc.
This feature request is about bringing the config options for this to the UI allowing users do define this on their own.
I agree!
Although mushroom card looks amazing, and Paul was just hired wasn’t he! So prehaps something in the future to enable UI icon colors.
Mushrooms
This is already a feature request
Thanks for linking. All those are based on entities with two states, with
we could use an almost endless list of states and corresponding icons. Why only limit to two states (which of course would fulfill likely 95 % of all requirements as read so far)? Going that extra mile would create a very powerful customization option.
That’s just the example he used, but his proposal implies other domains. This is indicated by the - under his fake device_class field.
Searched a lot and this seems to be the right place to ask. Is there nowadays a straightforward way to have colored entities for values like e.g. (I mean without addtional coding).
Temperature:
Below 0 Celcius blue and above red with gradient from blue to red, the hotter the more red?
I mean the value (state) of the entity in lovelace.
I have now a long list of temp sensors and like to see them in colors.
Doors/windows:
Open red, closed green.
Would love this too.
Not that I’m aware of, which is why I made this: Dynamic badge label (text) colours.
Hi All,
Wondering if someone can help. I have created a “navigation” button that switches to another dashboard where I can control my lights. See the pictures attached.
Screenshot 2023-01-06 105737
Screenshot 2023-01-06 105811
What i am trying to achieve is that the living zone icon should be grey when all of the light entities are off and a different colour when any of the light entities are on.
Can some one help with this?
Easiest solution I think is to make a light group from those lights. It will have a binary state according to your preferences afaik, so you could use that as the state entity for your button.
