I am unable to update to the latest patch.
It complains about Docker, however my system matches the requirement:
root@homeassistant:~# docker --version
Docker version 20.10.18, build b40c2f6
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:305
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 15:24:44 (2 occurrences)
Last logged: 15:35:51
[139874697742560] Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, system is not healthy
[139874707299472] Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, system is not healthy
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 303, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 45, in _wrapper
raise HassioAPIError(data[“message”])
homeassistant.components.hassio.handler.HassioAPIError: ‘HomeAssistantCore.update’ blocked from execution, system is not healthy
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 202, in handle_call_service
await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 1738, in async_call
task.result()
File “/usr/src/homeassistant/homeassistant/core.py”, line 1775, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 207, in handle_service
await service.entity_service_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 678, in entity_service_call
future.result() # pop exception if have
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 931, in async_request_call
await coro
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 715, in _handle_entity_call
await result
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 154, in async_install
await entity.async_install_with_progress(version, backup)
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 413, in async_install_with_progress
await self.async_install(version, backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 305, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, system is not healthy
