Esp32-s3 local voice asistant
I want to create a voice assistant using an ESP32-S3 via ESPHome.
Unfortunately, I’m encountering some issues, no wake word seems to be detected.
I’ve used a Max98357 and an INMP441 connected to an ESP32-S3 (the pins are different from the diagram).
Here’s my ESPHome configuration.
esphome:
  friendly_name: Assistant Chambre
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
# Enable logging
logger:
  level: DEBUG
i2s_audio:
  i2s_lrclk_pin: 17 #WS/LRC
  i2s_bclk_pin: 16 #SCK/BCLK
microphone:
  - platform: i2s_audio
    i2s_din_pin: 13 #SD
    adc_type: external
    bits_per_sample: 32bit
    i2s_audio_id: i2s_in
    pdm: false
speaker:
    dac_type: external
    i2s_dout_pin: 15 #DIN
    mode: mono
micro_wake_word:
  model: hey_jarvis
  on_wake_word_detected:
    then:
      - voice_assistant.start:
voice_assistant:
  microphone: mic
  use_wake_word: false
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  on_client_connected:
    - if:
        condition:
          switch.is_on: use_wake_word
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
However, when I turn on the switch, no keywords are recognized.
Do you have any ideas on how to solve my problem, please?
[19:52:15][D][switch:012]: 'Use wake word' Turning ON.
[19:52:15][D][switch:055]: 'Use wake word': Sending state ON
[19:52:15][D][voice_assistant:414]: State changed from IDLE to START_PIPELINE
[19:52:15][D][voice_assistant:420]: Desired state set to START_MICROPHONE
[19:52:15][D][voice_assistant:118]: microphone not running
[19:52:15][D][voice_assistant:202]: Requesting start...
[19:52:15][D][voice_assistant:414]: State changed from START_PIPELINE to STARTING_PIPELINE
[19:52:15][D][voice_assistant:435]: Client started, streaming microphone
[19:52:15][D][voice_assistant:414]: State changed from STARTING_PIPELINE to START_MICROPHONE
[19:52:15][D][voice_assistant:420]: Desired state set to STREAMING_MICROPHONE
[19:52:15][D][voice_assistant:155]: Starting Microphone
[19:52:15][D][voice_assistant:414]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[19:52:15][D][esp-idf:000]: I (93006) I2S: DMA Malloc info, datalen=blocksize=1024, dma_buf_count=4
[19:52:15][D][voice_assistant:521]: Event Type: 1
[19:52:15][D][voice_assistant:524]: Assist Pipeline running
[19:52:15][D][voice_assistant:414]: State changed from STARTING_MICROPHONE to STREAMING_MICROPHONE
[19:52:15][D][voice_assistant:521]: Event Type: 9
[19:52:15][D][esp-idf:000]: I (93045) wifi:
[19:52:15][D][esp-idf:000]: <ba-add>idx:1 (ifx:0, 3a:07:16:98:56:84), tid:6, ssn:2, winSize:64
[19:52:23][D][esp32.preferences:114]: Saving 1 preferences to flash...
[19:52:23][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[19:55:42][I][ota:117]: Boot seems successful, resetting boot loop counter.
[19:55:42][D][esp32.preferences:114]: Saving 1 preferences to flash...
[19:55:42][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[20:00:57][D][switch:016]: 'Use wake word' Turning OFF.
[20:00:57][D][switch:055]: 'Use wake word': Sending state OFF
[20:00:57][D][voice_assistant:514]: Signaling stop...
[20:00:57][D][voice_assistant:414]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[20:00:57][D][voice_assistant:420]: Desired state set to IDLE
[20:00:57][D][voice_assistant:414]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[20:00:57][D][esp-idf:000]: I (615356) I2S: DMA queue destroyed
[20:00:57][D][voice_assistant:521]: Event Type: 0
[20:00:57][E][voice_assistant:651]: Error: no_wake_word - No wake word detected
[20:00:57][D][voice_assistant:414]: State changed from STOPPING_MICROPHONE to STOP_MICROPHONE
[20:00:57][D][voice_assistant:414]: State changed from STOP_MICROPHONE to IDLE
[20:00:57][D][voice_assistant:521]: Event Type: 2
[20:00:57][D][voice_assistant:611]: Assist Pipeline ended
[20:01:09][D][switch:012]: 'Use wake word' Turning ON.
[20:01:09][D][switch:055]: 'Use wake word': Sending state ON
[20:01:09][D][voice_assistant:414]: State changed from IDLE to START_PIPELINE
[20:01:09][D][voice_assistant:420]: Desired state set to START_MICROPHONE
[20:01:09][D][voice_assistant:118]: microphone not running
[20:01:09][D][voice_assistant:202]: Requesting start...
[20:01:09][D][voice_assistant:414]: State changed from START_PIPELINE to STARTING_PIPELINE
[20:01:09][D][voice_assistant:435]: Client started, streaming microphone
[20:01:09][D][voice_assistant:414]: State changed from STARTING_PIPELINE to START_MICROPHONE
[20:01:09][D][voice_assistant:420]: Desired state set to STREAMING_MICROPHONE
[20:01:09][D][voice_assistant:155]: Starting Microphone
[20:01:09][D][voice_assistant:414]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[20:01:09][D][esp-idf:000]: I (627014) I2S: DMA Malloc info, datalen=blocksize=1024, dma_buf_count=4
[20:01:09][D][voice_assistant:521]: Event Type: 1
[20:01:09][D][voice_assistant:524]: Assist Pipeline running
[20:01:09][D][voice_assistant:414]: State changed from STARTING_MICROPHONE to STREAMING_MICROPHONE
[20:01:09][D][voice_assistant:521]: Event Type: 9
[20:01:23][D][esp32.preferences:114]: Saving 1 preferences to flash...
[20:01:23][D][esp32.preferences:143]: Saving 1 preferences to flash: 1 cached, 0 written, 0 failed
let me tell you, i have exactly the same issue -.-
INMP441 mic with a Lolin D32 board.
esphome:
  friendly_name: presence
  on_boot:
     - priority: -100
       then:
         - wait_until: api.connected
         - delay: 1s
         - if:
             condition:
             then:
esp32:
  board: esp32dev
  framework:
    type: ESP-IDF
    version: recommended
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.175
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: "Presence Fallback Hotspot"
    password: "12345678"
web_server:
  port: 80
captive_portal:
i2s_audio:
  i2s_lrclk_pin: GPIO26
  i2s_bclk_pin: GPIO25
microphone:
    adc_type: external
    i2s_din_pin: GPIO12
    pdm: false
voice_assistant:
  microphone: mic
  auto_gain: 31dBFS
  on_tts_end:
    - homeassistant.service:
        service: media_player.play_media
          media_content_id: !lambda 'return x;'
          media_content_type: audio/mpeg
          entity_id: media_player.windows
switch:
    name: Use wake word
    optimistic: true
    on_turn_on:
      - lambda: id(assist).set_use_wake_word(true);
      - if:
          condition:
            not:
          then:
    on_turn_off:
      - lambda: id(assist).set_use_wake_word(false);
Log:
[00:05:34][I][app:102]: ESPHome version 2024.2.1 compiled on Feb 28 2024, 23:35:27
[00:05:34][C][wifi:577]: WiFi:
[00:05:34][C][wifi:409]:   Local MAC:
[00:05:34][C][wifi:414]:   SSID: [redacted]
[00:05:34][C][wifi:415]:   IP Address: 192.168.1.175
[00:05:34][C][wifi:417]:   BSSID: [redacted]
[00:05:34][C][wifi:418]:   Hostname: 'presence'
[00:05:34][C][wifi:420]:   Signal strength: -53 dB ▂▄▆█
[00:05:34][C][wifi:424]:   Channel: 12
[00:05:34][C][wifi:425]:   Subnet: 255.255.255.0
[00:05:34][C][wifi:426]:   Gateway: 192.168.1.1
[00:05:34][C][wifi:427]:   DNS1: 0.0.0.0
[00:05:34][C][wifi:428]:   DNS2: 0.0.0.0
[00:05:34][C][logger:447]: Logger:
[00:05:34][C][logger:448]:   Level: DEBUG
[00:05:34][C][logger:449]:   Log Baud Rate: 115200
[00:05:34][C][logger:451]:   Hardware UART: UART0
[00:05:34][C][template.switch:068]: Template Switch 'Use wake word'
[00:05:34][C][template.switch:091]:   Restore Mode: restore defaults to ON
[00:05:34][C][template.switch:057]:   Optimistic: YES
[00:05:34][C][captive_portal:088]: Captive Portal:
[00:05:34][C][web_server:168]: Web Server:
[00:05:34][C][web_server:169]:   Address: 192.168.1.175:80
[00:05:34][C][mdns:115]: mDNS:
[00:05:34][C][mdns:116]:   Hostname: presence
[00:05:34][C][ota:096]: Over-The-Air Updates:
[00:05:34][C][ota:097]:   Address: 192.168.1.175:3232
[00:05:34][C][ota:100]:   Using Password.
[00:05:34][C][ota:103]:   OTA version: 2.
[00:05:34][C][api:139]: API Server:
[00:05:34][C][api:140]:   Address: 192.168.1.175:6053
[00:05:34][C][api:142]:   Using noise encryption: YES
[00:05:43][D][switch:016]: 'Use wake word' Turning OFF.
[00:05:43][D][switch:055]: 'Use wake word': Sending state OFF
[00:05:43][D][voice_assistant:514]: Signaling stop...
[00:05:43][D][voice_assistant:414]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[00:05:43][D][voice_assistant:420]: Desired state set to IDLE
[00:05:43][D][voice_assistant:521]: Event Type: 0
[00:05:43][E][voice_assistant:651]: Error: no_wake_word - No wake word detected
[00:05:43][D][voice_assistant:414]: State changed from STOP_MICROPHONE to STOP_MICROPHONE
[00:05:43][D][voice_assistant:414]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[00:05:43][D][esp-idf:000]: I (826200) I2S: DMA queue destroyed
[00:05:43][D][voice_assistant:521]: Event Type: 2
[00:05:43][D][voice_assistant:611]: Assist Pipeline ended
[00:05:43][D][voice_assistant:414]: State changed from STOPPING_MICROPHONE to IDLE
[00:05:47][D][switch:012]: 'Use wake word' Turning ON.
[00:05:47][D][switch:055]: 'Use wake word': Sending state ON
[00:05:47][D][voice_assistant:414]: State changed from IDLE to START_PIPELINE
[00:05:47][D][voice_assistant:420]: Desired state set to START_MICROPHONE
[00:05:47][D][voice_assistant:118]: microphone not running
[00:05:47][D][voice_assistant:202]: Requesting start...
[00:05:47][D][voice_assistant:414]: State changed from START_PIPELINE to STARTING_PIPELINE
[00:05:47][D][voice_assistant:435]: Client started, streaming microphone
[00:05:47][D][voice_assistant:414]: State changed from STARTING_PIPELINE to START_MICROPHONE
[00:05:47][D][voice_assistant:420]: Desired state set to STREAMING_MICROPHONE
[00:05:47][D][voice_assistant:155]: Starting Microphone
[00:05:47][D][voice_assistant:414]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[00:05:47][D][esp-idf:000]: I (829879) I2S: DMA Malloc info, datalen=blocksize=1024, dma_buf_count=4
[00:05:47][D][voice_assistant:521]: Event Type: 1
[00:05:47][D][voice_assistant:524]: Assist Pipeline running
[00:05:47][D][voice_assistant:414]: State changed from STARTING_MICROPHONE to STREAMING_MICROPHONE
[00:05:47][D][voice_assistant:521]: Event Type: 9
checking the Voice Assistant i do see the open Pipeline…
Engine:
entity_id: wake_word.openwakeword
metadata:
  format: wav
  codec: pcm
  bit_rate: 16
  sample_rate: 16000
  channel: 1
timeout: 5
Raw:
stage: wake_word
run:
  pipeline: 01hgy9rhxqkzekrwbh00emyr2f
  language: de
events:
  - type: run-start
      language: de
    timestamp: "2024-02-28T23:05:47.366435+00:00"
  - type: wake_word-start
      metadata:
        format: wav
        codec: pcm
        bit_rate: 16
        sample_rate: 16000
        channel: 1
      timeout: 5
    timestamp: "2024-02-28T23:05:47.366563+00:00"
wake_word:
  metadata:
    format: wav
    codec: pcm
    bit_rate: 16
    sample_rate: 16000
    channel: 1
  timeout: 5
  done: false
If i do a debug test on my smartphone the Hotword detection does work!
So i presume the microphone might be broken, or not? we will never know!
ohhhh i remember i had issues before!
configuration.yaml needs this line:
assist_pipeline:
  debug_recording_dir: /config/stt/assist_pipeline
sadly my file (20 seconds) is 0kb in size and seems broken.
If i do a pipeline test on my smartphone i get a 44kbit file and can hear myself talking.
You need to set the microphone to Left for starters.
microphone:
  platform: i2s_audio
  adc_type: external
  i2s_din_pin: GPIO4
  channel: left
  pdm: false
doesn’t make any difference.
Tried left, right. with L/R grounded or not.
I have 2 of these with the S3 boards running real well right now. Here is my config. You have alot missing to make these boards work for this.:
You can visit this thread fro more help
substitutions:
  voice_assist_idle_phase_id: '1'
  voice_assist_listening_phase_id: '2'
  voice_assist_thinking_phase_id: '3'
  voice_assist_replying_phase_id: '4'
  voice_assist_not_ready_phase_id: '10'
  voice_assist_error_phase_id: '11'
  voice_assist_muted_phase_id: '12'
esphome:
  friendly_name: Master Bedroom Voice assistant
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
      priority: 600
      then:
        - script.execute: control_led
        - delay: 30s
        - if:
            condition:
              lambda: return id(init_in_progress);
            then:
              - lambda: id(init_in_progress) = false;
psram:
  mode:  octal
  speed: 80MHz
esp32:
  variant: esp32s3
  framework:
    type: esp-idf
    components:
      - name:    esphome_board
        source:  github://jesserockz/esphome-esp-adf-board@main
        refresh: 0s
    sdkconfig_options:
      CONFIG_ESP32_S3_BOX_BOARD: "y"
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB:      "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B:  "y"
      CONFIG_AUDIO_BOARD_CUSTOM:           "y"
# Enable logging
logger:
api:
  encryption:
    key: "snip"
ota:
  password: "snip"
wifi:
  manual_ip:
    static_ip: *
    gateway: *
    subnet: *
  ap:
    ssid: "Master-Bedroom-Voice-Assistant"
    password: "snip"
esp_adf:
external_components:
  - source: github://pr#5230
    components:
    - esp_adf
    refresh: 0s
captive_portal:
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO18
    num_leds: 3
    rmt_channel: 0
    chipset: WS2812
    default_transition_length: 0s
    effects:
      - pulse:
          transition_length: 800ms
          update_interval: 800ms
          min_brightness: 0%
          max_brightness: 30%
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO3  ##INMP441-WS
    i2s_bclk_pin: GPIO2  ##INMP441-SCK
  - id: i2s_out
    i2s_lrclk_pin: GPIO6  ##Max98357 - LRC
    i2s_bclk_pin: GPIO20   ###Max98357 - BCLK
    ## l/R pin on ##INMP441 is connected to ground
microphone:
  platform: i2s_audio
  adc_type: external
  i2s_din_pin: GPIO4
  channel: left
  pdm: false
speaker:
  platform: i2s_audio
  dac_type: external
  i2s_audio_id: i2s_out
  i2s_dout_pin: GPIO8  ###Max98357 - DIN
  mode: mono
voice_assistant:
  microphone: external_microphone
  speaker: external_speaker
  use_wake_word: true
  auto_gain: 31dBFS
  volume_multiplier: 2.5
  on_listening:
    - lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
  on_stt_vad_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
  on_tts_stream_start:
    - lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
  on_tts_stream_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
  on_error:
    - if:
        condition:
          lambda: return !id(init_in_progress);
        then:
          - lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
          - delay: 1s
          - if:
              condition:
              then:
              else:
                - lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
    - if:
        condition:
        then:
        else:
    - lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
switch:
    name: Use Wake Word
    optimistic: true
    on_turn_on:
      - if:
          condition:
          then:
            - if:
                condition:
                    not:
                then:
    on_turn_off:
      - if:
          condition:
          then:
globals:
  - id: init_in_progress
    type: bool
    restore_value: no
    initial_value: 'true'
  - id: voice_assistant_phase
    type: int
    restore_value: no
    initial_value: ${voice_assist_not_ready_phase_id}
script:
  - id: control_led
    then:
      - if:
          condition:
          then:
            - if:
                condition:
                    wifi.connected:
                then:
                  - if:
                      condition:
                          api.connected:
                      then:
                        - lambda: |
                            switch(id(voice_assistant_phase)) {
                              case ${voice_assist_listening_phase_id}:
                                id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("none").perform();
                                break;
                              case ${voice_assist_thinking_phase_id}:
                                id(led).turn_on().set_rgb(0, 1, 0).set_effect("slow_pulse").perform();
                                break;
                              case ${voice_assist_replying_phase_id}:
                                id(led).turn_on().set_rgb(0, 0, 1).set_brightness(1.0).set_effect("fast_pulse").perform();
                                break;
                              case ${voice_assist_error_phase_id}:
                                id(led).turn_on().set_rgb(1, 1, 1).set_brightness(.5).set_effect("none").perform();
                                break;
                              case ${voice_assist_muted_phase_id}:
                                id(led).turn_off().perform();
                                break;
                              case ${voice_assist_not_ready_phase_id}:
                                id(led).turn_on().perform();
                                break;
                              default:
                                id(led).turn_on().set_rgb(1, 0, 0).set_brightness(0.2).set_effect("none").perform();
                                break;
                      else:
                        - light.turn_off:
                else:
                  - light.turn_off:
          else:
            - light.turn_on:
                blue: 50%
                red: 50%
                green: 50%
                effect: "fast_pulse"
Unfortunately, it still doesn’t work. I’ve tested the microphone on the left and completed my configuration.
Just like @Haldi, I’d like to be able to test if my mic is working or not.
Same here. I think the S3 support isn’t that far in esphome. Hopefully, it will get better.
@egreh4trj896436sfz
IF you have Arduino IDE installed i found a working script for 2.0!
So i did everything right with soldering and the mic is working!
Normal value is around -30 - 30 and when you yell it goes up to 5000 !
Now i just need to strip down Rich’s yaml from everything we don’t need for a working microphone -.-
@Haldi
Have you found a working configuration to make your microphone function?
Despite copying @Rich37804 configuration, I am unable to achieve something functional.
Have you tried this wiring and code? Since those are from two different places you may need to adjust the GPIO pin assignments slightly (I didn’t check if they line up) but that’s the correct wiring and I have had success with that code. (I also changed the GPIO to suit the particular ESP board I have.
Thank you very much, the wake word microphone works very well, but the voice recognition doesn’t seem to work. However, Whisper works with my phone.
Would you have any ideas?
The component requires an ESP32-S3 with PSRAM to function.micro_wake_word
# for example ESP32-S3-WROOM-1-N16R8
psram:
  mode: octal
  speed: 80MHz
Wait what?
The Atom Echo has PSRAM?
Or do they use some other method get it working as a satellite?
What makes you think that? The spec for INMP441 says to ground L/R for left channel. The WS pin is serial data.
youre right. confusing having lr clock on other device. i realized my mistake shortly after posting.
