Eufy Camera Integration
I think this may be why @nosleepr went towards using MQTT? I recall that when there was a change in the way things worked around March I could see changes in the app (to turn off motion, for example) but I’d still get motion alerts.
Is there a way to automate this camera.turn_on Call Service? I notice I have to do it manually to get my eufy camera to update in my dashboard every time I restart my server. I’m using the HACS integration to setup and use my eufy camera in HA
Sure, i’m surprised that the camera stream is lasting long for you, I thought it timed out after 3 minutes.
But you can create an automation that triggers when HASS reboots and then fire the camera.turn_on script.
- alias: "HASS Restart Camera On"
    platform: homeassistant
    event: start
    - service: camera.turn_on
        entity_id: camera.whatever
If you find a solution to automatically call the camera.turn_on let me know! Right now my eufy cams just show some still image from forever ago every time I restart HA. I have to manually go into Developer Tools > Services and call camera.turn_on for my eufy cams
I’m still learning. Where do I put that code snippet you have above? It doesn’t seem to work when I stick it inside my configurations.yaml and the root level. Does it go in a different file? Does it go underneath something? Thanks!
It’s an automation. So either add the snippet to automation.yaml, or create a version of it using the interface: Configuration > Automations, click on the + then skip the wizard. Use the alias as the name, in the trigger section choose Home Assistant from the drop-down (the event should be set as Start automatically). Skip the conditions (unless you want to add conditions, of course!), then in the Actions use Call service from the drop-down, then camera.turn_on from the next one and finally the camera from the last one.
Hi all, i have a wired eufy doorbell
i installed the nosleepr itegration, got a camera doorbell entity, it shows me a still image of the last event triggered.
Is it okay? ive heard that integration for doorbells are lame
also have a check tab on the image (Preload stream) does this affect anything?
Your integration doesnt affect doorbell cameras?
As I don’t have the doorbell myself, I have been unable to test it. It’s possible that it would work (with minor code changes) but it could require a bit more work to support it.
And by “support” I mean just simple controls that the app can do, no doorbell/motion events (yet)
I’d also like to clarify that the fork I have is for the API only, it’s not a HA integration.
I wish someone could do the integration
Great work tho
I installed the custom repository (https://github.com/nonsleepr/ha-eufy-security) in HACS - but I cannot see an image in lovelace. What configurations are required to see that? there are no instructions in the github wiki. Thanks!
log shows:
$ more home-assistant.log |grep eufy
2020-09-03 12:04:45 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for eufy_security which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
Hello Integration Works for me i have juste the last image when motion or person is detected
but for each camera I have a lot of information. Anyone know the meaning of each code ? Is ther possible to doo something with it ?
exemple Doorbeel:
1011: 1
1013: 1
1015: 0
1045: 0
1056: 0
1101: 86
1131: 1
1138: 21
1142: -46
1145: 0
1148: 0
1149: -1
1150: -1
1177: 255
1204:
1210: 112
1225: 9
1229: 100
1230: 100
1239: 9
1240: 1
1241: 1
1243: 2
1246: 1
1273: 1
1276: 3
1277: 1
1286: 2
1288: 0
1401: 100
1408: 0
1702: 1
1703: 1
1704: 1
1705: 5
1708: 80
1709: 0
1710: {"notification_motion_onoff":1,"notification_ring_onoff":1,"notification_style":2}
1714: 0
1716: 1
1717: 26
1718: 0
2111: 3
99904: 0
100000: 1
access_token: xxxxxxxxxxxxxx (replaced)
model_name: T8210
brand: Eufy Security
attribution: Data provided by Eufy Security
hardware_version: T8210
serial_number: T8210xxxxxxxxxxxxxx (replaced)
software_version: 2.2.1.3
device_upgrade_now: 0
watermark_mode: 1
push_msg_mode: 0
friendly_name: Doorbell
entity_picture: /api/camera_proxy/camera.doorbell?token=xxxxxxxxxxxxxx (replaced)
supported_features: 3
for eufycam 2C :slight_smile:
1011: 1
1013: 1
1015: 0
1045: 1
1056: 0
1101: 58
1131: 1
1138: 22
1142: -55
1145: 1
1146: 1
1148: 0
1149: -1
1150: -1
1177: 255
1204:
1210: 46
1225: 9
1229: 100
1230: 93
1239: 11
1240: 1
1241: 1
1243: 2
1246: 1
1273: 1
1276: 4
1277: 1
1286: 2
1288: 0
1401: 100
1408: 0
1702: 1
1703: 0
1704: 1
1705: 0
1708: 80
1709: 0
1714: 0
1716: 1
1717: 26
1718: 0
2111: 2
99904: 0
model_name: T8113
hardware_version: eufy2_mini
serial_number: T8113xxxxxxxxxxxxxx (replaced)
software_version: 1.6.7
watermark_mode: 1
push_msg_mode: 0
friendly_name: Parking vue Rue
entity_picture: /api/camera_proxy/camera.parking_vue_rue?token=xxxxxxxxxxxxxx (replaced)
I Add a door sensor
Home assistant with this integration dicover it after restart
It’s a Camera.xxxxxxx
Here the information
1131: 1
1148: -1
1149: -1
1150: -1
1177: 255
1225: 8
1239: 12
1506: 1
1507: 0
1508: 14
1550: 1
1551: 1599566313
1552: 0
access_token: xxxxxxxxxxxxx (remplaced)
model_name: T8900
hardware_version: 0.0.1
serial_number: T8900xxxxxxxxxxxxxxxxxx (remplaced)
software_version: 0.1.0gb
friendly_name: Porte d'entrée
entity_picture: /api/camera_proxy/camera.porte_d_entree?token=xxxxxxxxxxxxx (remplaced)
I try to open or close the sensor I don’t see modification !!!
For the sensor it’s seems that the 1550 and 1551 change !!!
1550 : 0 or 1 but it’s’nt change when i open or closed i don’t know
1551 : 1599566313 , 1599567942 perhaps iteration
Edit 10/09/2020
Just add motion detector
1131: 1
1141: -54
1148: -1
1149: -1
1150: -1
1177: 32
1178: 0
1179: 0
1225: 8
1239: 12
1507: 0
1601: 0
1607: 1
1608: 1
1609: 18
1613: 0
access_token: xxxxxx (remplaced)
model_name: T8910
serial_number: T8910xxxxxx (remplaced)
software_version: 2.0.1.1
friendly_name: Salon
entity_picture: /api/camera_proxy/camera.salon?token=xxxxxx (remplaced)
hi @Denizen
does your script work with the motion sensor which is separate from the camera system ? eufy have motion, window sensors for security.
thanks.
hi @bachoo786
As I don’t have the devices myself I can’t be certain, I’ve just moved house myself and will soon be purchasing more eufy products once I’ve got everything unpacked and organised.
Until then I’m afraid I won’t be able to test with other devices. But feel free to pull my repo and test with your own devices to see what data you get from eufy’s servers.
Hi @Denizen
Thanks for your reply.
I am moving house as well and wasn’t sure of getting the ring eco system which I know people have reversed engineered or the eufy eco system which you have given alot of attention to in reverse engineering etc. I dont have the devices yet so will wait until anyone confirms if the motion sensor works with your script etc.
Ps. Reason why I want the eufy eco system is due to the eufy doorbell which I have heard allows rtsp etc.
Hi all,
I followed the instructions from here https://github.com/nonsleepr/ha-eufy-security/blob/e03cf9aea468ba2463f03bd3a1e923e22e48c8d0/README.md.
Unfortunately, I cannot get any picture into the picture card… please find below the logs. Any help would be appreciated. Thanks
2020-09-16 21:11:25 WARNING (MainThread) [homeassistant.config_entries] Config entry for ipp not ready yet. Retrying in 5 seconds.
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6011", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6016", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6062", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1145", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6045", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1045", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1056", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6010", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1230", value "80"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1013", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6044", value "3"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6024", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6053", value "22"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6047", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6012", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6025", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1249", value "299"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1207", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1250", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1251", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6040", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6050", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6026", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1241", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6023", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6046", value "2"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6020", value "3"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6049", value "0"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6041", value "3"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1246", value "2"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6022", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6043", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "6014", value "1"
2020-09-16 21:11:29 WARNING (MainThread) [eufy_security.camera] Unable to process parameter "1240", value "1"
2020-09-16 21:11:30 WARNING (MainThread) [homeassistant.helpers.translation] eufy_security: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.11$
2020-09-16 21:11:33 WARNING (MainThread) [homeassistant.helpers.translation] eufy_security: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.11$
we are all waiting for you buying that doorbel to reverse engeneer
Frankly speaking i tried Amcrest doorbell and guess what? ive had enough of it in 3 days
i packed it back and pulled eufy back on the wall
Amcrest is shitty due to :
  1. it doesnt send you image with oush message tho you know who is there without openning
    2)if you open the push image - guess what - wait 30 sec till its saved and the person is gone
    3)no remote ding dong.
  2. rtsp on amcrest is laggy, i know stream component has a lag but it is 20 sec lag, and on dahua cam its 4sec
If eufy had a normal api it would be a masterpiece, or if someone hacks it normaly
I came across this topic by coincidence.
I have an Eufy Video Doorbell 2K installed here.
Would like to know if there is any integration for it.
I would be particularly interested in detecting button presses and motion detection, I’m not really looking for a video stream in HA.
Sorry about the noob question :sweat_smile:, but I couldn’t find an answer in this topic or the referred integration(s).
