Good point i will check that.
Still no joy. I have logged into the eufy mobile app and for the account im logging into with iobroker there are 4 devices available.
Actually ive added a new instance in iobroker and its now picking the devices up.
Thanks for the help.
Once I get to a good point with the Eufy Security ioBroker integration, I may look into that.
Thanks! I will come back to this
Some progress news:
I have now downloaded an encrypted video stored on the station, over P2P communication, decrypted it and converted it to an HLS stream. I played it back in the browser, including the audio, without any problems.
Now I will dedicate myself at the P2P livestream.
I think that the current P2P implementation of my adapter will handle the livestream without further ado.
As soon as I have tested this successfully I will start to put all the pieces together and publish a first testable version for you.
So stay tuned
Some more progress news:
The P2P livestream also works.
Now it’s time to put all the pieces together and release a first testable version.
All tests were done by me with an eufyCam 2 streaming with h264 video codec and aac audio codec. The 2k cameras should stream with h265. Here I have not yet looked more closely in the source code of the Eufy Security App how this is handled…
PS: Sadly i reached the max number of replies on this topic (3)… So i edited this message…
The P2P livestream has no time limit
Can someone explain to me why I can’t make new posts in this thread now? I already have 16 posts in this thread and now I get this message:
You have reached the reply limit for this topic
We’re sorry, but new users are temporarily limited to 3 replies in the same topic.
Instead of adding another reply, please consider editing your previous replies, or visiting other topics.
Thanks for any help.
Yes jbrukardt I added the eufy integration in HA
Sancho
Thanks! I followed the setup on your blog. Everything seems worked except the streaming. The picture-glance card does show the last motion image, however click it the pop windows doesn’t streaming. When I tried the stream url directly on the browser I got below response:
error: "object has no state"
In HA log there is error:
ERROR (stream_worker) [homeassistant.components.stream.worker] Error opening stream No Stream
How do I troubleshoot this?
Thank you!
Hi Sancho2 - I ended up using MQTT (https://github.com/matijse/eufy-ha-mqtt-bridge/) to get this to work again. I now see a state change with doorbell press and the latest camera image pop up in lovelace. good luck!
2 questions:
stream:
to your config?One thing to confirm, “CAMERA_ID” and “CAMERA_SERIAL_NUMBER” should be same thing, right?
Thanks.
Were you able to see your entities before MQTT?
Sancho
And yes, that’s just a typo/overlook on my part. They’re the same ( eufy-security.0.CAMERA_ID.cameras.CAMERA_ID should be what you get from the iobroker page)
I’m having similar issues. Used your guide (with MaxW’s IObroker home assistant addon).
Getting a few errors in the log:
Logger: homeassistant.components.sensor
Source: helpers/entity_platform.py:215
Integration: Sensor (documentation, issues)
First occurred: 10:35:16 PM (10 occurrences)
Last logged: 10:40:16 PM
- Platform rest not ready yet. Retrying in 30 seconds.
- Platform rest not ready yet. Retrying in 60 seconds.
- Platform rest not ready yet. Retrying in 90 seconds.
- Platform rest not ready yet. Retrying in 120 seconds.
- Platform rest not ready yet. Retrying in 150 seconds.
Logger: homeassistant.components.rest.data
Source: components/rest/data.py:67
Integration: rest (documentation, issues)
- Error fetching data: http://192.168.1.251:8087/getPlainValue/eufy-security.0.T8400P2020190CB2.station.guard_mode failed with [Errno 111] Connect call failed (‘192.168.1.251’, 8087)
- Error fetching data: http://192.168.1.251:8087/getPlainValue/eufy-security.0.T8400P2020190CB2.cameras.T8400P2020190CB2.livestream failed with [Errno 111] Connect call failed (‘192.168.1.251’, 8087)
Log Details (ERROR)
Logger: homeassistant.components.generic.camera
Source: components/generic/camera.py:162
Integration: generic (documentation, issues)
First occurred: 10:35:35 PM (4 occurrences)
Last logged: 10:35:45 PMError getting new camera image from Eufy Doorbell: Cannot connect to host 192.168.1.251:8082 ssl:default [Connect call failed (‘192.168.1.251’, 8082)]
Relevant sections of my configuration.yaml below
Lovelace yaml for the card, same as yours but cleaned up a little to match my config
cards:
- type: picture-glance
camera_image: camera.eufy_doorbell
entities:
- entity: camera.eufy_doorbell
title: Eufy Camera
double_tap_action:
action: call-service
service: rest_command.eufy_start_stream
hold_action:
service: rest_command.eufy_stop_stream
Relevant portions of the config.yaml
- platform: rest
name: Eufy Doorbell Guard Mode
resource: "http://192.168.1.251:8087/getPlainValue/eufy-security.0.T8400P2020190CB2.station.guard_mode"
scan_interval: 10
value_template: >-
{% set v = value | replace('"', "")|int %}
{{ {0: "Away",
1: "Home",
2: "Schedule",
3: "Custom1",
4: "Custom2",
5: "Custom3",
47: "Geofence",
63: "Disarmed"}[v] | default("Unknown state:" + (value|urlencode)) }}
- platform: rest
name: Eufy Doorbell Stream
resource: "http://192.168.1.251:8087/getPlainValue/eufy-security.0.T8400P2020190CB2.cameras.T8400P2020190CB2.livestream"
scan_interval: 10
value_template: >-
{% if (value) is not none and (value) != 'error: datapoint "Livestream URL" not found' %}
{{ value.replace('"', "") }}
{% else %}
No Stream
{% endif %}
rest_command:
eufy_start_stream:
url: "http://192.168.1.251:8087/toggle/eufy-security.0.T8400P2020190CB2.cameras.T8400P2020190CB2.start_stream"
eufy_stop_stream:
url: "http://192.168.1.251:8087/toggle/eufy-security.0.T8400P2020190CB2.cameras.T8400P2020190CB2.stop_stream"
camera:
- platform: local_file
file_path: /<config path>/images/mail_and_packages/mail_today.gif
- platform: generic
still_image_url: http://192.168.1.251:8082/getPlainValue/eufy-security.0.T8400P2020190CB2.jpg
stream_source: "{{ states('sensor.eufy_doorbell_stream') }}"
stream:
Everything looks good in iobroker, i see all my addons, the rest interface is live on 8087
When i paste the rest command
in a browser I get nothing back. Times out
If i issue the same command on 8081 instead of 8087 i get
Cannot GET /getPlainValue/eufy-security.0.T8400P2020190CB2.cameras.T8400P2020190CB2.livestream
I´m trying to setup nonsleepers integration, but it fails after entering the credentials.
Log output:
2021-01-27 11:56:36 ERROR (MainThread) [homeassistant.components.camera] Error while setting up eufy_security platform for camera
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 199, in _async_setup_platform
await asyncio.shield(task)
File "/config/custom_components/eufy_security/camera.py", line 31, in async_setup_entry
[EufySecurityCam(hass, camera) for camera in api.cameras.values()], True
File "/config/custom_components/eufy_security/camera.py", line 31, in <listcomp>
File "/config/custom_components/eufy_security/camera.py", line 46, in __init__
self._ffmpeg_image_frame = ImageFrame(self._ffmpeg.binary, loop=hass.loop)
TypeError: __init__() got an unexpected keyword argument 'loop'
Edit:
Was already fixed, sorry for spam.
Check out this post: Eufy Camera Integration
Might need to open the ports as you may not have the port open.
ok, this did something, thank you!. Im getting rid of some errors now at least
doing the port mapping per that post, and changing all the rest calls in config.yaml to point to 8086 instead of 8087. That got rid of all the errors in the log except one
Error opening stream 404 page not found is the one that remains.
What happens if you try the URL directly in your browser?
unfortunately cant try that one right now as im remotely logged in. If i try it points to an internal ip/port thats not exposed. Will try in about 10 hours though.
This seems to be a complaint by HA about the stream: entry in the configuration.yaml. Thats jsut supposed to be a blank section?
Yeah should just be stream:
as a line all by itself.
