External Storage Help
Hi
I have connected a usb external HDD to my rpi3 which is running hassio. I would like to find the path of it but when ssh hassio host hardware no usb devices show
Thanks in advance
I have the same problem. I connected a PiDrive to my raspi 3 running hashio. I have no way accessing it through ssh or the web interface.
I spent a few hours googling but couldn’t find any clues about how to use external hdd.
Any help appreciated.
I’m still stuck with this issue too
i just found these instructions:
Maye it helps, I’ll try it tonight.
the above link should work if you ssh to the host not into the docker.
ssh to host:
did it work for you
