Hi all
the Facebox component released in 0.70 is for face detection & recognition using FaceBox. To use you just need to run the FaceBox Docker container and configure the component. All processing is done locally on your machine hosting Docker, so there are no hassles associated with cloud services, and no real installation to perform. The speed of recognition will depend on your hardware, but on my Mac recognition takes 4.5 seconds. You can speed this up by disabling recognition, defaulting to detection only.
Cheers
Image-classifier components process the image from a camera at a fixed period given by the scan_interval. This leads to excessive computation if the image on the camera hasn’t changed (for example if you are using a local file camera to display an image captured by a motion triggered system and this doesn’t change often). The default scan_intervalis 10 seconds. You can override this by adding to your config scan_interval: 10000 (setting the interval to 10,000 seconds), and then call the scanservice when you actually want to process a camera image. So in my setup, I use an automation to call scan when a new image is available.
You can also reduce the time for face detection (counting number of faces only) by setting the environment variable -e MB_FACEBOX_DISABLE_RECOGNITION=true when you run Docker. As the variable name states, this disables facial recognition and in my experience detection time is reduced by 50-75%. Note that the teach endpoint is not available when you disable recognition.
Thanks for this. I will try to learn how docker works in order to install it and will try on my machine.
The jupyter notebook in your github is gold!
Just a correction: your Facebox link is pointing to Fakebox. You would like to fix that.
The use case I have in mind is deactivating an alarm system - only allow disarm if person X is home. Haven’t setup myself yet, but its just a case of adding a condition to an automation
Rob, thank you for creating this. Looking for some guidance.
So got the docker running, tested it with some pictures. It recognises. Great!
The integration in HA needs a bit more clarity/gudiance for wider use
I added the component “facebox_face_detect” which in turn needs
camera:
platform: local_file
file_path: /tmp/image.jpg
If the intention is to get it to recognise a snapshot, how to get the shot into file_path: /tmp/image.jpg and how is it subsequently updated.
Thank you.
Thank you Rob. I’ve updated to v0.2 (placed the image_processing folder inside custom_components) but the config checking is showing “Platform not found: image_processing.facebox”
any suggestions?
Hmm make sure there are no cached files in the custom_components/image_processing dir and double check your config. I recall that there was some issue with custom_components and not sure if this is resolved or open.
The other thing to try is just delete your custom_components/image_processing dir and place facebox.py in the image_processing dir within Home-Assistant
Cool, I’m using face recognition with dlib as a backup to disable an alarm and to also give me a TTS overview of my day ahead in the morning when I enter my hallway.
Takes between 4-8seconds to detect my face, any best practices for the camera setup? at the moment I’m using the MJPEG component.
