On 22 Sept. 2021, after updating the Z-Wave JS add-on from 1.37 to 1.39 and then1.40, HA Core to 2021.9.7, and HA OS to 6.4 from what was current on 4 Sept. 2021, I lost all Z-Wave functionality getting the error message βFailed to start the Z-Wave JS add-onβ.
Removing both the Z-Wave JS add-on and integration, then installing the integration with its automatic installation of the add-on gives the same error. Doing many variations/iterations of removing both Z-Wave components and rebooting, HA automatically discovers my Aetec Z-Stick Gen 5 and installs the integration but fails to start the add-on saying βAborted. Failed to start the Z-Wave JS add-onβ, then it automatically removes the integration. Restoring my 4 Sept. 2021 full backup does not fix this.
The Z-Wave log mentions the following driver issue but I donβt know how to provide the βvalueDBβ that apparently is missing:
β2021-09-23T00:32:25.297Z DRIVER Failed to initialize the driver: Cannot read property βvalueDBβ of undefined
Error in driver ZWaveError: Failed to initialize the driver: Cannot read property βvalueDBβ of undefined
at Immediate. (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:793:6) {
code: 5,
context: undefined,
transactionSource: undefinedβ
I simply did a routine update and lost Z-Wave. How do I restore Z-Wave JS functionality short of wiping my SSD and reinstalling everything?
I am running the standard HA OS installation on a NUC. Prior to these updates it was working fine except that after every reboot after an update I had to re-interview each Z-Wave device that I have added since switching from Classic Z-Wave.
Try specifying the path to the usb stick in the settings for the addon by /dev/serial/by-id instead of the ttyACM0 path. The ttyACM0 path can change around depending on moving the zstick to different usb slots, or if you have other devices. Specifying the usb path by /dev/serial/by-id will not change on you.
You can set this path in the addon configuration in the supervisor tab.
This issue is likely not the from the zwavejs addon. It was caused by the Linux kernel update to the os impacting the usb mapping order.
See this github issue for more context
The shifting around of tty mappings for usb devices has been an issue for years across different linux distributions. Specifying the path by id or creating a symlink to your usb will keep the mapping straight by setting a βstaticβ name for your usb device that wonβt change around on you. This article may help.
Having this problem myself. Plug my stick into my unit, then hop onto HA and all the info auto-populates but then when I go to start it it always failsβ¦
Iβve tried different USB ports.
But every time I get:
Aborted
Failed to start the Z-Wave JS add-on.
Any ideas on how to use. Using Nortek HUSBZB-1 stick.
Very new to all this so I donβt know if Iβm missing something obvious or not.
Hereβs what my log shows:
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] config.sh: executing...
[21:20:50] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[21:20:52] INFO: Virtual Machine detected, disabling soft-reset
[cont-init.d] config.sh: exited 0.
[cont-init.d] structure.sh: executing...
[cont-init.d] structure.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[21:20:53] INFO: Successfully send discovery information to Home Assistant.
2022-01-07T05:20:56.444Z DRIVER ββββββββ βββ βββ ββββββ βββ βββ ββββββββ βββ ββββββββ
ββββββββ βββ βββ ββββββββ βββ βββ ββββββββ βββ ββββββββ
βββββ βββ ββ βββ ββββββββ βββ βββ ββββββ ββββββ βββ ββββββββ
βββββ ββββββββββ ββββββββ ββββ ββββ ββββββ ββββββ ββ βββ ββββββββ
ββββββββ ββββββββββ βββ βββ βββββββ ββββββββ ββββββββ ββββββββ
ββββββββ ββββββββ βββ βββ βββββ ββββββββ ββββββ ββββββββ
2022-01-07T05:20:56.452Z DRIVER version 8.9.2
2022-01-07T05:21:05.562Z DRIVER Failed to open the serial port: Error: I/O error setting custom baud rate of 1
15200
Unable to start driver ZWaveError: Failed to open the serial port: Error: I/O error setting custom baud rate of 115200 (ZW0100)
at Driver.openSerialport (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:913:9)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:799:5) {
code: 100,
context: undefined,
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
I canβt say how many times I have had to deal with similar issues. From what I see, the /dev is not pointing to the correct device. I was using a zwave.me device for most of 2021 but it had so many problems. One day I could connect using /ttyxxx/blah/blah then after an OS update it wouldnβt work so had to change to /dev/by-id/blah/blah. Then the next update it would never worked again.
In the end I bought a Zooz controller and so far, 0 problems.
I know this is not what you want to hear but Haas.io has major problems IMO when it comes to Zwave devices and retaining its information.
I sure hope when Matter becomes a thing none of us will have to deal with this crap.
In theory, any device made by any manufacturer that βworks with matterβ, will communicate with other devices by different manufacturers using matter.
Zigbee is on board with it, but zwave is not. Therefore,
I really dont see matter helping zwave issues all that much.
The zwave alliance posted some article about how matter will βsupposedlyβ still make zwave better, but if theyβre not on board with full interoperability across the standard, I donβt see how it would.
The article didnβt make much sense to me, but here it is
Hello, Iβve been using this addon for years now with out a problem, suddenly stopped working a few weeks back. I tried several thing to get it back on line but same error ever time βfailed to start the z-wave js add-onβ. I have now factory reset Aeotec Gen5 and uninstalled every this on HA and still same problem. Any ideas?? Also how can I share my logs?
I had similar issues I am running Aeotec Gen7 dongle. When I had issues I deleted everything and reinstall Z-wave. (Another Looking Glass Zwave JS Failing to connect) I did check the box to use the supervisor add on when I was installing the add on. And it all works now
Switch the integration logs to debug and you will get all of the logs. Please share here so we can troubleshoot, but generally speaking if you are on a gen5 stick, make sure you are upgraded to the latest firmware as there were some problematic ones in between
