I’m getting constant failures when trying to upgrade 103.0 to 1.03.6 on RPi. Ive looked over similar posts and cant see any similarities. RPi has internet access and is otherwise working normally. Any suggestion for a solution or debug? Cheers
> 20-01-14 21:10:06 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.103.6
> 20-01-14 21:10:06 INFO (SyncWorker_11) [hassio.docker.interface] Update image homeassistant/raspberrypi2-homeassistant:0.103.0 to homeassistant/raspberrypi2-homeassistant:0.103.6
> 20-01-14 21:10:06 INFO (SyncWorker_11) [hassio.docker.interface] Pull image homeassistant/raspberrypi2-homeassistant tag 0.103.6.
> 20-01-14 21:10:21 ERROR (SyncWorker_11) [hassio.docker.interface] Can't install homeassistant/raspberrypi2-homeassistant:0.103.6 -> 500 Server Error: Internal Server Error ("Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)").
> 20-01-14 21:10:21 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
