Flash light and then on does not work?
When leaving the house I would like the light in the hallway to flash briefly and then go to on.
After flashing nothing happens.
When I run the action just for flashing, I get an error:
This is the full automation:
  alias: 'Hall: test flash'
  description: ''
  trigger: []
  condition: []
  - service: light.turn_on
      brightness_pct: 100
      flash: short
      entity_id: light.hall
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - service: light.turn_off
    data: {}
  - delay:
      hours: 0
      minutes: 0
      seconds: 2
      milliseconds: 0
      brightness_pct: 50
  mode: single
Try removing { } front he data line.
Hi @Coolie1101, the system adds it again and it doesn’t make a difference.
The automation does not continue after the flashing action…
What happens if you remove the entire data: {} line?
Hi @rcblackwell, same result: automation stops after first action.
I also tried this:
- id: '1652131323463'
  description: ''
  trigger: []
  condition: []
      brightness_pct: 100
      flash: short
      brightness_pct: 50
  mode: single
What happens if you insert a short delay, a second or two, between the two operations?
That’s what I had before but somehow the automation always stops after flashing.
Why do you have the flash line in the data of the first service call?
It looks like the automation is doing a flash effect anyway.
Does the light actually flash?
Why not just use the turn_on turn_off service consecutively?
What is the idea of flashing then turn on?
Also, you don’t need data for the light.turn_off service since there is no additional parameters.
The following works for me.
      brightness_pct: 100
      flash: short
  - delay:
      seconds: 5
    data: {}
  - delay:
      seconds: 2
      brightness_pct: 50
It was put there by the UI
Yes and then the automation stops.
That could be a way to get similar effect but I noticed the flash option for lights so why make it ‘difficult’.
A notification/confirmation and then have light in hall without natural light.
I tried your code but still the same…
It must have something to do with that error in my first post.
Executed: May 10, 2022, 5:43:51 PM
Result:
params:
  domain: light
  service: turn_on
  service_data:
    brightness_pct: 100
    flash: long
    entity_id:
      - light.hall
    entity_id:
      - light.hall
running_script: false
limit: 10
Fair enough, flash never really did anything for me, even if I used it alone, the lights just turn on, maybe someone who knows more about this function can chime in.
The following is what I actually used for flashing some LED’s for new years on the midnight hour, with a repeat until condition, which worked out great, and similarly with multiple delays for the countdown,
    data: {}
      entity_id: light.living_room_led
  - delay:
      milliseconds: 500
    data: {}
That’s where it belongs, as it’s a “Service data attribute
I know that, but your script is a flashing without the flash line, and that is probably the right way to go.
Not all products support flash.
Philips Hue did earlier, but changed it a few months back (Hue flash broken)
Would still like some insight on how the flash service actually works though, I tried it with some LED’s connected via MagicHome and Hyperion, I currently don’t have any other light’s that would support that service.
