That seemed to work for me too, HA initialized and did some discoveries.
But then I ran inDNS errors when installing/downloading custom integrations.
I did a new try with balena with the same result. (hanging balena, running HA, error when installing integrations). Don’t know how or why, but it seemed to be related.
But then I created 1 big partition and that made balena work and solved the DNS problem.
Hello all, typically I am a reader of forums, not a poster, but I have to say I am very happy I found this tread and had to respond.
I ran into the same issue as described (Balena Etcher freezing while running Ubuntu LTS from an USB drive, while flashing HA to a TC520 Intel NUC). Multiple tries, stuck at 14% or 32%, but afterwards (typically a hard shutdown after an hour) HA was running so I thought all was good.
The radio and metrology integration not working was fine for me, but not getting Z-wave to integrate was extremely frustrating. Add-on was running perfect, but the integration could not connect, failed to connect or just ignored any response. I almost gave up completely to move back to Domoticz…
I have now done the same but with the USBimager instead of Balena etcher, flashing was quick and easy (same as above, used Gparted to make 1 ext4 drive of my NUC drive).
And now HA is running 10 times quicker, radio and metro work, Zwave JS UI add-on and integration were truly 1 minute to setup and everything works as it should.
Thanks a lot and I would definitely vouch for adding this option to the installation manual!
The results of our investigation showed that Etcher will make connection to the following systems:
Connection
Included intentionally
Sentry
YES
Mixpanel
YES
Google Analytics (&doubleclick)
NO
Go Squared
NO
Facebook Pixel
NO
Gstatic .com
NO
jquery
NO
Cloudfront
NO
facebook .com/facebook .net
NO
At this point HA should definitely stop suggesting using this spyware - not only does it not respect user privacy (opt-out VS opt-in) but also ads are mandatory with this badware based on a EOL browser (with known 0-day exploits ) and easily being bigger than a HaOS image it should juat write
And to answer your question: No…the original is Better;Without ads (except for their own) and without trackers (not sure, but according @orange-assistant there are issues).
I read a little bit in the balena github repo and actually it looks like “some” fake etcher sites were just distributing old unmodified etcher binaries WITHOUT ANY ADS (but with all the tracking as this is part of etcher for a long period already).
I will avoid etcher for now thanks to all that information (it also has unfixed security issues according to devs on github).
USBimager looks great! They have a table on gitlab and (also) compare it with etcher - looks like it wins in all categories!
What a lifesaver it was to find this thread. I had exactly the same issues two days ago, with my NUC, a fresh Ubundu live and Etcher. I have all the symptoms, I had the Ubuntu freeze, the dns container halting and have been tryting to get it to work for two days now. Thanks! I will try again with high hopes.
Update: 1 day later and success using sudo .\usbimager -a to be able to flash my SSD.
I think it’s time update the HA docs to don’t suggest etcher (with it’s known vulnerabilities and trackers/ads) anymore as it looks like it is the root cause of many HA related problems (not limited to writing/flashing but also DNS manipulations?).
A quick look shows that for raspberry based installs the pi imager (and not etcher) is already suggested so it should be no problem to replace the docs which still promote etcher with usbimager I guess?
This is a balena etcher issue and have nothing to do with the image by itslef. I would recommend using the dd pre-installed tool in the live ubuntu image.
Download haos_generic-x86-64-11-1.img.xz
Unpack the image and you will get instead haos_generic-x86-64-11-1.img unxz haos_generic-x86-64-11-1.img.xz
Flash the image to your device sudo dd of=/dev/{YOUR_DEVICE} if=./haos_generic-x86-64-11-1.img bs=64k oflag=dsync status=progress
Used a live Linux bootable USB (Ubuntu Desktop). Managed to install Balena Etcher easily enough, and download the image, but Balena Etcher failed to even start writing to the SSD.
Moved over to a Linux Mint bootable USB, and installed Balena Etcher, and it installed to 32% before the whole machine locked up. I left it for an hour or so, but it didn’t recover. However, when I rebooted, HA appeared to boot absolutely fine. Spent the next couple of hours playing around, before realising I had networking issues with anything external (logs showed issues with the weather integration, and I couldn’t migrate to MariaDB because the mirrors weren’t accessible). Everything pointed to DNS issues, but even manually setting the DNS server didn’t help. So, whilst I had assumed the image restore completed and maybe the graphics had just locked up, it definitely had not completed.
Tried various other methods, including an external USB caddy, but it wasn’t compatible. Also tried other disk imaging software, but none of them would detect the in-built SSD, they only worked for USB devices, and I didn’t have a suitable enclosure.
In the end, this guide did the trick. Used Ubuntu Desktop live again (as I had before), but installed Balena Etcher a different way, using an older version as per this guide. It threw a number of errors when installing Balena Etcher, but it did install and ran fine. It failed when using the URL, but downloading the image and selecting the file worked perfectly, got to 100% and successfully verified the write.
Thank you very much, I was stuck on Balena at 32% and was trying for hours after testing your step by step tutorial. Works like magic! thank you again!
For those of you, who get stuck like described above (aka myself). I had mixed results with usbimager. One day, I was able to flash but yesterday I wasn’t. Due to a tip within the thread, I decompressed the xz file to the img file and used balena etcher afterwards which worked like a charm.
The same image? Maybe the older images were still within the (size) limit but the newest one outgrown the (only) mentioned limitation in the docs when writing xz compressed images?
