Sounds promising, @keyd!
Shouldn’t USBimager work also on Ununtu?
I’ll give it a try tomorrow evening (out of home until then).
I’ll keep you posted.
This sounds promising indeed ! Thanks @keydi for letting us know !
This also highlight the potential correlation between the freezing at 31% and the DNS failures, as I mentionned above - but I might still be totally wrong lol.
On the webpage he linked, it doesnt say anything other than “linux” so I assume it might work.
Will try the same this evening and keep you posted as well !
Cheers
I have successfully connected to HA via ZeroTier One from the outside of my home network, so network-wise everything seems good so far.
Lol - it legit worked. I had literally 0 hope of resolving that but it actually worked.
Thanks A LOT @keydi !!!
Met.no works, radio works, hacs install is currently going on - I am SO relieved !
@Damos, I confirm it works on Ubuntu LTS - please download USBimager Ubuntu LTS version, then open it with the native software installer from Ubuntu. Ping me if you need any help !
@keydi, thanks again and @all thanks everyone for your shot at trying to help that f*cking issue !
Wow - love the energy here.
So is this the case where there might be compatibility issues with Balena Etcher and HAOS, so that if we use USBImager instead of Balena Etcher, we would be fine?
In my opinion (and experience) it’s a little bit more convoluted than just “Balena Etcher + HAOS” issue. According to my experience, it’s rather “HAOS + Balena Etcher on live Linux booted from SD/USB + flashing SSD on thin-client-like hardware”:
But Etcher on live Linux flashing HAOS to SDD → freezing of OS.
I concur with Keydi’s conclusions. This seems to be this very specific set of inputs that lead to the issue.
In short: I confirm the solution worked!
Here are the steps (from the beginning):
HAOS started right away
Additional steps:
Well, not everything. My add-ons didn’t start at the beginning. I had to reboot the host another time, now everything seems to be fine.
@nukem1232, @keydi, @k8gg, @everyone, thanks a lot for your support, and your dedication!
@nukem1232, apparently I lost the bet, a beer on me!
Whoever might need support: happy to help!
Damos
Great that you got it working but it seems way to complicated for a normal user to install this on a standard x64 system. It seems though that there is no easier way currently.
I don’t think that’s too complicated if you consider Home Assistant as a platform. It wouldn’t be manageable by a „normal user“ anyways.
Even if you’d take a Yellow, configuring HA and maintaining it needs a fair understanding of IT.
I did the installation from a Live USB Ubuntu onto a M.2 SSD Sata Drive in my newly purchased Lenovo M700.
I used Balena Etcher and I never got confirmation it flashed properly but HASS OS did boot up.
After restoring from a Full Backup, I ended up with some weird behavior with HACS. It came down to hassio-dns completely failing with a segmentation fault error.
cont-init: info: /etc/cont-init.d/corefile.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun coredns (no readiness notification)
s6-rc: info: service legacy-services successfully started
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x17 pc=0xc00057]
goroutine 1 [running]:
gopkg.in/DataDog/dd-trace-go.v1/ddtrace/tracer.(*span).setTagError(0x136bf00, 0x7, 0x0, 0x7)
/go/pkg/mod/gopkg.in/!data!dog/[email protected]/ddtrace/tracer/span.go:131 +0x57
[11:16:17] WARNING: Halt DNS plug-in with exit code 2
This results in DNS resolution issues for Components.
I’m currently reinstalling using the step from @Damos with USBimager.
I’ll update if this resolved my issue or not.
Thank you
EDIT:
It’s working flawlessly from the start. So Etcher + Live USB + SSD x86-664 generic Storage does screw up things.
Thank you @Damos, you solve my headaches better than any acetaminophen.
@irogoff, thanks for sharing.
I think, using USBimager as an alternative should be mentioned in the documentation. I will raise an issue there.
Best -
Damos
Hi, Thanks for the walkthrough. This is my first venture into Home Assistant. It is terribly hard. I used the supervised installation, but couldn’t install etcher. When found the dependencies, it hanged at 32%. The image still seemed to work but with all cloud based integrations not working.
I have used RPi’s and have experience with programming and CLI. I tried the most basic installation method and I still can’t get it to work. I use a HP ELITEDESK 800 G3 MINI i5-7500T. I’ve got resilience, but even setting up home assistant seems to be too difficult for me :(.
3d day: I’ve been trying these steps but usbimager doesn’t show my SSD card, just the USB stick I use to boot. I followed all steps up untill step 10. There the SSD doesn’t show up in the dropdown of USBImager. Any ideas?
@JvDUnleashed, I recommend, when you start Ubuntu from the USB stick to start the hard disk utility (or whatever it is called), deleted all partitions from the SSD, and create one big ext4 partition.
Did this work?
Like the docs from usbimager suggested this is the default behavior but it can be as easy as attaching
-a
when executing usbimager to have it shown all devices
With ‘-a’, all devices will be listed, even system disks and large disks. With this you can seriously damage your computer, be careful!
bzt / usbimager · GitLab
And it should be seriously considered for a privacy respecting software like HA to ditch the suggestion of that etcher spyware completely. Not that it has a lot’s of bugs and is build on a EOL browser it probably also violates the GDPR, only works with advertisements and leaks data to various companies around the globe before it can be disabled (opt-in). In all this fancy dd
to write & verify a disk image has grown bigger than HaOS! As today etcher takes more than half a gigabyte with dependencies. That HA suggest a software which does not respect privacy and user choice (opt-in instead of opt-out like HA does it) is something quite sad - many projects stopped already suggesting balena etcher adware / spyware
USBImager shows that if you build a etcher like software without ads, trackers, eol browser and other dependencies it can do the same with a size smaller than half a megabyte (that’s thousand times less than etcher )
Hi, That did work. Also, orange-assistant’s suggestion worked. Etcher did it’s job, USBImager did it faster. Apart from initial setup, HA’s versatility and usablilty amaze me to no end. I’m so happy
Hey, thanks for taking time writing the manual. I’m trying it the same way as you’rem using Ubuntu.
I did everything, but my Usbimager doesn’t seem to see the ssd disk, even launched using sudo.
Any ideas on why that could be?
Yes, just read the last posts in this thread because four posts before yours @JvDUnleashed just asked the exact same question and confirmed it working just in the post before of yours!
And welcome to the community by the way
Tried it, sudo usbimager -a
Still nothing , although I see the SSD in the system with ext4 file system and mounted
