I feel bad for you, but somewhat good for me that it may not be something I did wrong.
This is the log
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:239
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 5:59:54 PM (1 occurrences)
Last logged: 5:59:54 PM
[547085914176] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 239, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2738, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2779, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 975, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1047, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/number/__init__.py", line 116, in async_set_value
await entity.async_set_native_value(native_value)
File "/config/custom_components/tesla_custom/number.py", line 91, in async_set_native_value
await self._car.set_charging_amps(value)
File "/usr/local/lib/python3.12/site-packages/teslajsonpy/car.py", line 897, in set_charging_amps
data = await self._send_command(
File "/usr/local/lib/python3.12/site-packages/teslajsonpy/car.py", line 775, in _send_command
raise ex
File "/usr/local/lib/python3.12/site-packages/teslajsonpy/car.py", line 760, in _send_command
data = await self._controller.api(
File "/usr/local/lib/python3.12/site-packages/teslajsonpy/controller.py", line 1367, in api
response = await self.__post_with_retries(
File "/usr/local/lib/python3.12/site-packages/tenacity/_asyncio.py", line 142, in async_wrapped
return await fn(*args, **kwargs)
File "/usr/local/lib/python3.12/site-packages/tenacity/_asyncio.py", line 58, in __call__
do = await self.iter(retry_state=retry_state)
File "/usr/local/lib/python3.12/site-packages/tenacity/_asyncio.py", line 110, in iter
result = await action(retry_state)
File "/usr/local/lib/python3.12/site-packages/tenacity/_asyncio.py", line 78, in inner
return fn(*args, **kwargs)
File "/usr/local/lib/python3.12/site-packages/tenacity/__init__.py", line 410, in exc_check
raise retry_exc.reraise()
File "/usr/local/lib/python3.12/site-packages/tenacity/__init__.py", line 183, in reraise
raise self.last_attempt.result()
File "/usr/local/lib/python3.12/concurrent/futures/_base.py", line 449, in result
return self.__get_result()
File "/usr/local/lib/python3.12/concurrent/futures/_base.py", line 401, in __get_result
raise self._exception
File "/usr/local/lib/python3.12/site-packages/tenacity/_asyncio.py", line 61, in __call__
result = await fn(*args, **kwargs)
File "/usr/local/lib/python3.12/site-packages/teslajsonpy/controller.py", line 1390, in __post_with_retries
return await self.__connection.post(command, method=method, data=data, url=url)
File "/usr/local/lib/python3.12/site-packages/teslajsonpy/connection.py", line 166, in post
return await self.__open(url, method=method, headers=self.head, data=data)
File "/usr/local/lib/python3.12/site-packages/teslajsonpy/connection.py", line 218, in __open
raise TeslaException(resp.status_code)
teslajsonpy.exceptions.TeslaException
