UPDATE 11 MAY 2026
I have cleansed this post and updated my entity setup instructions to make it a bit easier for everyone.
- It has been a while since I looked at this and I have created these updated steps a really long time ago, but forgot to share.
- Looking at the most recent way of me doing this, with the previous instructions, the entities unique IDs have changed, and if applied as such, it will cause a breaking change. You can deal with it in 2 ways
- Change the entity ids in the script below to match your existing entities
- Go ahead with the new script, migrate long term statistics to the new sensors (instructions are dependant on your DB engine), and delete the old entities from your configuration files.
- You can find the old entity configurations at the bottom of this post if you need to compare side by side
INSTRUCTIONS
IHD
Start by setting up your MQTT details on the IHD. The settings steps can be seen in the video on this article https://medium.com/@joshua.cooper/glow-local-mqtt-f69b776b7af4
The instructions below are set for the default topic glow
Home Assistant Entities
Go to Settings -> Automations & Scenes -> Scripts -> Create script -> Create new script -> ... -> Edit in YAML
Use the following YAML file.
- Replace
ihd_id: REDACTED with your ID. You can either get it from your MQTT broker using something like MQTT Explorer, or direct from the IHD screen (Go to Wifi, note the mac address, remove the colons :)
- Note the topic in the configuration. The new sensors are saved in
homeassistant/sensor/IHD_ID and are based on data from glow/IHD_ID/
alias: Configure Glow IHD
variables:
ihd_id: REDACTED
mode: single
icon: mdi:home-lightning-bolt-outline
sequence:
- alias: "Electricity: Export"
topic: >-
homeassistant/sensor/{{ ihd_id
}}/glow_ihd_smart_meter_electricity_export/config
retain: true
payload: |
"name":"Electricity: Export",
"unique_id":"glow_ihd_smart_meter_electricity_export",
"state_topic":"glow/{{ ihd_id }}/SENSOR/electricitymeter",
"device_class":"energy",
"unit_of_measurement":"kWh",
"state_class":"total_increasing",
"value_template":"{{ "{{ value_json.electricitymeter.energy.export.cumulative }}" }}",
"icon":"mdi:flash",
"expire_after":"60",
"device":{
"identifiers":"{{ ihd_id }}",
"name":"IHD Smart Meter",
"model":"Glow",
"manufacturer":"Hildebrand"}
action: mqtt.publish
- alias: "Electricity: Import"
topic: >-
}}/glow_ihd_smart_meter_electricity_import/config
retain: true
payload: |
"name":"Electricity: Import",
"unique_id":"glow_ihd_smart_meter_electricity_import",
"value_template":"{{ "{% if value_json.electricitymeter.energy.import.cumulative == 0 %}{{ states('sensor.smart_meter_electricity_import') }}{% else %}{{ value_json.electricitymeter.energy.import.cumulative }}{% endif %}" }}",
"icon":"mdi:flash",
"device":{
"model":"Glow",
- alias: "Electricity: Import (Today)"
topic: >-
}}/glow_ihd_smart_meter_electricity_import_today/config
retain: true
payload: |
"name":"Electricity: Import (Today)",
"unique_id":"glow_ihd_smart_meter_electricity_import_today",
"value_template":"{{ "{% if value_json.electricitymeter.energy.import.day == 0 and now() > now().replace(hour=0).replace(minute=1).replace(second=0).replace(microsecond=0) %}{{ states('sensor.smart_meter_electricity_import_today') }}{% else %}{{ value_json.electricitymeter.energy.import.day }}{% endif %}" }}",
"icon":"mdi:flash",
"device":{
"model":"Glow",
- alias: "Electricity: Import (This week)"
topic: >-
}}/glow_ihd_smart_meter_electricity_import_week/config
retain: true
payload: |
"name":"Electricity: Import (This week)",
"unique_id":"glow_ihd_smart_meter_electricity_import_week",
"value_template":"{{ "{{ value_json.electricitymeter.energy.import.week }}" }}",
"icon":"mdi:flash",
"device":{
"model":"Glow",
- alias: "Electricity: Import (This month)"
topic: >-
}}/glow_ihd_smart_meter_electricity_import_month/config
retain: true
payload: |
"name":"Electricity: Import (This month)",
"unique_id":"glow_ihd_smart_meter_electricity_import_month",
"value_template":"{{ "{{ value_json.electricitymeter.energy.import.month }}" }}",
"icon":"mdi:flash",
"device":{
"model":"Glow",
- alias: "Electricity: Import Unit Rate"
topic: >-
}}/glow_ihd_smart_meter_electricity_import_unit_rate/config
retain: true
payload: |
"name":"Electricity: Import Unit Rate",
"unique_id":"glow_ihd_smart_meter_electricity_import_unit_rate",
"device_class":"monetary",
"unit_of_measurement":"GBP/kWh",
"state_class":"total",
"value_template":"{{ "{{ value_json.electricitymeter.energy.import.price.unitrate }}" }}",
"icon":"mdi:cash",
"device":{
"model":"Glow",
- alias: "Electricity: Import Standing Charge"
topic: >-
}}/glow_ihd_smart_meter_electricity_import_standing_charge/config
retain: true
payload: |
"name":"Electricity: Import Standing Charge",
"unique_id":"glow_ihd_smart_meter_electricity_import_standing_charge",
"unit_of_measurement":"GBP",
"value_template":"{{ "{{ value_json.electricitymeter.energy.import.price.standingcharge }}" }}",
"icon":"mdi:cash",
"device":{
"model":"Glow",
- alias: "Electricity: Power"
topic: >-
}}/glow_ihd_smart_meter_electricity_power/config
retain: true
payload: |
"name":"Electricity: Power",
"unique_id":"glow_ihd_smart_meter_electricity_power",
"device_class":"power",
"unit_of_measurement":"kW",
"state_class":"measurement",
"value_template":"{{ "{% if value_json['electricitymeter']['power']['value'] < 0 %}{{ states('sensor.smart_meter_electricity_power') }}{% else %}{{ value_json['electricitymeter']['power']['value'] }}{% endif %}" }}",
"icon":"mdi:flash",
"device":{
"model":"Glow",
- alias: "Gas: Import"
topic: homeassistant/sensor/{{ ihd_id }}/glow_ihd_smart_meter_gas_import/config
retain: true
payload: |
"name":"Gas: Import",
"unique_id":"glow_ihd_smart_meter_gas_import",
"state_topic":"glow/{{ ihd_id }}/SENSOR/gasmeter",
"value_template":"{{ "{% if value_json.gasmeter.energy.import.cumulative == 0 %}{{ states('sensor.smart_meter_gas_import') }}{% else %}{{ value_json.gasmeter.energy.import.cumulative }}{% endif %}" }}",
"icon":"mdi:fire",
"device":{
"model":"Glow",
- alias: "Gas: Import (Today)"
topic: >-
}}/glow_ihd_smart_meter_gas_import_today/config
retain: true
payload: |
"name":"Gas: Import (Today)",
"unique_id":"glow_ihd_smart_meter_gas_import_today",
"value_template":"{{ "{% if value_json.gasmeter.energy.import.day == 0 and now() > now().replace(hour=0).replace(minute=1).replace(second=0).replace(microsecond=0) %}{{ states('sensor.smart_meter_gas_import_today') }}{% else %}{{ value_json.gasmeter.energy.import.day }}{% endif %}" }}",
"icon":"mdi:fire",
"device":{
"model":"Glow",
- alias: "Gas: Import (This week)"
topic: >-
}}/glow_ihd_smart_meter_gas_import_week/config
retain: true
payload: |
"name":"Gas: Import (This week)",
"unique_id":"glow_ihd_smart_meter_gas_import_week",
"value_template":"{{ "{{ value_json.gasmeter.energy.import.week }}" }}",
"icon":"mdi:fire",
"device":{
"model":"Glow",
- alias: "Gas: Import (This month)"
topic: >-
}}/glow_ihd_smart_meter_gas_import_month/config
retain: true
payload: |
"name":"Gas: Import (This month)",
"unique_id":"glow_ihd_smart_meter_gas_import_month",
"value_template":"{{ "{{ value_json.gasmeter.energy.import.month }}" }}",
"icon":"mdi:fire",
"device":{
"model":"Glow",
- alias: "Gas: Import Unit Rate"
topic: >-
}}/glow_ihd_smart_meter_gas_import_unit_rate/config
retain: true
payload: |
"name":"Gas: Import Unit Rate",
"unique_id":"glow_ihd_smart_meter_gas_import_unit_rate",
"value_template":"{{ "{{ value_json.gasmeter.energy.import.price.unitrate }}" }}",
"icon":"mdi:cash",
"device":{
"model":"Glow",
- alias: "Gas: Import Standing Charge"
topic: >-
}}/glow_ihd_smart_meter_gas_import_standing_charge/config
retain: true
payload: |
"name":"Gas: Import Standing Charge",
"unique_id":"glow_ihd_smart_meter_gas_import_standing_charge",
"value_template":"{{ "{{ value_json.gasmeter.energy.import.price.standingcharge }}" }}",
"icon":"mdi:cash",
"device":{
"model":"Glow",
- alias: "Electricity: Cost (Today)"
topic: >-
}}/glow_ihd_smart_meter_electricity_cost/config
retain: true
payload: |
"name":"Electricity: Cost (Today)",
"unique_id":"glow_ihd_smart_meter_electricity_cost_today",
"value_template":"{{ "{{ (states('sensor.glow_ihd_smart_meter_electricity_import_today') | float(0) * states('sensor.glow_ihd_smart_meter_electricity_import_unit_rate') | float(0) + states('sensor.glow_ihd_smart_meter_electricity_import_standing_charge') | float(0)) | round(2) }}" }}",
"icon":"mdi:cash",
"device":{
"model":"Glow",
- alias: "Gas: Cost (Today)"
topic: homeassistant/sensor/{{ ihd_id }}/glow_ihd_smart_meter_gas_cost/config
retain: true
payload: |
"name":"Gas: Cost (Today)",
"unique_id":"glow_ihd_smart_meter_gas_cost_today",
"value_template":"{{ "{{ (states('sensor.glow_ihd_smart_meter_gas_import_today') | float(0) * states('sensor.glow_ihd_smart_meter_gas_import_unit_rate') | float(0) + states('sensor.glow_ihd_smart_meter_gas_import_standing_charge') | float(0)) | round(2) }}" }}",
"icon":"mdi:cash",
"device":{
"model":"Glow",
- alias: Software Version
topic: >-
}}/glow_ihd_smart_meter_software_version/config
retain: true
payload: |
"name":"Software Version",
"unique_id":"glow_ihd_smart_meter_software_version",
"state_topic":"glow/{{ ihd_id }}/STATE",
"value_template":"{{ "{{ value_json.software }}" }}",
"entity_category":"diagnostic",
"device":{
"model":"Glow",
- alias: Hardware Version
topic: >-
}}/glow_ihd_smart_meter_hardware_version/config
retain: true
payload: |
"name":"Hardware Version",
"unique_id":"glow_ihd_smart_meter_hardware_version",
"value_template":"{{ "{{ value_json.hardware }}" }}",
"device":{
"model":"Glow",
- alias: Smets Version
topic: >-
}}/glow_ihd_smart_meter_smets_version/config
retain: true
payload: |
"name":"Smets Version",
"unique_id":"glow_ihd_smart_meter_smets_version",
"value_template":"{{ "{{ value_json.smetsversion }}" }}",
"device":{
"model":"Glow",
- alias: Zigbee Version
topic: >-
}}/glow_ihd_smart_meter_zigbee_version/config
retain: true
payload: |
"name":"Zigbee Version",
"unique_id":"glow_ihd_smart_meter_zigbee_version",
"value_template":"{{ "{{ value_json.zigbee }}" }}",
"device":{
"model":"Glow",
- alias: Status
topic: homeassistant/sensor/{{ ihd_id }}/glow_ihd_smart_meter_status/config
retain: true
payload: |
"name":"Status",
"unique_id":"glow_ihd_smart_meter_status",
"value_template":"{{ "{{ value_json.han.status }}" }}",
"device":{
"model":"Glow",
- alias: WiFi Signal
topic: >-
}}/glow_ihd_smart_meter_wifi_signal/config
retain: true
payload: |
"name":"WiFi Signal",
"unique_id":"glow_ihd_smart_meter_wifi_signal",
"value_template":"{{ "{{ value_json.han.rssi }}" }}",
"enabled_by_default":"false",
"device":{
"model":"Glow",
- alias: Zigbee Signal
topic: >-
}}/glow_ihd_smart_meter_zigbee_signal/config
retain: true
payload: |
"name":"Zigbee Signal",
"unique_id":"glow_ihd_smart_meter_zigbee_signal",
"value_template":"{{ "{{ value_json.han.lqi }}" }}",
"device":{
"model":"Glow",
description: ""
Save the script, then run it (... -> Run)
- This will bring in all the relevant entities.
- The entities are then grouped as 1 device.
- You can keep the script for any future thinkering. If you change anything, you just need to Run the script again
Home Assistant Energy Dashboard
The entities we need to use are as follow:
NOTE: Some meters are reporting figures in MW, so the there will be a difference of a factor of 1000. If you are affected by that, here is a workaround for the cost entities:
"value_template":"{{ "{{ (states('sensor.glow_ihd_smart_meter_electricity_import_today') | float(0) * 1000 * states('sensor.glow_ihd_smart_meter_electricity_import_unit_rate') | float(0) + states('sensor.glow_ihd_smart_meter_electricity_import_standing_charge') | float(0)) | round(2) }}" }}",
Bonus Content
Did you know you can replicate the Energy dashboard in Lovelace, and then include your own other entities?
Old Configuration files
Ignore if you are a new user, only useful to existing users that need to possibly avoid a breaking change and need this for manually changing entity unique_ids.
mqtt:
- name: "Smart Meter Electricity: Export"
unique_id: "smart_meter_electricity_export"
state_topic: "glow/REDACTED/SENSOR/electricitymeter"
device_class: "energy"
unit_of_measurement: "kWh"
state_class: "total_increasing"
value_template: "{{ value_json['electricitymeter']['energy']['export']['cumulative'] }}"
icon: "mdi:flash"
- name: "Smart Meter Electricity: Import"
unique_id: "smart_meter_electricity_import"
value_template: >
{% if value_json['electricitymeter']['energy']['import']['cumulative'] == 0 %}
{% else %}
{{ value_json['electricitymeter']['energy']['import']['cumulative'] }}
{% endif %}
icon: "mdi:flash"
- name: "Smart Meter Electricity: Import (Today)"
unique_id: "smart_meter_electricity_import_today"
state_class: "measurement"
value_template: >
{% if value_json['electricitymeter']['energy']['import']['day'] == 0
{% else %}
{{ value_json['electricitymeter']['energy']['import']['day'] }}
{% endif %}
icon: "mdi:flash"
- name: "Smart Meter Electricity: Import (This week)"
unique_id: "smart_meter_electricity_import_week"
value_template: "{{ value_json['electricitymeter']['energy']['import']['week'] }}"
icon: "mdi:flash"
- name: "Smart Meter Electricity: Import (This month)"
unique_id: "smart_meter_electricity_import_month"
value_template: "{{ value_json['electricitymeter']['energy']['import']['month'] }}"
icon: "mdi:flash"
- name: "Smart Meter Electricity: Import Unit Rate"
unique_id: "smart_meter_electricity_import_unit_rate"
device_class: "monetary"
unit_of_measurement: "GBP/kWh"
value_template: "{{ value_json['electricitymeter']['energy']['import']['price']['unitrate'] }}"
icon: "mdi:cash"
- name: "Smart Meter Electricity: Import Standing Charge"
unique_id: "smart_meter_electricity_import_standing_charge"
unit_of_measurement: "GBP"
value_template: "{{ value_json['electricitymeter']['energy']['import']['price']['standingcharge'] }}"
icon: "mdi:cash"
- name: "Smart Meter Electricity: Power"
unique_id: "smart_meter_electricity_power"
device_class: "power"
unit_of_measurement: "kW"
value_template: >
{% else %}
{% endif %}
icon: "mdi:flash"
- name: "Smart Meter Gas: Import"
unique_id: "smart_meter_gas_import"
state_topic: "glow/REDACTED/SENSOR/gasmeter"
value_template: >
{% if value_json['gasmeter']['energy']['import']['cumulative'] == 0 %}
{% else %}
{{ value_json['gasmeter']['energy']['import']['cumulative'] }}
{% endif %}
icon: "mdi:fire"
- name: "Smart Meter Gas: Import (Today)"
unique_id: "smart_meter_gas_import_today"
value_template: >
{% if value_json['gasmeter']['energy']['import']['day'] == 0
{% else %}
{{ value_json['gasmeter']['energy']['import']['day'] }}
{% endif %}
icon: "mdi:fire"
- name: "Smart Meter Gas: Import (This week)"
unique_id: "smart_meter_gas_import_week"
value_template: "{{ value_json['gasmeter']['energy']['import']['week'] }}"
icon: "mdi:fire"
- name: "Smart Meter Gas: Import (This month)"
unique_id: "smart_meter_gas_import_month"
value_template: "{{ value_json['gasmeter']['energy']['import']['month'] }}"
icon: "mdi:fire"
- name: "Smart Meter Gas: Import Unit Rate"
unique_id: "smart_meter_gas_import_unit_rate"
value_template: "{{ value_json['gasmeter']['energy']['import']['price']['unitrate'] }}"
icon: "mdi:cash"
- name: "Smart Meter Gas: Import Standing Charge"
unique_id: "smart_meter_gas_import_standing_charge"
value_template: "{{ value_json['gasmeter']['energy']['import']['price']['standingcharge'] }}"
icon: "mdi:cash"
template:
# Energy Costs
- name: "Smart Meter Electricity: Cost (Today)"
unique_id: smart_meter_electricity_cost_today
device_class: monetary
icon: mdi:cash
state: "{{ (
states('sensor.smart_meter_electricity_import_today') | float
* states('sensor.smart_meter_electricity_import_unit_rate') | float
+ states('sensor.smart_meter_electricity_import_standing_charge') | float
) | round(2) }}"
- name: "Smart Meter Gas: Cost (Today)"
unique_id: smart_meter_gas_cost_today
icon: mdi:cash
state: "{{ (
states('sensor.smart_meter_gas_import_today') | float
* states('sensor.smart_meter_gas_import_unit_rate') | float
+ states('sensor.smart_meter_gas_import_standing_charge') | float
) | round(2) }}"
