Hey Hey,
i just run into a problem which i cant seem to fix.
Following has happened:
Yesterday evening i tried to setup TTS in HA which was then working. But after that, i noticed google Assistant isnt working anymore / It was working just fine for the last 1,5 years. So if i try to switch my light on - the google assistant tells me “Sorry the device is currently not available”. So i decided to setup the google cloud project from Scratch and unlinked the old Google Cloud Project from my Assistant/Home App and set it up completly fresh. In my Home App everything is poping up and i can controll it manually from the Android Phones App. But when i try to do it with Google Assistant on my phone or my 2 Google Nest Minis - i get the “Sorry the device is currently not available”.
When i tell the assistant to resync the devices it syncs the devices flawless and doesnt spit out a error.
How can i debug the process? The Home Assistant Log under → system → Log is empty
Greetings and thanks for any answer given! Me
Edit: I’m using self hosted version of HA as VM without the cloud option it offers
Are you using nabucasa also? I had an issue that if nabucasa was enabled together with manual google assistant, only the cloud version was working, and not the manual anymore
Yes I did. Like mentioned in the title the Google home app is working fine - i can turn off and on all devices in the Google home app and the devices are displayed fine - the only thing that is not working, is controlling the devices with the Google Assistant.
I discovered something strange:
Every device is controllable via an iPhone and the Google Assistant iOS App.
On my 2 x Nest devices and my Android Phone im getting “Sorry device XYZ isnt available right now.” as a response from the assistant.
Like mentioned - the Android Home App is working fine.
Im at the end with my knowledge…
I have been pulling my hair out trying to figure this out. Same thing. I can control everything from the google home app but 2 google minis and google assistant fail. I thought it had something to do with me trying to configure local fulfillment earlier in the day. Something else I noticed, the google home app doesn’t update state changes. If I turn a light off, it actually goes off but the state in the google home app is still on. If I turn it off again through google home it actually corrects the state. Whatever happened, happened sometime on feb 5 th.
God bless im not alone.
Yeah, on my end it changed at around the 4th of february.
I have some older backups of my HomeAssistant, every 3rd day i backup to backblaze, just out of intrest i reverted back to an one old copy of the assistant and its NOT working!
The time of the backup made - i guarantee that it was working! But i cant seem to find any informations on how to debug the stacktrace of the google assistant… i still dont know how to fix it…
Yes i did unlink and relink the Project in the home assistant app - i even created a whole new Project and started from Scratch. What do you mean with Google Account Page? Where can i find this?
I think the odd thing here, at least from what I can tell, is from those that it is broken for, there were literally no changes. I have had google assistant configured and working for 3-4 years and then bam, the voice assistant stuff stopped working. The home app still works perfectly fine. Sync’ing works perfect. Everything but voice assistants. Even if I try to use voice in the google home app….broken, but clicking on devices in the home app works just fine except for the state updating. I can even go into the google logs and see states updating. I have checked everything locally, opnsense, nginx (swag) container, APs, nothing indicates any issues. Google logs don’t even show an attempt when I attempt a voice command. And the test portion of the google actions fails.
