Google Assistant - KNX Temperature sensor not working
Hello.
I’m using Google Assistant with the NabuCasa integration.
I got the following KNX temperature sensor (KNX - Home Assistant) setup:
- name: "Some Temperature Sensor"
  state_address: "3/2/20"
  type: temperature
  state_class: measurement
The sensor is showing up correctly in home assistant but in Google Home it is showing up but doesn’t display anything. (so GA doesn’t detect the correct device class I guess)
Is there anything I can do to fix this issue?
Thank you very much.
Denis
Hi @denisha.
Having the same issue with different temp sensors. We’re discussing it, here:
