I just tried to use my Google Home to control some devices and it said Home Assistant was not available. Now when I try to test my device I seem to get the “GoogleFulfillment ‘actions.fulfillment.devices’ is not supported”. I have tried to download the gactions but when I do that I get the
ERROR: Couldn’t fetch versions
ERROR: The caller does not have permission
2019/02/23 08:59:38 Server did not return HTTP 200
Is there something else that can be done to get this working again?
Yep, just tried this … something definitely changed. I had about 40 devices exposed to Google Assistant via HA, now I can only get 18 after unlink/link
I have 27 exposed and just asked Google to Sync my devices and it was successful. I am not seeing any difficulties with this component at all. Incidentally, 24/2 at 11:52 AM is when it’s supposed to be 30 days so we shall see… I assume this is US westcoast time… It is actually local time.
Slightly different scenario … I had all my devices exposed and syncing fine. Out of curiosity, I tried unlinking/re-linking in the GH app, and observed the same error as in this thread referred by @pergola.fabio I decided to clean up stale projects and created a new project. After creating a new project with no changes other the credentials required for the integration, I still saw the same error. So I started commenting out some device as mentioned until it would successfully link. I do have some Chromecasts (3) also that are liked directly to GH - so effectively 21 devices, but only 18 via HA.
my 27 are all via HA… I have another 11 or so exposed directly 38 all together. This includes scenes which don’t show up as ‘devices’ I have 11 HA devices, 4 through MiHome, 1 TelstraTV, 1 WeMo, 5 ‘assistant’ - 3xGoogle Homes, 2xChromecasts
Total devices listed in rooms 38. 16 scenes from HA.
I made the mistake of clicking on Actions under Build and then clicked on Test… that had the effect of killing my test and I could not restart the test.
So I followed the gactions instructions. When I try and list it says No versions of your app for the Assistant exist. but I was able to issue the
gactions get --project name-of-project --version draft > action.json
Got a message to visit a URL which I did and auth’ed my Google Account.
Then did the edit and was able to push my action which restarted my test.
I did NOT have to unlink and relink my app. Issuing the command to ‘Hey Google, Sync my devices’ gave no errors and I still have the exact same devices as before when I open the Google Assistant on my phone.
I tried all of that as well and it seemed to work thank goodness.
EDIT: Well it looks like I spoke too soon it now shows up in my Google home account as the test and I try to link however after I put the login information in I get an error
Yes , definitely something changed with amount of exposed devices, only @DavidFW1960 is successful …
I also tried it with cloud version, same issue… @DavidFW1960 can you show us your config?
Maybe it has something to do with room or alias or something, or maybe naming convention, I have no idea
