Hello - Google Maps location sharing working correctly, but has recently stopped. This might have coincided with updating to 80, but I’m unsure.
The log entry follows. Any advice appreciated.
2018-10-25 15:51:30 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform google_maps
File "/usr/local/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 109, in _populate
self._charging = data[13][0]
TypeError: 'NoneType' object is not subscriptable
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 184, in async_setup_platform
disc_info)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/google_maps.py", line 46, in setup_scanner
scanner = GoogleMapsScanner(hass, config, see)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/google_maps.py", line 66, in __init__
self._update_info()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/google_maps.py", line 78, in _update_info
for person in self.service.get_all_people():
File "/usr/local/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 459, in get_all_people
people = self.get_shared_people() + [self.get_authenticated_person()]
File "/usr/local/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 451, in get_authenticated_person
None,
File "/usr/local/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 95, in __init__
self._populate(data)
File "/usr/local/lib/python3.6/site-packages/locationsharinglib/locationsharinglib.py", line 113, in _populate
raise InvalidData
locationsharinglib.locationsharinglibexceptions.InvalidData
