Hi there!
i’m running Hassio 11.5 on PC x64 installed using generic x86_x64 method.
On the GUI i done some Core and Supervisor Update with success but i have never succeded to update “Home Assistant Operating System”…i’m still at 11.5 release and i tried to update to every update released till today without success.
The update process from the GUI does not return any error but at the reboot i’m always at 11.5.
Just tried to update by the CLI with ha os update --log-level debug command and the update process seems to had success but at the reboot i’m always at 11.5.
I’ve found a new log file that’s not shown in the Gui
I installed the Samba client and browsed to this directory in Windows.
\\homeassistant.local\config
I found this log file: home-assistant.log.1
Apparently HA resets the supervisor log every time you reboot, so the error messages from an update sometime don’t show up in the regular log, and you need to go to this log file instead
I have these three error messages which are not visible using the GUI to browse the log files
2024-03-15 16:24:13.773 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration zha_toolkit which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-15 16:24:13.777 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-03-15 16:24:13.781 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
It looks like I’m using a custom integration that’s preventing the upgrade.
These three are not “error messages”, they are as they also state warnings. Every custom integration will generate these.
The way that they say WARNING in all caps was probably my first clue.
I have these messages, and other posts have said that they haven’t been able to update because of these integrations. So I thought that you might want to know.
The messages tell you the names of the custom integrations as not everyone is aware of what may or may not count, or they may simply have forgotten what was custom and what wasn’t.
The “other users” logs differs significant from yours , but you could ofcause just try to disable these integrations ( which is also kind of what these “Warnings” says, And it is as Mentioned Warnings !, if you don’t have any Errors which could lead to these Integrations, i suggest you just ignore these Warnings, otherwise you’ll just get headache every time you look at your startup/restart log.
there is one significant hint in your( sorry, frankiep’s ) “debug log” …
So you could try to run the same “debug command” again, as you should get another result (Error !, doo to the fact it just reported “OK, Command completed successfully.”
So my first thought is , Log Out Of HA , flush everything in your browser cache(cookies included, or check from another device, you usually dont connect to HA from )
Right you are not getting that message, because you probably didn’t run this debug, command, in the HA CLI ( the console of your HA-Device ).
Beside you looked in (talking about) the CORE-Logfile ( And not the Supervisor-log), Nor The OS-logfile
I’m not getting anything that looks like an error, or even a warning, other than what I’ve already mentioned. Which is why I’m coming here to look for other people with similar problems.
Your problem is, You are not coming here to “look” for other people with similar problems, you come here to SPAM the community, by creating:
51 Topics in less than 5 month
0 zero NONE You marked with a Solution !
every Topic made, you seems to just abandon
With your read-time VS Topics & Post created, it seems like you haven’t found the Search-Box either
Compared to the Topics/Post Created and +1.6K “read ?” (doubtful), however you didn’t find any help or responds you “liked”
You are wasting peoples time, People who try to help you
You clearly totally failed to understand what this Forum is about, and missed to READ, the Community Rules/Advices
Now. 23 = 20 Topics created, January 16 Topics created, Please Do the Match
If 100.000 members should create i.e 20 Topics A Day ! , it would be 2 million 2.000.000 Topics. ( In 1 Day ! )
51 Topics in Less than 5 month, would be +5 Millions Topics ! … Abandoned and Not Marked with a Solution
Since you seem to be here only to grief other people’s posts, I’m simply going to request that you do not attempt to interact with me in any way that does does not involve trying to sincerely resolve the problems that I’m having.
This is a forum for providing technical support, not for ranting at strangers.
