I’m new to HA and new to Z-Wave. I installed my first Z-Wave devices – two Aeotex Recessed Door Sensor 7’s. I’m using the Z-Wave integration and a Zooz Z-Wave Plus S2 USB Stick ZST10.
After a significant amount of effort trying to pair them, I got them to show up under the Z-Wave integration configuration panel. However, they show up as Aeotec Limited Unknown: type=0102, id=00bb rather than being recognized as a door sensor.
I believe what I’m then seeing is a result of them not being recognized – under the Entities for each one, there’s a whole *slew of entities.
I think I figured out the three I actually care about for each sensor (boolean state, alarm type for open/close events, and battery level???), and I manually renamed those entities, as well as the nodes themselves:
I’ve checked “Exclude this entity from Home Assistant” for each of the other miscellaneous entities, but my Overview still looks like this:
Is this really the sort of laundry list I should expect when I add a Z-Wave device, or is this the result of the integration not having information to interpret this into a more reasonable number of entities with states like “open/close”, etc.?
I have four First Alert Z-Wave smoke detectors sitting here and a third door sensor, but I don’t want to install them yet until I know if I’m missing a step somewhere along the way to make these show up with a bit more syntactic sugar in the HA UI.
