When I tried to install the HACS integration into HAOS, It kept failing. While I’m able to connect to GitHub and confirm the needed port is open using PING, NC, and NMAP, the install process is failing with a UI message, ‘Could not authenticate with GitHub’, and a log message, ‘Cannot connect to host github.com:443 ssl:default [Try again]’.
Does this make sense to anyone? I don’t come from a Linux background, so I still finding my way under the hood.
I posted this problem at the developer’s GitHub page. The detailed writeup and screen shots are at: https://github.com/hacs/integration/issues/3252. The developer suggested the problem is a communication issue, not a HACS issue. I’m inclined to trust his suggestion as I’m not finding other posts about this problem.
Any suggestions or ideas?
