I think in that’s the version 2.4 sensor in the video - at least that’s what the PDF manual Ben shows on his screen says.
Sebastian
Sebastian
Yeah, if you notice I updated my post a few minutes before you replied to reflect that for clarification.
I’d still send him a PM and ask though. He may be in the same boat, then again he may have the answer.
I only use Aeon multisensors because of this so I don’t have the experience to help beyond what I’ve already provided. I even checked issues on Github and deep searched the forums but couldn’t find anything. Sorry.
Hello! Saw I was tagged here, had a minute, and just wanted to chime in. My Fibaro multisensor works as expected with HA without doing anything after pairing it.
Just confirming what was already said here, yes, the burglar alarm and motion report on the same binary sensor. If my memory serves me right, there is setting in the OpenZWave config to change the burglar function into a seismic sensor. I played with it briefly, but was content with how my sensor was behaving already. If my burglar alarm trips, I got bigger problems than a motion event.
Once I wrap up my next two videos, I’ll be jumping back into Zwave. I’ll let you know if I find anything worth sharing.
@bruhautomation Ok great, I watch your youtube videos and they are great (only issue I have it that they usually end up me spending money! Lol).
I’m just looking to do very basic reliable stuff like have the fibaro sensor turn on (and keep on) a light when somebody is in an area (our entrance hallway) and then turn it off when no activity is detected within say 1 min.
The older version (non zwave plus/v2.6) of these fibaro sensors worked great but since trying out the newer zwave plus (v3.2) I’m seeing a few odd issues (the light was switching on without anyone being in that area).
I do wonder and I’m curious… How does open zwave/device XML files get updated in HA to support new devices?
did anyone get the newer version working properly? I wasted almost 8 hours fannying on with this sensor, wished I bought the early version. I’ve reset so many times it is unreal and I am back to it working i.e. lights on when setting changes to 8. I tried the stuff in #25 but it just threw up some errors and never worked (reset again, reinstall HA again).
So now it works but LUX and temp etc only up date IF I press the B button, after 8 hours of being at work, no update… press button it updates. It is driving me crazy
Any thoughts please? or just buy the older version and keep this for another day?
Cheers
Mark
It works fine for me, with the limitation that I have to check for this burglar == 8 thing to detect motion.
Since it does not matter if I build an automation with “binary sensor == on” or “burglar == 8”, this doesn’t bother me.
I’m guessing that sooner or later openzwave will fix this anyway.
Light and temp reporting also works perfectly. You probably have to fiddle with the settings a bit and turn on regular reports and maybe reduce the threshold values for the reports.
Look at parameters 40,42 and 60, 62, 64.
I have set 42 and 62 to 1200s.
Sebastian
Bumping thread… Does anyone have this working with OpenWave 1.5 and/or HASS 0.58? I have tried the following:
After this, when I open the openzwave-control-panel I can see the burglar sensor move to 3 and 8 as mentioned in this post.
I set up an automation to create a persistent notification when the sensor changes to either 3 or 8 (below) to debug. When I use the <> states UI to set the state to 8 I get the notification.
However, this is never triggered naturally in HA and my UI looks different than I’ve seen in this post. It only (ever) shows a string “Burglar - Unknown”. Again, I can see the value ‘8’ in the OZWCP but HASS doesn’t show this and my automation doesn’t run.
OZW_Log.txt.xml (2.3 MB)
Any help is much appreciated. I’ve spent a good 8 hours on this and am at a standstill. Thanks for your help!
Am on mobile, so without looking at your log file…
If you have it working in OZW (you say you see it change values in the log) and hass isn’t seeing this changes, the first thing which comes to my mind: did you tell hass the network key? I’ve seen the exact same behavior and it turned out hass was looking at a different file which didn’t have the key back then. (This was before the ozw bundling).
The network key needs to be set like this:
Also, you can include your sensor directly within HA, so there’s no need to go through the Openzwave UI, so in the future, you would go to Configuration -> zwave -> add node secure. Then include the device. Battery operated devices like the Fibaro motion sensor may need to be woken up a few times before its attributes are loaded entirely. Lastly, restart HA for it to re-read the *zw5.xml file so it will include the proper name for the device.
Thanks! I do have the network key set okay - the OWZ log file indicates this and I have two garage doors that are security enabled that are working well. I’ll try to keep the sensor awake (triple click) some more and see if that helps.
Did you have to change association groups or other configuration parameters for your device?
No, I didn’t have to change anything to get it working, but I changed some threshold values for when it should report changes in temperature and light intensity.
Hi got now also two new Fibaro Motion Sensors Gen5.
I was able to connect them securly to the Z-Wave network and I am getting already valid temperture messurement.
What is still unclear for me is the Motion sensor.
Do I really need to add the Group 2 (motion) and group 3 (tamper) to the controller to get it working? If yes, why?
Both devices have each one sensor (burglar) and one binary-sensor
The Burglar-Sensor changes to 8 if motion is detected and the binary-sensor to on. But somehow this is not
accurate. e.g. Today I went into both rooms for a couple of seconds. Both rooms changed to “on” and “8”. One Room changed back to “0” and “off” but the other one stayed at “8” and “on” although no one was in the room.
Br,
Johannes
I posted my findings here:
