TL;DR - trying to use sub folders with NGINX (my.domain/server) and NOT subdomains (server.my.domain). Always get a 502 Bad Gateway no matter what server/service I’m trying to proxy to whether it is a separate machine like my router, or another addon on the same machine. Config file below.
I’m having issues with NGINX as well. I will start with the fact that I DO NOT want to use Subdomains. I have a limited number of available domain names through my provider that will not be enough for what I need and I do not want to switch. I have had a longstanding ddns through no-ip that I have been using over the years for access to my camera system and a couple other items on my network using port forwarding rules. When i setup hassio a year or so ago I forwarded 8123 to my RasPi and called it a day.
I recently switched to a linux VM with Docker and installed hassio in the docker using the generic linux install method so that I have a little more horsepower behind my hassio to process video feeds, etc from my cameras. Kept the port forwarding until the Google Assistant integration was broken and now requires SSL to work proper. I implemented the ssl options under the
http:
header in my config.yaml, used the Let’s Encrypt addon to obtain my certs, and all was good in my home again.
Now that the backstory is out of the way, I can move on to my current issue. I keep seeing peoples mention of using NGINX as a revers proxy for increased security for their hassio installs, but also to reduce the port forwarding required in ones router for other services. I decided I liked the idea and started researching NGINX. I installed the NGINX SSL Proxy addon and input my domain in the config. I forwarded 443 to 443 on my hassio VM and it started working. Good for me, on to expanding my setup to include subfolders, so I change my customize > “active” option to true, then setup a nginx_proxy_default.conf file in my /share folder. In that .conf file I decided to start with an easy forward that shouldn’t require too much, my router. I entered :
location /router/ {
rewrite /router/(.*) /$1 break;
proxy_pass http://192.168.1.1;
proxy_http_version 1.1;
proxy_set_header Host $host;
proxy_set_header X-Forwarded_for $proxy_add_x_forwarded_for;
proxy_set_header_ Upgrade $http_upgrade;
proxy_set_header Connection ‘upgrade’;
I expect when I enter
https://my.domain/router/
that it would take me to my router login page, but no such luck. It instead takes me to a “502 Bad Gateway” page with “nginx/1.14.0” below the Bad Gateway text. The log for NGINX says something about an invalid header and I know netgear routers have an issue currently about invalid null characters in the header and no longer work in Chrome; so assuming that is the issue, I also tried using similar settings for the Configurator addon and the IDE addon, but using http:127.0.0.1 for the proxy_pass since they are hosted on the same machine. Both of which take me to the same “502 Bad Gateway” page, but with a different error (same error for all the addons, but different from the router).
[error] 21#21: *64 connect() failed (111: Connection refused) while connecting to upstream, client: ::ffff:xx.yy.zz.vv, server: my.domain, request: “GET /ide/ HTTP/2.0”, upstream: “http://127.0.0.1:8321/”, host: “my.domain”
^ Where xx.yy.zz.vv is the public internet IP of the computer I’m trying to access from, my.domain is the domain name of my home, and /ide/ is the subfolder name (location /ide/ in my .conf file) used in NGINX.
Also, which is coming to the last straw, I can no longer access anything on my home network that requires forwarding, such as my security cameras or my OctoPi setup. The NGINX server sucks up all incoming https traffic and prevents it from passing by.
