Running 0.51.2. All seems to be well, except that the hass.io main menu has disappeared.
I suspect it may be related to the 3rd party AppDaemon/HAdashboard integration. Could a misconfigured add-on cause this? How do I get it back?
I should mention there are no errors in home-assistant.log
Add this to your configuration:
hassio:
Restart
Worked like a charm. Thank you both!
i have the same problem, and after trying the proposed solution , this error is shown :
The following components and platforms could not be set up:
hassio
Please check your config
is there anything else i could be missing, or need to include on my install ?
thanks
I also am experiencing this after upgrading to 0.61. I previously had hassio: in my configuration and was getting errors. Removing it did not bring the hass.io menu back
Same with me too! I suspect it might be a bug with the release. Logs are as follows:
Error during setup of component hassio
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 196, in _async_setup_component
result = yield from component.async_setup(hass, processed_config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/hassio.py", line 172, in async_setup
if not (yield from hassio.is_connected()):
File "/usr/lib/python3.6/site-packages/homeassistant/components/hassio.py", line 262, in _wrapper
data = yield from funct(*argv, **kwargs)
File "/usr/lib/python3.6/site-packages/homeassistant/components/hassio.py", line 333, in send_command
X_HASSIO: os.environ.get('HASSIO_TOKEN')
File "/usr/lib/python3.6/site-packages/aiohttp/helpers.py", line 99, in __iter__
ret = yield from self._coro
File "/usr/lib/python3.6/site-packages/aiohttp/client.py", line 275, in _request
resp = req.send(conn)
File "/usr/lib/python3.6/site-packages/aiohttp/client_reqrep.py", line 463, in send
writer.write_headers(status_line, self.headers)
File "/usr/lib/python3.6/site-packages/aiohttp/http_writer.py", line 247, in write_headers
[k + SEP + v + END for k, v in headers.items()])
File "/usr/lib/python3.6/site-packages/aiohttp/http_writer.py", line 247, in <listcomp>
TypeError: must be str, not NoneType
I just had a look on the web chat to see what was going on with this.
A number of people are rolling back to 0.60.1. Assuming you have CLI access to your hass.io box, enter the following command:
curl -d '{"version": "0.60.1"}' http://hassio/homeassistant/update
Then wait a while for the process to complete.
I have been experiencing the same error since upgrading 0.60.1, so you may want to go back to 0.60
Running 0.69.1, Hass.io tab disappeared tonight. No amount of CTRL+F5 or restarting helped.
Tried adding hassio
: to my customize.yaml file. Restarted. Still no Hassio tab.
Stopped the server and rebooded the pi host. Still no Hassio tab.
Nothing relevant in the log. I can still access HA via the web, ssh and SMB and it appears to be functioning as per normal except for the missing Hass.io tab.
Try to use chrome…
Yeah I sorted it out in another thread.
