Amazing app! I really like the approach. Really clean!
Where would you like us to provide feedback?
One thing I noticed: when trying to set up a home, it uses “Home Assistant Local”, so I wasn’t able to set it up when away (I downloaded it from work and had to wait until I got home!).
Is there a way of getting the device_tracker re-registered, i only get the battery level and state sensors in ha, but no traces of the app device tracker.
Also the latest changelog says climate was included but still doesn’t appear as available device in rooms
GPS, yes i guess also the zone. Well i am not sure how is suppose to work, the officlal ha app, creates a device_tracker for the app that appears in ha as soon as you enable location usage, then gets the location updates. Should this app create another device_tracker or works differently?
I have an unofficial custom component for lg thinq split ac. The climate entity is available in HA.
It creates a device_tracker with your device name (it takes the iphone name by default). If you use a different name in the official app, it should create a different one.
I fixed some issues with the climate component in the latest alpha, check that out!
Everything is working fine for me , except the message of reconnecting if i use external link , when i checked and troubleshooted with debugs i found that websockets does not work if we put external link from y side but with local it works
