Hassio & Flic Buttons
Has anybody managed to get flic buttons working on hass.io yet?
I can see that it was discussed August - October last year:
but has anyone done it yet?
The component page says:
“The platform does not directly interact with the buttons, but communicates with the flic service that manages the buttons. The service can run on the same instance as Home Assistant”
I guess my question is - is it even possible install the flic service when I have limited access to the command line using hass.io?
(I am running hass.io on a raspberry pi3 with the bluetooth service running).
The initial hass.io install went like a charm but I am now wondering if the build is too restrictive with its reduced command line. I am very new to hass.io so this may well be my inexperience / ignorance and not the software.
Any ideas or experience on this that you have would be much appreciated. It would be great to use flic if possible.
I would also like to know this! I’m preparing for the big re-installation (because of python upgrade…). I am considering HASS.io, but if flic is not working then I will have to go for hassbian once again. I’m not ready to sacrifice my 8 flic buttons…
I couldn’t find a way to do this with hass.io so I have started again with Hassbian.
Do you have a definitive way to setup the flic buttons/service? This message in the forum looks promising - https://community.home-assistant.io/t/install-flic/16969/3
Can anyone confirm that this is the correct way to do it?
This add-on/repository may be a way to get flic running on Hass.io https://community.home-assistant.io/t/issue-to-start-flicd-on-hass-io/22817/2?u=red7
I have moved over to Hassbian now but let me know if you succeed on hass.io
Good Luck
Quick update:
This worked fine for me on Hassbian:
The button appears as a binary sensor and can be used within automations. :slight_smile:
I’ve used the “guide” in the thread, and it works just fine.
Thanks for the update.
Do you flic buttons come back ok after a full reboot? Mine are a bit hit and miss.
I would say that they work after reboot for me. Sometimes they stop working, but it is usually after HA udates when i forget to reboot my pi…
Just tried this myself: using flicd on hass.io - worked a treat!
Follow the instructions in this comment, and away you go:
Issue to start flicd on hass.io
I second @king999art , works great on Hassio. I have 4 of these used every day
