How to proceed with this, which command to type in. I do not know which IP address has HomeAssistant, and can not enter the browser with homeassistant.local: 8123 or homeassistant: 8123. How to find the IP address? this is Raspberry Pi 4 / 2Gb firmware hassos_rpi-64 …5.3 img.gz and is on 120Gb SSD SanDisk
Fixed.
After installation, I connected RPi4-RJ45 to router to be able to configure HAssistant with ADDON and now works as it should, hope so!
Has anyone else upgraded from OS 5.2 with SSD+Pi working to OS 5.3? I see two folks posted positive news but wanted to see if everyone has tried it and whether it was as smooth as the above two users indicated.
I had a working set-up on OS 5.2 for a month or so. Then upgraded to 5.5. The process was very smooth and without problems. But after ± 24h the system locked up. This kept happening every day or so. Rolled back to 5.2 and problem is gone. Me I’m staying on 5.2 for now.
Looks like they just released 5.8 as stable production.
Yes saw that today.
But also got a person with problems, his installation wouldn’t start up anymore.
There was a short blink on the ssd and then it stopped, he went back to 5.4 ( seems like there was a problem with his raspberry, version 5.4 doesn’t work…he is going to try a sd card again)
later today I will give it a try, and see if I can get 5.8 to work.
I tried to update to version 5.8 using the UI. But as @DavyRoswinkel mentioned, also on my Pi4 the HomeAssistant did’t start up anymore. I’ll check what’s possible …
I updated and it works fine for me.
My friend is back on a sdcard, as the ssd doesn’t seem to work anymore.
Broken or damaged ssd?? Or wrong settings for the Raspberry to bootup?? I don’t know yet.
I was able to fix the SSD boot problem after upgrading the OS from 5.4 to 5.8: For unknown reason, the boot partition of the SSD drive wasn’t updated correctly. Hence, I executed the following steps:
- Download HassIO 5.8 image
- Create an SD card with the new OS 5.8
- Booting up HA with the new OS on the SD card
- Shutdown the Pi
- Copy the files of the SD card boot partition to the SSD boot partition (partition still existed after the OS update from 5.4 to 5.8)
- Reconnect the SSD to the Pi4
- HA boots from the SSD again as before.
I understand, that booting HA from SSD is not supported (yet). Hence, booting from the SD card and keeping the data files on the SSD might be hassle free for future updates.
Thank you for the link.
During the Home Assistant Conference (13.12.2020) Pascal Vizeli explained that the recommended way to use USB disks is for data only. The OS shall be loaded on the SD card (see conference video at 0h 20’ 30"). I should have written ‘not recommended’ instead of ‘not supported’.
Now I’m confused even more. The whole point of the USB disk is to remove the SD card once and for all. I even got Argon 40 M2 case to use M2 SSD drive with Raspberry Pi 4. Too many cards broken for me.
I guess I need to watch that part again and ask for clarification.
Thanks for the link
My argon one m2 is also ordered… so very interested in this thread
I see with the 5.8 update there is now an easy way to move the data from the sd to a ssd. Is there an easy way to update from 5.8 32 bit to 64 bit?
If you install HassOS 5.8 64bit it is not a problem to use a recovery backup which is 32bit. This is how I used it when switching from SD card to SSD disk.
Thanks. I understood this. I was asking if there was a way of doing this without going through the snapshot restore. How did you restore your recovery? All except os? Also can you just restore the snapshot thought the initial screen after HA comes up?
I believe this was added a couple of versions ago. Been waiting to go from sd to ssd for months. I have been reluctant as everything has been working so well.
I took snapshots of the original system, wrote a HassOS 5.8 64bit image to the SSD and had it run on Rpi without an SD card. I installed SSH and Samba and copied it to HA and then restored the backup.
Did you restore everything?
Yes, everything has been restored. No problem and everything works fine.
Watch that part again. Pascal clearly said:
the data disc is only usable for boards with sd card only support.
So I guess that’s not the case with Raspberry Pi 4
