anyone succeeded install on ssd with raspberry pi 4 hassOS ? My SSD does not boot or showing activity lights when i turn on raspberry pi … ssd connected with usb cable…
or do i have to wait for a ssd support for the pi 4 ?
Here works perfect. Use SD to boot and rest boot from root on SSD
This worked for me perfect. Tried this couple of times to be sure this is working. Now running for 3 months Hassio on SSD on RPi. Only first boot part from SD
Flash on SD Card Debain Buster Lite Image put in RPi4 and bootup
Now do some things on command prompt of Buster on your Pi:
(In my case my SSD is /dev/sda1, it can be different ar your setup)
sudo mkfs.ext4 /dev/sda1 -L root
sudo mkdir /media/newdrive
sudo mount /dev/sda1 /media/newdrive
sudo rsync -avx --progress / /media/newdrive
sudo nano /boot/cmdline.txt
Copy the full line in the cmdline.txt so you have 2 same lines. command 1 out with #
Replace the second line the “root=“ see below.
root=/dev/sda1 rootfs_type=ext4 root_wait rootdelay=5
Save the file
reboot now
If you have something with resize, remove that part also.
Correct location and timezone
raspi-config
Install Docker
sudo -i
apt-get install software-properties-common -y
apt-get update
apt-get install apparmor-utils apt-transport-https avahi-daemon ca-certificates curl dbus jq socat
curl -fsSL get.docker.com | sh
Install Hass.io
curl -sL "https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh" | bash -s -- -m raspberrypi3
After about 20 Min login via WebUI. Create account
Are you using a PI3 installer for a pi4??
Since August 2020 it is possible to directly boot your ssd attached via usb on a RPI4 without a SD card. Finally a firmware Update on the RPI opened this door.
And HassOS 5.2 (64bit Version) finally boots from SSD.
To use this feature you need to run the latest eeprom update.
Steps (source: boot-raspberry-pi-4-usb)
sudo apt update
sudo apt full-upgrade
sudo rpi-update
sudo rpi-eeprom-update -d -a
sudo raspi-config
Your PI should now boot directly from SSD and installs hassOS
I had it working on a Hassio 5.1 I’ve updated to 5.2 and I got a completely black screen after the splash screen.
I tried this method installing
Raspberry Pi 4 Model B (1 GB, 2 GB and 4 GB model) 64-bit
and I have the same result.
reflashing 5.1 or 5.2 worked
Wait - is this true?! we can finally boot directly from an USB drive?! No Docker or other shenanigans?! Simple, plain old HassOS?!
Does it also work with the RPi 3B+???
Dreams do come true!
well docker is integral part of hassOS and this worked for the Pi3 already for a long time.
It did?!
What kind of “long time” are we talking about?! I last tried to do that early 2020 - but then it was only possible to install home assistant in a virtual machine running on the pi (if I understood correctly) … But now (starting with HassOS 5.0?!) it’s the same thing as running it on a SD card, right?!
Which HassOS version should I use for a RPi3 B+ ? Does the latest stable 4.13 work too, or do I need to use 5.x?
I am not sure what you are talking about. I was able to install HassOS 4.x on a RPI 4 via SD card last year without a problem. And a Rasbian OS based HA installation also worked on SSD with a SD card to boot since last year. that was exactly my setup since last week.
Unfortunately I cannot recommend anything for RPI 3 because I don’t have own experience here.
I have the same question- is the dev version (5) needed to run Home Assistant (HassOS) from an SSD, or does this work with HassOS 4? I’ve followed the threads but am confused still.
No, it does not work.
The only possibility to use HassOS 4 on SSD with a Pi 4 is to use a SD-card to boot and have the data-partition on the SSD.
Thank you! So for people like me who want to switch to SSD because of previous SD issues, but are in no rush, we can simply wait till HassOS 5 is in production?
I would say so!
So news?
Boot from SSD in RasPi 3 B?
I tested also LATEST 5.4 DEV but screen stay black and no video signal.
So still boot from sd and data in ssd? I read that is possible to boot from SSD!
Maybe the problem is only for Hassos?
That should be possible also in older versions of HassOS I thought. Because the 3B can boot after a not reversible patch (don’t ask me how it works!) from USB.
The 3B+ can boot from start from USB.
I used this guide
$ vcgencmd otp_dump | grep 17:
17:3020000a
So now I cold boot from ssd… but not work (also tested ubuntu and raspbian distro)
Works like described with hassos 5.5. Perfect, thanks for the description.
