I’ve raised an issue for this on the hassos github, but am also seeing if anyone has had a similar problem here.
Screen shot:
There is no further detail after the yellow message (but do also note the red text 502 bad gateway). A single time, it said:
Cannot connect to host github-production-release-asset-2e65be.s3.amazonaws.com:443 ssl:None [Try again]
but I have tried several times (at least 15) and normally there is no follow up message.
Anyone else having any similar issues or know a solution?
Hass.os issue: https://github.com/home-assistant/hassos/issues/346
tom_l
February 10, 2019, 11:56pm
2
Yep. Exactly the same issue.
19-02-10 23:53:58 WARNING (MainThread) [hassio.hassos] Can't fetch versions from https://github.com/home-assistant/hassos/releases/download/2.8/hassos_rpi3-2.8.raucb: Cannot connect to host github.com:443 ssl:None [Try again]
Thomy
(Thomy)
February 11, 2019, 9:37am
3
Had similar problems updating, but it worked as I started the update from the command line (ssh). Maybe it’s worth a try?
Hi, I did the update from 1.13 to 2.8 yesterday without issue.
I’m using wired ethernet on a RPi 3
I would check your internet connectivity, are you able to manually download the hassOS images from github?
I am; on my phone or laptop connected to the same network. (but my pi is wired ethernet).
How do you do this? Is this the Hassio SSH or the Host SSH?
Ok, which Pi are you using?
On your laptop, are you able to download any of the files form the hassOS releases page here:
I have downloaded them successfully over the last couple of days, but I’m not currently home to be able to try again.
I have a Raspberry Pi 3B running my home assistant.
I think there’s a way to do some sort of offline update to hassos.
You may be able to copy hassos_rpi3-2.8.raucb
to a usb stick and then do an offline update
EDIT: One more thing to try is disabling any HASSIO addons, a firewall or DNS addon could be causing network issues
Thanks,
Yeah, I’ve read about that offline method. But I’d prefer to try and fix this issue first. This method has always proven reliable to me; I’m concerned I’ll get something wrong doing a more manual update!
Thomy
(Thomy)
February 11, 2019, 4:06pm
11
Well, I did it with hass.io SSH, see here for all commands:
https://www.home-assistant.io/hassio/commandline/
Good luck!
Thanks - but looks like “hassio host update” is no longer available; I can only do
hassio host info/options/reboot/reload/shutdown
Thomy
(Thomy)
February 11, 2019, 4:32pm
13
Upps, NoNoNo, just use hassio homeassistant update
Your Host-System should not be touched!
But doesn’t that just update Home Assistant? I’m looking to update Hass.Os.
Thomy
(Thomy)
February 11, 2019, 7:14pm
15
You’re right, thats another topic
In this case I strongly recommend
backup the configuration (YAML and all other custom files…)
“Bare Metal” installation of hass.io
reinstall add-ons
restore your configuration
Definitely the cleanest solution, and by the way, the ideal opportunity to replace your used SD card with a new quality SD card. Just to be on the safe side…
Simon_Bunn
(Simon Bunn)
November 5, 2019, 3:42am
16
I have the same issue with 101.2
19-11-05 03:24:36 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.101.2
19-11-05 03:24:36 INFO (SyncWorker_22) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.100.3 to homeassistant/qemux86-64-homeassistant:0.101.2
19-11-05 03:24:36 INFO (SyncWorker_22) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.101.2.
19-11-05 03:25:43 INFO (SyncWorker_22) [hassio.docker.interface] Stop homeassistant application
19-11-05 03:26:45 INFO (SyncWorker_22) [hassio.docker.interface] Clean homeassistant application
19-11-05 03:26:48 INFO (SyncWorker_33) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.101.2
19-11-05 03:26:58 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-05 03:27:13 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-05 03:37:14 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
19-11-05 03:37:14 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback
I would like to update System HassOS 3.3
But see error in logs:
19-12-20 14:58:19 WARNING (MainThread) [hassio.hassos] Can’t fetch versions from https://github.com/home-assistant/hassos/releases/download/3.7/hassos_rpi4-3.7.raucb:
How fix it? I would like to update HassOS…
honikos
(Horst 🇩🇪)
December 22, 2019, 10:41am
20
Same error for me. Any ideas?
If from CLI or WebUI, it’s the same error. Thought it’s temporarily, but Dimitrys post Hassos will not update indicates it’s not.
I am using standard hass.IO Installation on Rpi4
BTW: Is it recommended to do this update?
arch
armv7l
dev
false
docker
true
hassio
true
os_name
Linux
python_version
3.7.5
timezone
Europe/Berlin
version
0.103.3
virtualenv
false
