Hi All,
Is there a way to heal the Zigbee network like you would with a Z-Wave network? I am just curious if for instance you move Zigbee devices to a different location anything should be done to update the network
Hi All,
I found out how to do this,
Basically power off the home assistant machine for 30 minutes. This will cause all of the zigbee devices to go into panic mode. Once the home assistant machine is re started the zigbee mesh network is rebuilt. This can take a while so I tend to just leave things for at least an hour.
Hope this helps
I use the zigbee2mqtt network map plugin which re-generates once a day, I see changes happening in the network almost every day. Not sure if healing is really necessary. Do you see a device that clings to a router that is now not the most optimal path anymore?
At the time I originally posted that question I was having lots of stability issues with my Zigbee network but I have since worked through them and it is now solid & reliable.
I use the HUSBZB-1 Zigbee adapter, is it possible to use the zigbee2mqtt network map plugin you mentioned?
I would love to be able to see a visual representation of the Zigbee network. I currently use the custom Lovelace ZHA card to quickly check the status of my Zigbee devices.
I’m not sure if it is a feature of zigbee2mqtt or supported in the Zigbee protocol. Doesn’t hurt to give it a try and see what happens ![]()
Have you tried this? I added it to my install and it’s working great, I use the same zigbee hub (HUSBZB-1) using ZHA. Hope it helps.
Is this still the right way? is this somewhere documented?
Sort of resurrecting this; I cannot, on these forums or in the Home Assistant dashboard editor, find any way to add this visualization. Where can I find instructions on how to add this?
Is there a way to improve the visualisation? eg the fact it hides the text unless zoomed in very close makes it a bit of a chocolate teapot for understanding my network visualisation).
Even if the text could overlap the circles, it’d at least be usable?
I just installed a new hub device - is there anything I need to do for Zigbee2MQTT to take advantage of it or will it do it over time?
can you give me a link for this plugin, that re-generates a map?
That post is 2 years old and you don’t need an addon for this anymore. Both ZHA & Z2M have ways of showing the map within their respective interfaces now. This is from Z2M - the ZHA map was shown a few posts up.
great! thank you.
by the way, this map you posted now, is it from zigbee2mqqt or ZHA ?
It’s Zigbee2MQTT.
@hello_green for network map in the ZHA integration see documentation → https://www.home-assistant.io/integrations/zha#zigbee-network-visualization-in-zha-ui
As this forum is meant for Home Assistant’s built-in Zigbee Home Automation (ZHA) integration and Zigbee devices used with that ZHA implementation as Zigbee gateway you should really address any Zigbee2MQTT question not directly related to Home Assistant to Zigbee2MQTT’s on community → Koenkk/zigbee2mqtt · Discussions · GitHub
Regardless of Zigbee solution used do read and try to follow this guide before you begin to troubleshoot any Zigbee issues any deeper as simpy taking actions to follow those best practice tips will usually many problems and make it easier to find root cause of real problems → Zigbee network optimization: a how-to guide for avoiding radio frequency interference + adding Zigbee Router devices (repeaters/extenders) to get a stable Zigbee network mesh with best possible range and coverage by fully utilizing Zigbee mesh networking
Since when?
That’s like saying people shouldn’t be posting questions about addons or custom integrations. If they need help or clarifications and the subject is about something which is integrated in HA, then why do you feel the need to gatekeep these forums?
I just wanted to ask the following: I’ve recently moved house and thus relocated my NAS which runs my HA instance. I use ZHA to control my zigbee network.
Now my issue is the following. We now have a pet cat so I cannot use presence sensors to trigger lights or automations (too much anyways). As a result, my network will be a bit smaller than it was. What would be the easiest/best way to rebuild my ZHA/zigbee network?
ATM, I have several hue dimmer switches that aren’t functional as I’d need to rebind (or something like that) them first…Do I need to delete all devices/entities and start from scratch? Is that even possible in HA?
Any assistance or information would be much appreciated.
If you’re saying that you restored a backup after the move but your motion sensors are no longer present and causing the mesh to collapse, then I suggest you remove the devices from HA.
The mesh should “heal” itself over a day or two. If it hasn’t, then you might need to remove & readd the dimmer switches, starting from the one closest to the coordinator, in order to build up your mesh again.
If that still doesn’t fix things, then your last option would be to buy more routers.
I suggest you create a new post with the details of your install (including your ZHA map) if things don’t work out.
