Ok , I will update the docs for this
Now the dial plan is executing but now i get this.
[Feb 26 23:47:35] ERROR[378]: chan_pjsip.c:2661 request: Unable to create PJSIP channel - endpoint 'sip.linhome.org' was not found
I pinged it from ssh and that works. Not sure why it has no connection.
I will get back at this tuesday. Now i have to sleep.
Thanks a lot for your help!
Same here, should work tough, you can try replacing it with 8000
Will post tomorrow another config for testing linhome user from another softphone
Crap, i see the issue, I have a mistake in my dialplan, I will post solution tomorrow, it’s because I’m testing myself with pjsip vs chansip and I copy pasted wrong to GitHub
@Glenn22dv , change this line, add the ‘outgoing’ there …, outgoing is part of the pjsip_custom file, and is needed to define how to call a linhome external user, like h264 …
same => n,Set(DIALGROUP(mygroup,add)=PJSIP/outgoing/[email protected])
What’s wrong here ??7
Andy@iobroker:~/doorbell/examples$ python3 hik_isapi_callsignal.py
File "/home/Andy/doorbell/examples/hik_isapi_callsignal.py", line 1, in <module>
from hcnetsdk import HCNetSDK, NET_DVR_DEVICEINFO_V30, NET_DVR_DEVICEINFO_V30, NET_DVR_XML_CONFIG_INPUT, NET_DVR_XML_CONFIG_OUTPUT
ImportError: cannot import name 'NET_DVR_XML_CONFIG_INPUT' from 'hcnetsdk' (/home/Andy/doorbell/examples/hcnetsdk.py)
and hik.py :
Andy@iobroker:~/doorbell/examples$ python3 hik.py
loop[2] find 2 mac and 0 ip
Segmentation fault
Andy@iobroker:~/doorbell/examples$ uname -a
Linux iobroker 5.15.53-1-pve #1 SMP PVE 5.15.53-1 (Fri, 26 Aug 2022 16:53:52 +0200) x86_64 GNU/Linux
I need a bit of context to help you.
What version are you using? How are you running this software?
Can you please open an issue in github so we can better diagnose and discuss the problem?
New UPDATE: Two Way Audio
Guys, first steps are being made in Two Way Audio based on ISAPI, just want to give you guys an heads up… Yes, we are now able to send a spotify playlist to our doorbell
Hopefully next steps, lovelace card for sending audio!
Это очень круто. Спасибо.
Подскажите а как сделать карту с двусторонним аудио в HA?
И как интегрировать Домофон DS-KH6320 в HA? В нем есть 2 реле, 8 настраиваемых датчиков, двусторонние аудио, 4 сцены и пароль для сигнализации. Домофон DS-KH6320 можно использовать как дополнительную сигнализацию.
This is very cool. Thank you.
Tell me how to make a card with two-way audio in HA?
And how to integrate Intercom DS-KH6320 into HA? It has 2 relays, 8 configurable sensors, two-way audio, 4 scenes, and an alarm password. Intercom DS-KH6320 can be used as an additional alarm.
Hi, for integration for sensors, make sure to install the BETA addon, it has more stuff… No alarm input sensors yet, but try to test us and enable debug mode as described, create an issue thread and show us the output, so we can help making the sensors
For two way audio, you can use official SIP, or alternate approach is my baresip addon
For two way audi based on ISAPI, there is no card yet, the webrtc card doesnt have a microphone service “yet” … but you can use go2rtc for that, all described here:
GitHub - AlexxIT/WebRTC: Home Assistant custom component for viewing almost any camera stream in real time using WebRTC and other technologies.
For guys want to test out, since documentation is not yet availble on github
Installed this addon, make sure to use “master”
Then configure like below:
streams:
hikvision:
- rtsp://admin:[email protected]:554/Streaming/Channels/102
- isapi://admin:[email protected]/
Then add virtual mediaplayer:
media_player:
- platform: webrtc
stream: hikvision
audio: pcmu
Then send something with TTS service!!
Hi, is it possible to call a http-event to my local server if someone press the doorbell
DS-KD8003-IME1
V2.2.56 build 220916
- is it possible to open the door from a sip-phone? (Fritz-Box-Router an SIP-Devices)
Hi, yes, see first post, you can install the Doorbell Addon, that will give sensor in HA
If you want to enable SIP on the devices, you can open door by sending ‘#’ during call , dtmf method = info
thx, i read it, but i dont want run home-assistant only for notification for the doorbell.
i also tried to call callStatus, but the response ist always idle.
ist there no way to get a notification via http?
‘#’ works, thanks a lot!
Yes, ISAPI for callstatus doesnt work on 8003 models, because you need to grab if from indoor panel, and indoor panel doesnt support port 80 , so no isapi there… Only alternative is to use SDK instead or go the SIP road… The addon also works as standalone, and if you are patient, there will be an mqtt version… to make it even easier
okay thank you for your fast answer!
i will install home assistant on a old raspi 3 i found
then i will install the addon, thank you!
make sure its not too OLD
, the SDK is limited to aarch64 and amd64
its aarch64
