Hi, do you have an indoor device? You need something to call… In case of no indoor station and no hikconnect, you will have calling failed, so that’s normal indeed.
You can still enable hikconnect, but in hikconnect itself disable the incoming notification
Hi, thank you for your prompt answer. No, I don’t have any indoor device, as I have a homepod mini, I use it as a chime when someone push the call button. Okey interesting, I don’t know the SIP option, I guess i’ll take a look to see how it works. Anyway, after blocking internet access of the device, it stopped working after it detected that it has gone offline. So as you said SIP obliged. Thank you very much.
First of all, my apologies if this topic was discussed earlier. I have been searching in the thread and haven’t found anything relevant.
A few days ago, I found this firmware for DS-KV6113-WPE1(B) doorbell model. If you go back to the Home menu, you can browse the whole repository, which contains a lot of tech docs and firmware versions that cannot be found in the standard end-user websites.
The thing is that such firmware version fixes the front device’s green LED behaviour. Such LED was supposed to light upon opening a gate relay. On previous and “official” version V2.2.53_220602 (the latest available in Hikvision website), the green LED was always lit. Now, the green lights when it should. But, more important, the new version sends a photo to the App, which it is displayed as an event and kept there, so if you have a missed call, you can see such photo. This was not possible until now, at least with my model:
Both features are not listed in the release notes. Is there a way to fetch such photo without using any other thing? Currently, I get photos and clips through Frigate, but it would be great for the addon to be able to get such image through an image or camera entity, for example, so it can be handled for automations, dashboard, etc. I have been Googling but I haven’t found any information about it, just the usual info to get a photo manually through an ISAPI command.
I am not sure whether this photo capture is handled by the doorbell or the Hik-Connect App itself, so I am not actually sure whether it is possible to do this, but it was worth it to ask.
Hi , no there is no camera/picture entity in the add-on, don’t think mqtt is good for that, I don’t think it supports video at all… Best to use the rtsp stream
Hi , i dont know that device, but in first post of this thread, you will see some example commands based on curl
btw; why not using the addon? have you tried it? SDK is always better then curl/php , its faster since its based on events and not polling
Okay I can’t figure out where I am going wrong and need some help.
Set-up:
DS-KH6320
DS-KD8003
Homeassistant running in Docker
Steps taken:
Frigate running in a docker container
MQTT running in a docker container
I am running the add-on in a docker container
I upgraded the go2rtc to the newest version
I added the go2rtc rtsp and isapi streams to my frigate docker config
I configured the development.env file with the path to the outside and inside units
I installed the frigate integration and it picks up my outside unit
I got HA to talk to the indoor and outdoor units using MQTT
I installed the lovelace card and configured it
Now I am getting a live stream from my doorbell camera and I can see the clips from the persons it detects. So that is all working.
In MQTT all the controls are in blue and I managed to decline a call by pressing ‘Hangup call’ on my indoor station. So it seems to be properly linked. But it doesn’t work in the lovelace card and I can’t get two way audio to work.
I enabled ISAPI request but that stays on ‘unknown’. Also ‘Call state’ remains unavailable on the outdoor unit.
So it seems I did something wrong or forgot something but I can’t figure out what exactly.
Would it be possible to get a different state for the call_state sensor when the doorbell is on a call? Currently (at least with my DS-KV6113-WPE1(B)), the idle state is “idle”. When someone pushes the doorbell button, such state changes to “ringing”. However, if the call is picked up, state stays on “ringing”, rather than “on_call” or something similar. I checked the relevant MQTT topic state hmd/sensor/Doorbell/Call-state/state and it is updated in the same way.
Hi, thats correct, the SDK doesnt provide the “on_call” event, thats why we dont update the sensor state… we only see ringing/dismissed events
However, in the last addon update .14, i added an extra button, if you press on it it sends an ISAPI command, maybe you can poll that one x amount of seconds with an automation when you see an ringing event?
That call info button should give more details like “on_call” etc …
Hi, I’m using the add-on and it works very well… but after the last update, my automations for employee face recognition stopped triggering. I read the change log that “now the employee is an attribute” but I think it does not affect the automation because I didn’t see any change in the trigger settings. Can you please help me? This is my yaml code:
As your proposal remove the device and restart. The employee trigger disappears and unfortunately this doesn’t work. I will reed the mqtt option and hope to have success.
Yes, there is only 1 device trigger now, only the payload is different, that payload contains the employee id… You can use it normally in the device trigger automation
You can look with mqtt explorer to see the payload
First of all, check if ISAPI already works, you can expose/enable port 1984 in the Frigate Add-on, afterwards you can surf to to [http://mylocalip:1984](http://mylocalip:1984/) You should see the camera there, with also a "links" command, click on it, at the bottom you should see: "video+audio+microphone = two way audio from camera"
Do I have to install the go2rtc addon from Alexii or not? If I do not install it at myip:1984 I get ERR_CONNECTION_REFUSED
If I install the go2rtc addon when I go to myip:1984, I get this
