No, don’t install the go2rtc add-on , update the version inside the frigate add-on, as explained on my GitHub
I believe the new beta frigate add-on already includes a newer version
Ok ok thanks I solved it, now that part works.
Now my problem is the Hass frigate card, I copy pasted your code, changed the entity-id with mine, but it gives error in Lovelace, I tried it all, checked indentation 10 times, something I am missing?
When I keep this part, it works but of course shows only the camera no controls,
- type: custom:frigate-card
cameras:
- camera_entity: camera.door12n_f
live_provider: go2rtc
go2rtc:
modes:
- webrtc
once I add all code I get the error
cameras:
go2rtc:
modes:
- webrtc
menu:
style: outside
position: bottom
buttons:
microphone:
enabled: true
type: toggle
screenshot:
enabled: false
download:
enabled: false
fullscreen:
enabled: false
snapshots:
enabled: false
timeline:
enabled: false
media_player:
enabled: false
clips:
enabled: false
live:
enabled: false
cameras:
enabled: false
frigate:
enabled: false
camera_ui:
enabled: false
live:
auto_mute: never
controls:
builtin: true
title:
mode: none
layout:
fit: fill
elements:
- type: custom:frigate-card-menu-icon
icon: mdi:volume-high
tap_action:
- action: custom:frigate-card-action
frigate_card_action: unmute
icon: mdi:volume-off
tap_action:
frigate_card_action: mute
icon: mdi:phone
tap_action:
- action: call-service
service: button.press
entity_id: button.door12_answer_call
entity_id: button.door12_hangup_call
frigate_card_action: microphone_unmute
icon: mdi:phone-hangup
tap_action:
frigate_card_action: microphone_mute
icon: mdi:door-open
hold_action:
service: switch.turn_on
entity_id: switch.door12_door_relay_0
dimensions:
aspect_ratio_mode: static
aspect_ratio: '16:9'
its not about code/identitaion, your frigate card isnt installed correctly
Maybe a cache issue, maybe you ddnt add it to your resources?
I edited my message after your answer: with simple code it works, with all the code it gives error. I edited my previous message, to show the two cases
your code is fine, its the card that isnt installed correctly
custom element doesnt exist means => card is not found
if its the code, then you will see other errors , it would even load the UI
Try deleting cache, i always test in chrome incognito mode, thats the best test to see if all cards are installed
Yeah some weird HACS thing, I solved I don’t even know how to replicate, just a good combination of clearing cache and restart.
Now all works except the answer button, when I click on it I get this as a popup in chrome bottom left
Failed to call service button/press. must contain at least one of entity_id, device_id, area_id.
also try to use “service_data” instead of “data”
i updated the docs, but seems the new card is not released yet, so you need to use “service_data”
I changed my github page back to old version
its strange sometimes it does it sometomes not, changing to service_data its the same
what error do you see then in the log? it should work always, maybe again a cache issue
what error do you see now then? check also HA log itself
Just now someone ringed doorbell, when I press answer button gives popup error.
Below the log.
Maybe has to do because I use frigate full access version?
Can’t send file with kwargs: {‘url’: ‘https://myip/api/frigate/notifications/1706342144.5153-vnb13e/door12n-f/clip.mp4’, ‘timeout’: 1000, ‘caption’: ‘A person was detected on door12n-f camera’}
09:11:04 – (ERROR) Telegram bot - message first occurred at January 26, 2024 at 22:34:46 and shows up 82 times
Can’t load data into ByteIO: HTTPConnectionPool(host=‘ccab4aaf-frigate’, port=5000): Max retries exceeded with url: /api/events/1706340416.666693-7go9zx/thumbnail.jpg (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7fb0b4692810>: Failed to establish a new connection: [Errno -5] Name has no usable address’))
09:10:18 – (ERROR) Telegram bot - message first occurred at January 26, 2024 at 22:34:46 and shows up 41 times
You are still with an issue with the code/cache/card…
Maybe your code is wrong? I changed like this
(sorry I am with phone doesn’t show code icon for formatting code)
(BTW why unmute and after microphone_unmute?)
MY CODE
elements:
tap_action:
tap_action:
icon: mdi:phone
tap_action:
service_data:
tap_action:
service_data:
icon: mdi:door-open
hold_action:
dimensions:
YOUR CODE
elements:
tap_action:
tap_action:
icon: mdi:phone
tap_action:
entity_id: button.door12_hangup_call # <====== ??????
tap_action: # <========== missing hang up call?
icon: mdi:door-open
hold_action:
Yeah, try to post formatted code… But I think you didn’t intent the “entity_id”
Microphone_mute and mute and different things, one is audio, one is micro
Ok I edited the post from PC. Ok got it the mute and microphone_mute difference.
Is not possible to have a button press like the Hikconnect app (the micriphone icon in that app), when pressed it acrivates the dual audio communication ?
The microphone button enables two way audio, the same as in hikconnect…
Only on a real incoming call, you first need to answer it, then unmute, that’s why there are multiple services
I don’t see the microphone button…?
Did you check my edited post?
Show me with a picture
