Also for HomeKit users, using Scrypted with vityevato’s hikvision plugin still doesn’t work with two-way audio, despite enabling Hikconnect on KH9510. I think the plugin is still trying to send Reject & Hangup commands to the KV6113 doorbell instead of the KH9510 indoor station, which might be why it doesn’t work. Not sure how to change this though.
Yeah I don’t know why hikconnect is needed to send those commands;-(
If you want to go fully local, sip is indeed an alternative
when I do a call (the same configuration like for doorbell) from SIP client I get a ring - so, it looks that customizing on SIP server is ok
Hello, I have DS-KV9503-WBE1 working with your add-on. I installed magnetic contact sensor to AI1 and it is working fine. I receive two magnetic_door_status events, one when I open the door and one when I close the door. Is it possible to have OPEN | CLOSE state in the trigger payload?
Can we proceed on GitHub for this
Hi folks, thanks for the great work with this addon!
I purchased a DS-KV8113-WME1(B) outdoor unit, which works fine with frigate (with username and password). I tried to connect to it with this addon, using same username and password as I do in frigate and I get the following error
2024-04-11 16:13:33.322 | DEBUG | __main__:main:31 - Importing Hikvision SDK
2024-04-11 16:13:33.335 | INFO | sdk.utils:loadSDK:44 - Using OS: Linux with architecture: x86_64
2024-04-11 16:13:33.335 | DEBUG | sdk.utils:loadSDK:57 - Loading library from lib-amd64/libhcnetsdk.so
2024-04-11 16:13:33.376 | DEBUG | __main__:main:35 - Hikvision SDK loaded
2024-04-11 16:13:33.376 | DEBUG | sdk.utils:setupSDK:86 - Initializing SDK
loop[2] find 2 mac and 0 ip
[2024-04-11 16:13:33.397][DBG] CCoreGlobalCtrlBase::LoadDSo, HPR_LoadDSo Succ, Path[/lib/x86_64-linux-gnu/libz.so.1.2.11], hHandleRet[566695936]
[2024-04-11 16:13:33.397][INF] The COM:HCCoreBase ver is 6.1.4.15, 2020_03_05. Async:1.
[2024-04-11 16:13:33.397][INF] The COM:Core ver is 6.1.6.45, 2021_03_02. Async:1.
[2024-04-11 16:13:33.397][INF] This HCNetSDK ver is 6.1.6.45 Ver 2021_03_02.
2024-04-11 16:13:33.397 | DEBUG | sdk.utils:setupSDK:100 - SDK initialized
2024-04-11 16:13:33.398 | DEBUG | doorbell:__init__:51 - Setting up doorbell: auloporta
2024-04-11 16:13:33.398 | DEBUG | doorbell:authenticate:59 - Logging into doorbell
[2024-04-11 16:13:33.398][INF] Login dev 192.168.1.27:8000.
[2024-04-11 16:13:33.398][INF] dwTotalNum[2048]
[2024-04-11 16:13:33.399][INF] Private connect 192.168.1.27:8000 sock=135 this=0x220d2ac4 cmd=0x10000 port=42046
[2024-04-11 16:13:33.399][INF] LogonDev1 in[192.168.1.27:8000]
[2024-04-11 16:13:33.402][DBG] CCoreGlobalCtrlBase::LoadDSo, HPR_LoadDSo Succ, Path[/app/lib-amd64/libcrypto.so], hHandleRet[571176208]
[2024-04-11 16:13:33.405][DBG] CCoreGlobalCtrlBase::LoadDSo, HPR_LoadDSo Succ, Path[/app/lib-amd64/libssl.so], hHandleRet[570636192]
[2024-04-11 16:13:33.406][INF] SSLTRANSAPI::LoadAPI, libeay, Load Real Path[/app/lib-amd64/libcrypto.so]
[2024-04-11 16:13:33.406][INF] SSLTRANSAPI::LoadAPI, libssl, Load Real Path[/app/lib-amd64/libssl.so]
[2024-04-11 16:13:33.406][INF] SSLTRANSAPI::IsAllAPILoaded, OpenSSL_version Unload
[2024-04-11 16:13:33.406][INF] OpenSSL, Not All Function Loaded!
[2024-04-11 16:13:33.407][INF] SSLTRANSAPI::PrintVersion, SSLeay_version info [OpenSSL 1.0.2t 10 Sep 2019]
[2024-04-11 16:13:33.408][INF] CSSLTrans::SSLCtxInit, dwSSLVersion[0], m_fnClientMethodV23
2024-04-11 16:13:33.630 | ERROR | __main__:<module>:101 - Error while logging into auloporta: User name or password error. Error code:1
[2024-04-11 16:13:33.629][ERR] LogonDev1[192.168.1.27]
[2024-04-11 16:13:33.629][ERR] [192.168.1.27:8000]PRO_LoginHikDevice fail[err=1].[0x-0000001,0x-0000001]
[2024-04-11 16:13:33.629][ERR] CMemberMgrBase::AllocIndex2, MemberStart Failed, iIndex[0]
[2024-04-11 16:13:33.637][INF] COM_Logout[-1][1]
any tips on how to fix this?
maybe strange character in password? are you using the admin account? maybe a firmware upgrade? reboot?
Weird I just changed the password to something else and it worked. Previous password was alphanumeric, no strange characters.
I followed your tutorial and installed Asterisk to use SIP. I set it up as an extension in the indoor station. It registered successfully. However, I don’t understand what to do from here. How can I receive, answer and reject calls like with your Hikvision add-on? How do I send these commands?
If you are using SIP, you don’t need to use answer commands from the addon, you need to use sip to answer
Hi Fabio👋
I have the Doorbell KV-8213 with 2 Buttons.
Is it possible to use this only with HomeAssistant (without Indoor Station)?
I want use your Addon Hikvision Doorbell and the Frigate for 2way Audio.
I’m already try your step by step Instructions.
Now I installed your Addon and I can see all entity in mqtt. With frigate Addon I can see the image but I have no 2 way functionality. And I can’t see the microphone button. What’s wrong?
My doorbell have 2 buttons how can I create an automation with notify for example button 1 to tablet 1 and button 2 to tablet 2 ?
BR
Neotixc
Uh, not sure , my addon doesn’t have any relationship with frigate, I created an basic guide to start with frigate, if you follow that guide , it’s a good start point, make sure to setup https and a valid ssl, it’s an requirement
Okay thank you!
Do you know how can I set the doorbell button, for example button 1 goes to tablet 1 and button 2 goes to tablet 2?
On the Doorstation itself, you can define SIP numbers, that way you can call different devices
(You need a Doorstation with multiple buttons offcourse)
Of course I have the door Station KV-8213 with 2 Buttons.
Which add on for home assistant i need to Setup the SIP numbers for the Doorstation?
There is an asterisk addon, it’s preconfigured to call a Lovelace card
Here is an example using yeastar for example…
For Asterisk you don’t need the indoor station to forwarding the call?
Indeed, for SIp, no indoor station is needed
Hi, I want to use DS-KV8213 in two apartments. I want to call the first button and respond with an indoor station and the second button responds from a wall-mount Android Tablet. Is it possible? I really appreciate any help you can provide.
