sorry @Steveuk I cant get it right like yours. Is it possible if you could please share the code?
thanks.
Yeah Iām not sure if this has copied and pasted correctly as itās so hard from my phone on the HA app.
If not Iāll re do it later on my laptop when Iām home.
Should come through ok if you stick it in a manual card.
type: vertical-stack
cards:
- type: 'custom:simple-thermostat'
entity: climate.home
sensors:
- entity: sensor.home_boost
attribute: Boost ends in
name: Boost ends in
control: false
- type: horizontal-stack
cards:
- type: 'custom:button-card'
tap_action:
action: toggle
entity: script.boost
icon: 'mdi:fire'
state:
- operator: template
value: |
[[[return (states["sensor.home_boost"].state === 'ON')]]]
styles:
icon:
- color: 'rgb(255,119,0)'
- value: 'on'
styles:
card:
- filter: opacity(100%)
icon:
style: |
ha-card:hover {
transform: scale(1.01);
box-shadow: 0 0 10px;
tap_action:
action: toggle
entity: script.1611181589757
icon: 'mdi:fire'
state:
value: |
styles:
icon:
- value: 'on'
styles:
card:
icon:
style: |
ha-card:hover {
tap_action:
action: toggle
entity: script.1611181628914
icon: 'mdi:fire'
state:
value: |
styles:
icon:
- value: 'on'
styles:
card:
icon:
style: |
ha-card:hover {
thank you it worked perfectly. Here it is:
However, I dont have the card that states āoperationā in your lovelace?
And also is it possible to change the font of this particular thermostat card? or is it all driven by themes?
Also I suppose there is an issue with your code, as when I pressed boost 45 all the rest of the boost turned orange. I would have expected only boost 45 to turn to orange?
Ah yeah sorry I forgot I made mine compact.
In the code change line control: false to true then your should get them.
As for all the buttons lighting up I tried doing that but I couldnāt figure out how to do it then forgot.
The problem is all 3 buttons report the state of 1 sensor so I think i need to create another 2 sensors then link the other buttons to that.
thanks for that.
I suppose an if statement would do the trick.
Iām still learning all this so Iāll take your word for it
If you get that working let me know.
Still having no luck, no idea why Iāve not got my climate showing. Iāve installed the custom component and then set up integration via UI but no luck. No idea what Iām missingā¦
What version of home assistant are you running?
Apparently, Iām an idiot and I just didnāt have it up to dateā¦
Is anyone experiencing hive outage on HA using this custom component? I find hive on my HA randomly appearing as unavailable however after restart it re appears again.
@Khole ?
@bachoo786 No I have not experienced any issues with my hive integration did you have any errors in the logs?
no errors in the log. so not sure really
I raised an issue as I had a lot of errors in the log and random 'stats and TRVs going offline, but it was closed down.
I uninstalled it and installed the standard Hive integration, which was good for a few weeks, but tonight the same problem has reared its ugly head.
Iāve uninstalled the standard integration now, to see if the problem comes back with just a standard Hive setup and as I really donāt know what else to do.
I was having a similar problem, suddenly loosing all my Hive devices and entities in Home Assistant a week or two ago. Like you, one of my TRVs had been frequently going offline and so Iād been uninstalling and re-installing it. When I checked my Hive app today, I noticed that I had a āghostā offline duplicate TRV showing amongst its devices. I contacted Hive support and after some false attempts they were able to remove this offline/duplicate device for me. All my other Hive devices immediately then re-loaded when I reinstalled the Home Assistant integration. So I think my problem lay at the Hive end of things.
Well, not even 24 hours later and Iāve got a red light on one of my receivers and random TRVs showing that theyāre offline.
Iāve spent nearly an hour trying to get them back online but itās having none of it. So, Iāll be wasting time tomorrow trying to get to the bottom of it with Hive. Joy.
Hi @DragonSorcerer did you manage to work this out? I am trying to use a script to turn the heating on and increase the temperature by 2 degrees.
This is what I have,
entity_id: climate.thermostat
time_period: "01:00:00"
temperature: '{{ (states("sensor.thermostat_current_temperature")) + 2 }}'
@bachoo786
No, I gave up on the boost and went for a simple switch on the heatingā¦
service: climate.set_temperature
entity_id: climate.thermostat_1
data_template:
temperature: '{{ states("input_number.heatingtargettemp") }}'
do we need to switch over to the official integration to have support for hive.boost_heating_on or will the current version of the custom component be fine ?
Now that 2021.5 is released we will look to release a new custom component version with the updated services.
Thank you for that. Do you think it makes sense to switch over from custom to official or is there not much benefit?
Thanks again
