It’s up to you do you need/use the extra sensors that custom component offers? If you don’t you can switch to the official one.
hi All,
Version 2021.5.1 of the custom component has been released which adds the new features from 2021.5.0 home assistant release to be included.
Hi @Khole
After updating my HA to 2021.5 I have lost my hive climate. It says unavailable and I am planning to go back to HA 2021.4.6.
is this a known issue with the new HA release?
What version of hive are you using ? if you’re using the custom component I would think you need to upgrade that as well
I did not have the notification of the latest version of the custom component. I have updated it to the latest version and have updated HA to the latest version.
It seems to be working fine for now. Thanks.
Just to +1 this. I’ve lost climate and my Hive plug switches. Temperature is still there, as are some of the plug sensors.
I’m using the normal Hive integration, not the custom component.
@DragonSorcerer so I managed to work the template by adding int
entity_id: climate.thermostat
time_period: "01:00:00"
temperature: '{{ (states("sensor.thermostat_current_temperature")) | int + 3 }}'
It works fine for me now i.e. raises the temperature by 3 degrees of the current temperature.
sorry @ajcooper72 I have no idea on the normal Hive integration. Try and report it on the blog post of 2021.5 or on HA github.
Here is the link: 2021.5: Stability, performance, triggers, color modes! - #13 by tozzke
Just to +1 this… me too. rolled back to 2021.4 for now…
mine also lost climate rolling back also
What version of home assistant are you running when you updated to 2021.5.1 of the hive custom component?
For anyone wondering why hacs isn’t showing hive as installed this is due to a repository name change and a pull request has been raised to fix the issue. Once merged the issue will no longer be there.
a restart fixed the issue
For anyone using the hive custom component version 2021.5.1 please could you also upgrade to the latest version of home assistant
My water boost scripts and service calls from developer mode have stopped working:
Trying to turn on:
2021-05-08 17:42:24 ERROR (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Error executing script. Unexpected error for call_service at pos 1: 'WaterHeater' object has no attribute 'turnBoostOn'
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 363, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 563, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1481, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1516, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 630, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 726, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/hive/__init__.py", line 106, in wrapper
await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hive/water_heater.py", line 142, in async_hot_water_boost
await self.hive.hotwater.turnBoostOn(self.device, time_period)
AttributeError: 'WaterHeater' object has no attribute 'turnBoostOn'
2021-05-08 17:42:24 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139625019514400] Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 21, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 482, in handle_execute_script
await script_obj.async_run(msg.get("variables"), context=context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1209, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 345, in async_run
await self._async_step(log_exceptions=False)
await service_task
task.result()
await coro
await result
Trying to turn off:
2021-05-08 17:43:32 ERROR (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Error executing script. Unexpected error for call_service at pos 1: 'WaterHeater' object has no attribute 'turnBoostOff'
await service_task
task.result()
await coro
await result
File "/usr/src/homeassistant/homeassistant/components/hive/water_heater.py", line 144, in async_hot_water_boost
await self.hive.hotwater.turnBoostOff(self.device)
AttributeError: 'WaterHeater' object has no attribute 'turnBoostOff'
2021-05-08 17:43:32 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139625019514400] Error handling message: Unknown error
await service_task
task.result()
await coro
await result
Any Ideas Dev?
My hive.boost_hot_water service seems to have disappeared in the latest version
Yes me too, not sure when it went missing, not used it for a while
Any ideas when the PR is being merged ?
Same here. Gone since Core 2021.5.1 update. I use boost in automations on daily basis and now its gone. If devs could fix this would be really great. Thanks
Hi all,
Thanks to @Ovid for fixing the hot water boost and 2021.5.4 has been created for the custom component
