So I’m not alone! No, to be honest, I don’t have find a solution. I’ve deleted the repo, readded, reloaded multiple times, reloaded Supervisor, Hass.io and even rebooted the Raspi. Nothing. Even changed IP and DNS server. No luck. I still see the ls113 version.
I’m investigating… In the meanwhile I’ve duplicated the latest version in this temporary repo : alexbelgium/hassio-addons-test (github.com) and it was confirmed to be able to install the latest version, however it is a one-off as I can’t update both repositories…
It’s solved! Just reload the repo and you’ll find the latest version, ls117.
I had an hidden file that referenced ls113 and prevented to update! That’s great, now it’s working and I learned something
Great! Confirmed, it works now.
I don’t understant what tge “networkdisks” are for. Is it to use a network folder as a download folder? That would be what I wanted to.
@glorifiedg Hi, that’s exacty that.
You write on networkdisks your smb paths, then the username and password to get there. You need to check a specific checkbox if you are using smb1.
This allows accessing either distant smb shares, or local hdd by mounting them first with (sambanas)[[New Addon] Samba NAS. (Mount external disk and share it )] .
Here are two examples :
- Will mount the smb share to /mnt/downloads, and set the download path
networkdisks :
//HOMEASSISTANT/NAS/downloads
cifsusername: homeassistant
cifspassword: password
SavePath: /mnt/downloads
- Will mount the smb shares to /mnt/downloads and /mnt/hello, and set the download path
networkdisks : "//192.168.178.1/FRITZNAS/downloads, //192.168.178.23/system/hello"
cifsusername: "homeassistant"
cifspassword: "password"
SavePath: /mnt/hello
If you have issues with network load, you can set a temporary local download directory from bittorrent webUI, then once the download is complete it will be moved to the path in the SavePath option
hi alexbelgium
I’m using your transsmission-NAS addon. Thanks for it. I have the config that you describe, but I receive Permission denied error. please advice. my config and logs are below
In transmision Web-ui I have correct disk size. From windows I have full access to //10.0.0.5/bigpen/
transsmission yaml:
PUID: 1000
PGID: 1000
download_dir: /mnt/bittorrent
incomplete_dir: /mnt/bittorrent/incomplete
networkdisks: //10.0.0.5/bigpen/bittorrent/
cifsusername: zzz
cifspassword: zzz
smbv1: false
transmission nas startup log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 01-envfile: executing...
[cont-init.d] 01-envfile: exited 0.
[cont-init.d] 10-adduser: executing...
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User uid: 1000
User gid: 1000
[cont-init.d] 10-adduser: exited 0.
[cont-init.d] 20-config: executing...
[cont-init.d] 20-config: exited 0.
[cont-init.d] 20-transmission-configuration.sh: executing...
[cont-init.d] 20-transmission-configuration.sh: exited 0.
[cont-init.d] 50-mounts.sh: executing...
[09:05:37] INFO: Mounting smb share(s)...
[09:05:41] INFO: ... //10.0.0.5/bigpen/bittorrent successfully mounted to /mnt/bittorrent
[cont-init.d] 50-mounts.sh: exited 0.
[cont-init.d] 99-custom-files: executing...
[custom-init] no custom files found exiting...
[cont-init.d] 99-custom-files: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
error message after adding torrent file:
zzz.x265-AAAUHD tr_fdFileCheckout failed for “/mnt/bittorrent/incomplete/zzz.x265-AAAUHD/zzz.x265-AAAUHD.mkv.part”: Permission denied (/home/buildozer/aports/community/transmission/src/transmission-3.00/libtransmission/inout.c:95)
My samba-NAS config:
workgroup: WORKGROUP
username: zzz
password: zzz
interface: ‘’
allow_hosts:
- 10.0.0.0/8
- 172.16.0.0/12
- 192.168.0.0/16
- ‘fe80::/10’
moredisks: - BIGPEN
veto_files: - .DS_Store
- Thumbs.db
- icon?
- .Trashes
compatibility_mode: false
autodiscovery: {}
My samba-NAS startup log
[fix-attrs.d] done.
[cont-init.d] automount.sh: executing...
[09:18:23] INFO: Protection Mode is false
[09:18:23] WARNING: MoreDisk option found!
[09:18:23] INFO: More Disks mounting.. BIGPEN
[09:18:23] INFO: Mount BIGPEN
[09:18:24] INFO: Success!
[cont-init.d] automount.sh: exited 0.
[cont-init.d] mqtt.sh: executing...
[cont-init.d] mqtt.sh: exited 0.
[cont-init.d] samba.sh: executing...
[09:18:27] INFO: Hostname: homeassistant
tdbsam_open: Converting version 0.0 database to version 4.0.
tdbsam_convert_backup: updated /var/lib/samba/private/passdb.tdb file.
Added user homeassistant.
[cont-init.d] samba.sh: exited 0.
[cont-init.d] done.
[services.d] done.
[09:18:28] INFO: Starting the AVAHI daemon for homeassistant...
[09:18:28] INFO: Starting the MQTT daemon for disks info...
nmbd version 4.12.9 started.
Copyright Andrew Tridgell and the Samba Team 1992-2020
Waiting for daemon ...
daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
smbd version 4.12.9 started.
INFO: Profiling support unavailable in this build.
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
[09:18:29] INFO: Sending MQTT autodiscovery...
Samba name server HOMEASSISTANT is now a local master browser for workgroup WORKGROUP on subnet 172.30.32.1
Samba name server HOMEASSISTANT is now a local master browser for workgroup WORKGROUP on subnet 172.17.0.1
Hi @trynqz, thanks for testing the addon!
Your config seems fine, and samba NAS works correctly.
The most probable root cause is that the incomplete folders didn’t exist in the requested path. Could you check? Thanks
/incomplete folder existed.
PUID: 0
PGID: 0
Did the trick. Now it is working. Thanks
New feature : ingress addition
Starting from version *ls125-rev2, the addon supports ingress (with or without ssl) in addition to the current WebUI access ! Ingress is set to the VueTorrent view, however the customUI option still allows to select the UI that you want when accessing directly from the ip.
If it asks for a password in ingress just click OK the url is anyway whitelisted as it is local. You can however remove whitelisted url from the addon options if your prefer.
Please star the github repo if this is useful to you!
Thanks for your addon! If I try to mount a samba share, I get the following error:
[cont-init.d] 91-configuration.sh: exited 0.
[cont-init.d] 92-smb_mounts_v1.1: executing...
[14:30:16] INFO: Mounting smb share(s)...
mount error(13): Permission denied
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
[14:30:17] ERROR: Unable to mount //10.0.0.100/Data/Data to /mnt/Data with username milenco, somepassword
[cont-init.d] 92-smb_mounts_v1.1: exited 0.
I believe this is because the addon isn’t running in unprivileged mode (Protection disabled), but I don’t have the option, as you can see here:
What should I do?
Hi, thanks for testing the addon! I had removed the full access tag as it was normally not useful anymore with the new apparmor system…
Could you please try to check the box “smbv1” in the addon option and restart - by default the system tries to mount with smbv2.5
Also, could you please check that it is correctly capital letters for “Data”, that you really have two successive “Data” folders, and that there is no “weird” characters in your password that could mess with the code ?
Could you also check in supervisor log if there is more details?
If this doesn’t work, could you please try to mount if manually in the web terminal addon (that allows running both in priviledged, and in normal mode) with the commands :
mkdir /tmp
mount -t cifs -o username=USERNAME,password=PASSWORD //10.0.0.100/Data/Data /tmp
This would allow to see if the issue with priviledge mode, or with something other.
And if you have a workgroup,
mount -t cifs -o username=USERNAME,password=PASSWORD,domain=WINDOWSDOMAIN //10.0.0.100/Data/Data /tmp
Thanks!
Thanks for taking time to look into this issue for me! As for the path, I’m pretty sure it’s spelled correctly. This is how it’s mounted on my Macbook:
m.mulder@MacBook-Pro-van-Milenco ~ % mount |grep 10.0.0.100
//[email protected]/Data on /Volumes/Data (smbfs, nodev, nosuid, mounted by m.mulder)
m.mulder@MacBook-Pro-van-Milenco ~ % ls -l /Volumes/Data/Data
total 128
drwx------ 1 m.mulder staff 16384 15 apr 10:04 ~new
Mounting with the samba v1 option gives the same error:
[22:28:49] INFO: Mounting smb share(s)...
[22:28:50] ERROR: Unable to mount //10.0.0.100/Data to /mnt/Data with username milenco, somepassword
[cont-init.d] 93-openvpn: executing...
As for mounting it manually: It doesn’t work from within the addon (I have SSH access to the host and access it directly using docker), I still get a permission denied error. Mounting it on the host obviously works, but the vm doesn’t share the /tmp folder so I can’t get it accessed there.
See the logs:
root@minos:~# docker exec -it addon_db21ed7f_qbittorrent /bin/bash
root@db21ed7f-qbittorrent:/# mkdir /tmp/data
root@db21ed7f-qbittorrent:/# mount -t cifs -o username=milenco,password=somepassword //10.0.0.100/Data/Data /tmp/data
root@db21ed7f-qbittorrent:/# exit
root@minos:~# mkdir /tmp/data
root@minos:~# mount -t cifs -o username=milenco,password=somepassword //10.0.0.100/Data/Data /tmp/data
root@minos:~# mount|grep 10.0.0.100
//10.0.0.100/Data/Data on /tmp/data type cifs (rw,relatime,vers=default,cache=strict,username=milenco,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1)
root@db21ed7f-qbittorrent:/# ls -alF /tmp/data/
total 8
drwxr-xr-x 2 root root 4096 Apr 22 22:30 ./
drwxrwxrwt 1 root root 4096 Apr 22 22:30 ../
I could setup something like that but I rather have it working natively, since I’m currently using the qbittorrent docker container outside Home Assistant/supervisor. I would prefer your plugin to work natively so I can back it up using supervisor and play around with the build in VPN options, which also seems very nice.
Thanks again, hoping you can help!
Edit: I don’t see any supervisor logs for this addon when starting it, just the ‘Starting Docker add-on’-message.
It appears VPN also needs the elevated permissions to function properly, I’m getting the following error now when trying to connect to my Private Internet Access account over OpenVPN:
Fri Apr 23 20:30:55 2021 WARNING: file '/etc/openvpn/credentials' is group or others accessible
Fri Apr 23 20:30:55 2021 OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Sep 5 2019
Fri Apr 23 20:30:55 2021 library versions: OpenSSL 1.1.1f 31 Mar 2020, LZO 2.10
Fri Apr 23 20:30:55 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Apr 23 20:30:55 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]212.102.35.92:1198
Fri Apr 23 20:30:55 2021 UDP link local: (not bound)
Fri Apr 23 20:30:55 2021 UDP link remote: [AF_INET]212.102.35.92:1198
Fri Apr 23 20:30:55 2021 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri Apr 23 20:30:55 2021 [amsterdam402] Peer Connection Initiated with [AF_INET]212.102.35.92:1198
Fri Apr 23 20:30:57 2021 OpenVPN ROUTE6: OpenVPN needs a gateway parameter for a --route-ipv6 option and no default was specified by either --route-ipv6-gateway or --ifconfig-ipv6 options
Fri Apr 23 20:30:57 2021 OpenVPN ROUTE: failed to parse/resolve route for host/network: 2000::/3
Fri Apr 23 20:30:57 2021 ERROR: Cannot ioctl TUNSETIFF tun: Operation not permitted (errno=1)
Fri Apr 23 20:30:57 2021 Exiting due to fatal error
Initially it wouldn’t start because was complaining about missing (and non-executable) up.sh and down.sh, but after creating these in the container I got the above error.
Hi @Milenco, thanks for the very detailed info! I didn’t have time to look at it today but had a few minutes now.
- Regarding openvpn
EDIT : working - I tested it with a free openvpn config
To allow it to function, you need to write the name of the openvpn config file in the option (I guess that’s what you did) and the addon will look for this file in “/config/openvpn/YOURFILE.ovpn”.
I created a -dev2 version :
- added +x to the up.sh file (error that you mentioned - the up.sh is generated if the 93-openvpn script executed correctly during launch)
- added info / error messages in the 93-openvpn script to write in the log if it executed ok or couldn’t find the config file
- added apparmor/config options to configure the tun device and allow openvpn to work
- Regarding smb failure
I need to investigate further as I don’t use this config. I see two possible ways for you :
- either you mount the smb share on your host machine in the homeassistant /share or /media folders (I have mounted them both in the addon)
- or you accept to spend a bit more time troubleshooting it using ssh. The good news is that as you have the same error code with ssh, we can use it to troubleshoot what is happening. I’ve looked a bit on internet and found many people having issues mounting smb shares from a mac.
– First thing : is your UID/GID set to 0/0 in the addon options? as I see that when mounting on host it appears in the cifs options and I suppose you are root on your mac
– Second thing : thanks very much for the info on successful mount on the host. Could you try to mount it using the same values, and some variations. And if it works, remove argument per argument until it fails… I’m sorry but this seems the quickest way to troubleshoot… As it could either be an issue with the version of smb, or a permission issue. The first one is the least useful as “default” could hide a lot of smb values… A faster way of find the smb version would be with “smbutil statshares -a”
# test full
mount -v -t cifs -o rw,relatime,vers=default,cache=strict,username=milenco,password=PASSWORD,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1 //10.0.0.100/Data/Data /tmp/data
# test smbv1
mount -v -t cifs -o rw,relatime,vers=1.0,cache=strict,username=milenco,password=PASSWORD,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1 //10.0.0.100/Data/Data /tmp/data
#test smbv3
mount -v -t cifs -o rw,relatime,vers=3.0,cache=strict,username=milenco,password=PASSWORD,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1 //10.0.0.100/Data/Data /tmp/data
# test security
mount -v -t cifs -o username=milenco,password=PASSWORD,sec=ntlmv2 //10.0.0.100/Data/Data /tmp/data
# test domain
mount -v -t cifs -o username=milenco,password=PASSWORD,domain=YOURDOMAIN //10.0.0.100/Data/Data /tmp/data
New feature as of version -ls128
Optional openvpn support
You need to add your ovpn config file in the folder /config/openvpn/, then modify 4 addon options. Openvpn creates a Tun network interface. The script configures qbittorrent to use Tun as interface instead as the default (like eth0). Debug messages in the addon log should show if there is an issue with OpenVPN initialization (such as ovpn config file not found)
openvpn_enabled: true/false # openvpn required to start qbittorrent
openvpn_config: For example "config.ovpn" # name of the file located in /config/openvpn.
openvpn_username: USERNAME
openvpn_password: YOURPASSWORD
Automatic smb version selection
Smbv1 flag depreciated. The script will try all smb versions automatically until it succeeds, then write the correct version in the addon log.
A new option allows to set a cifs domain if needed.
Thanks again for your help! I’ve tried your new version and good news, the VPN from Private Internet Access is now working! I had to change the config filename from “pia” to “pia.ovpn” but then it worked.
As for SMB: I have a external drive connected to my Home Assistant host, which is mounted to /mnt/data (and therefor inaccessible by addons). I could mount the drive to /usr/share/hassio/media instead and have it available for all addons but I rather keep it seperated and manually mount it via Samba for those addons that need it (and this is the only one so far).
I’ve tried your different approaches for mounting and this is my full log now:
[fix-attrs.d] done.
_ ()
| | ___ _ __
| | / __| | | / \
| | \__ \ | | | () |
|_| |___/ |_| \__/
GID/UID
User uid: 0
User gid: 0
[cont-init.d] 30-config: executing...
chown: cannot access '/config/data/qBittorrent': No such file or directory
[cont-init.d] 30-config: exited 0.
[cont-init.d] 30-nginx.sh: executing...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0
0 0 0 0 0 0 0 0 --:--:-- 0:00:02 --:--:-- 0
100 622 100 622 0 0 280 0 0:00:02 0:00:02 --:--:-- 280
43 3321k 43 1444k 0 0 459k 0 0:00:07 0:00:03 0:00:04 459k
100 3321k 100 3321k 0 0 918k 0 0:00:03 0:00:03 --:--:-- 3994k
[cont-init.d] 30-nginx.sh: exited 0.
[cont-init.d] 91-configuration.sh: executing...
[10:16:33] INFO: Downloads can be found in /mnt/Data
[10:16:33] INFO: Whitelisted subsets will not require a password : localhost,127.0.0.1,172.30.0.0/16,10.0.0.0/16
[10:16:33] INFO: WEBUI username set to admin
[10:16:33] INFO: Default username/password : admin/adminadmin
[10:16:33] INFO: Configuration can be found in /config/qBittorrent
[cont-init.d] 92-smb_mounts_v1.2.sh: executing...
[10:16:34] INFO: Mounting smb share(s)...
/var/run/s6/etc/cont-init.d/92-smb_mounts_v1.2.sh: line 70: bashio::log.critical: command not found
[cont-init.d] 92-smb_mounts_v1.2.sh: exited 127.
[cont-init.d] 93-openvpn.sh: executing...
[10:16:34] INFO: Configuring openvpn
[10:16:34] INFO: openvpn correctly set, please modify manually qbittorrent options to select it
sed: -e expression #1, char 66: unknown option to `s'
[cont-init.d] 93-openvpn.sh: exited 1.
[cont-init.d] 99-custom-scripts: executing...
[cont-init.d] 99-custom-scripts: exited 0.
[cont-init.d] done.
[services.d] done.
Mon Apr 26 10:16:34 2021 WARNING: file '/etc/openvpn/credentials' is group or others accessible
Mon Apr 26 10:16:34 2021 OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Sep 5 2019
Mon Apr 26 10:16:34 2021 library versions: OpenSSL 1.1.1f 31 Mar 2020, LZO 2.10
Mon Apr 26 10:16:34 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mon Apr 26 10:16:36 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]143.244.41.31:1198
Mon Apr 26 10:16:36 2021 UDP link local: (not bound)
Mon Apr 26 10:16:36 2021 UDP link remote: [AF_INET]143.244.41.31:1198
Mon Apr 26 10:16:36 2021 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Mon Apr 26 10:16:37 2021 [amsterdam420] Peer Connection Initiated with [AF_INET]143.244.41.31:1198
Mon Apr 26 10:16:38 2021 OpenVPN ROUTE6: OpenVPN needs a gateway parameter for a --route-ipv6 option and no default was specified by either --route-ipv6-gateway or --ifconfig-ipv6 options
Mon Apr 26 10:16:38 2021 OpenVPN ROUTE: failed to parse/resolve route for host/network: 2000::/3
Mon Apr 26 10:16:38 2021 TUN/TAP device tun0 opened
Mon Apr 26 10:16:38 2021 /sbin/ip link set dev tun0 up mtu 1500
Mon Apr 26 10:16:38 2021 /sbin/ip addr add dev tun0 10.30.112.76/24 broadcast 10.30.112.255
Mon Apr 26 10:16:38 2021 /etc/openvpn/up.sh tun0 1500 1553 10.30.112.76 255.255.255.0 init
[10:16:38] INFO: Starting NGinx...
Notice the warning about ‘/etc/openvpn/credentials’ and the ‘sed’ expression that failed about OpenVPN. It still works though. This is the config I use: https://www.privateinternetaccess.com/openvpn/openvpn.zip (I use the Netherlands config).
I believe Samba not mounting is a security measure from Docker which can only be properly circumvented by running the container in privileged mode. I tried to mount the several commands directly from the host (so not in the container), and they all ran succesfully:
root@minos:/tmp# # test full
root@minos:/tmp# umount /tmp/data
root@minos:/tmp# mount -v -t cifs -o rw,relatime,vers=default,cache=strict,username=milenco,password=somepassword,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1 //10.0.0.100/Data/Data /tmp/data
mount: //10.0.0.100/Data/Data mounted on /tmp/data.
root@minos:/tmp# mount|grep /tmp/data|grep 10.0.0.100
root@minos:/tmp# # test smbv1
root@minos:/tmp# mount -v -t cifs -o rw,relatime,vers=1.0,cache=strict,username=milenco,password=somepassword,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1 //10.0.0.100/Data/Data /tmp/data
//10.0.0.100/Data/Data on /tmp/data type cifs (rw,relatime,vers=1.0,cache=strict,username=milenco,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=131007,echo_interval=60,actimeo=1)
root@minos:/tmp# #test smbv3
root@minos:/tmp# mount -v -t cifs -o rw,relatime,vers=3.0,cache=strict,username=milenco,password=somepassword,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1 //10.0.0.100/Data/Data /tmp/data
//10.0.0.100/Data/Data on /tmp/data type cifs (rw,relatime,vers=3.0,cache=strict,username=milenco,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1)
root@minos:/tmp# # test security
root@minos:/tmp# mount -v -t cifs -o username=milenco,password=somepassword,sec=ntlmv2 //10.0.0.100/Data/Data /tmp/data
//10.0.0.100/Data/Data on /tmp/data type cifs (rw,relatime,vers=default,sec=ntlmv2,cache=strict,username=milenco,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1)
root@minos:/tmp# # test domain
root@minos:/tmp# mount -v -t cifs -o username=milenco,password=somepassword,domain=WORKGROUP //10.0.0.100/Data/Data /tmp/data
//10.0.0.100/Data/Data on /tmp/data type cifs (rw,relatime,vers=default,cache=strict,username=milenco,domain=WORKGROUP,uid=0,noforceuid,gid=0,noforcegid,addr=10.0.0.100,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,rsize=1048576,wsize=1048576,echo_interval=60,actimeo=1)
New feature : openvpn addition
Starting from version *ls129-ov2, the addon supports optional OpenVPN - and this time it works!
Thanks very much to @Milenco for helping troubleshoot and allowing local webUI in tunnelled mode!
To enable it, you need to add your ovpn config file in the folder /config/openvpn/, then modify the 4 addon options below.
openvpn_config: For example “config.ovpn” # name of the file located in /config/openvpn.
We (@alexbelgium annd myself) did some troubleshooting together to get both VPN and Samba working properly. VPN now seems to work properly (at least, using Private Internet Access). We had to add some route manually to private networks, so we can still access the WebUI outside of Home Assistant (otherwise it would only work in the sidepanel).
We are still having troubles mounting Samba drives. It could be my setup (I’m using supervised Home Assistant) that gives the permission denied errors, but it could be something with the addon as well. Are there other persons using this addon with Samba without issues? I got it fixed myself by mounting my USB to another folder so the addon has access through HA’s share-folder, but I’d still like to have the issue resolved for others. At least, if there are people with issues using Samba together with this addon…
Many thanks for @alexbelgium for building this addon
New feature : custom DNS setting
Starting from version *ls132, the addon supports optional setting of specific DNS. By default, they are set to 8.8.8.8 (google) and 1.1.1.1 (cloudflare).
Why : The objective is to avoid using the router’s default DNS in case you have enabled a DNS ad-blocker like adguard home or pihole. Although the DNS is only used for the initial connection and not during downloads, I noticed that the high levels of connection increased by 3x the adguard home response time (+ cpu usage).
How : to enable it, don’t change anything (it is by default). If you want to use your own custom DNS, just add the IP address in the option box, separated by commas. If you still want to use the router’s default DNS, just keep it blank.
“DNS_server”: “8.8.8.8,1.1.1.1” # Keep blank to use router’s DNS, or set custom DNS to avoid spamming in case of local DNS ad-remover
Updated feature : smb mount
A script was established with @Milenco (thanks very much!) that tests iteratively until it works many common options for mounting of smb shares (different smb & security protocols, forcing ID…). This should allow eaiser mounting for most people.
