Home Assistant and Proxmox 7.3 - web UI no longer accessible on 8123?
I have a Home Assistant instance, running as a VM on Proxmox.
Background:
  • Around 1-2 days ago, I tried upgrading the Home Assistant Supervisor via the web UI - the update didn’t seem to take - it either hung, or silently failed.
  • Just now, I upgraded the hypervisor from Proxmox 7.2 to 7.3 - and then restarted that node.
  • The Home Assistant VM is configured to boot automatically on Proxmox startup.
Anyhow, after the Proxmox node restarted, the HA VM did start up, seemingly successfully.
However, I can’t seem to access the HA web UI on the normal port (8123) - it simply says connection refused.
(To be clear, I’m not sure if the Proxmox update itself caused this, or if it was simply the reboot of the VM).
I did check port 4357, and it seems to be healthy from there:
I then connected to the VM console, and logged in as “root” (no password, which I believe is the default?):
This is the output of ha resolution info:
# ha resolution info
checks:
- enabled: true
  slug: backups
- enabled: true
  slug: dns_server_ipv6
- enabled: true
  slug: addon_pwned
- enabled: true
  slug: free_space
- enabled: true
  slug: network_interface_ipv4
- enabled: true
  slug: dns_server
- enabled: true
  slug: supervisor_trust
- enabled: true
  slug: core_security
issues: []
suggestions: []
unhealthy: []
unsupported: []
This is the output of ha core logs:
# ha core logs
2022-12-06 13:51:47.205 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 13:52:47.206 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 13:53:47.207 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 13:55:47.209 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 13:56:47.210 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 13:57:47.212 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 13:58:47.212 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 13:59:47.215 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 14:00:47.214 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 14:11:47.224 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 14:15:47.227 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 14:20:47.231 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-06 18:05:19.266 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-06 18:06:19.271 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-06 18:07:19.269 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-06 18:08:19.271 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-06 18:09:19.273 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-06 20:26:54.003 ERROR (MainThread) [homeassistant.components.shelly] Error fetching shellydimmer2-84CCA8AE5CAC data: Error fetching data: DeviceConnectionError()
2022-12-06 20:26:54.013 ERROR (MainThread) [homeassistant.components.shelly] Error fetching shellydimmer2-84CCA8AE2077 data: Error fetching data: DeviceConnectionError()
2022-12-06 21:13:00.003 ERROR (MainThread) [homeassistant.components.shelly] Error fetching shellydimmer2-84CCA8AE2077 data: Error fetching data: DeviceConnectionError()
2022-12-06 21:13:00.006 ERROR (MainThread) [homeassistant.components.shelly] Error fetching shellydimmer2-84CCA8AE5CAC data: Error fetching data: DeviceConnectionError()
2022-12-07 00:14:49.973 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 00:15:49.975 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 00:16:49.976 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 00:17:49.978 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 00:18:49.979 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 08:13:48.246 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-07 08:14:48.248 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-07 08:16:48.249 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-07 08:18:48.252 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-07 08:19:48.252 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-07 08:20:48.253 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-07 08:23:48.255 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-07 08:25:48.255 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.master_bedroom is taking over 10 seconds
2022-12-07 13:31:21.707 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 13:44:21.733 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 13:46:21.733 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 13:47:21.737 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 13:48:21.739 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 13:54:21.750 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 15:31:52.307 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.living_room is taking over 10 seconds
2022-12-07 17:45:52.424 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.living_room is taking over 10 seconds
2022-12-07 18:16:52.270 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:17:52.272 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:18:52.274 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:19:52.276 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:20:52.277 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:34:22.310 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:35:22.311 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:36:22.313 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:39:22.320 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:40:22.321 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 18:41:22.327 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.master_bedroom_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 21:30:56.226 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.living_room_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 22:52:56.384 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.living_room_measured_cumulative_power_consumption is taking over 10 seconds
2022-12-07 23:45:10.187 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/update request Server disconnected
2022-12-07 23:45:10.280 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall update.install (c:01GKH2TYB70NT2FT5CWRVH9MC6): entity_id=['update.home_assistant_supervisor_update'], backup=False>
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 258, in async_install
    await async_update_supervisor(self.hass)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 42, in _wrapper
    data = await funct(*argv, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 399, in async_update_supervisor
    return await hassio.send_command(command, timeout=None)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 276, in send_command
    raise HassioAPIError()
homeassistant.components.hassio.handler.HassioAPIError
  File "/usr/src/homeassistant/homeassistant/core.py", line 1762, in catch_exceptions
    await coro_or_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1781, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 208, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 943, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 154, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 413, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 260, in async_install
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor:
s6-rc: info: service legacy-services: stopping
[12:45:18] INFO: Home Assistant Core finish process exit code 0
[12:45:18] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
This is the output of ha supervisor logs:
# ha supervisor logs
22-12-08 04:47:45 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-12-08 04:47:45 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
22-12-08 04:47:45 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0
22-12-08 04:47:45 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-12-08 04:47:45 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
22-12-08 04:47:45 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0 - 172.30.32.5
22-12-08 04:47:45 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
22-12-08 04:47:45 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-12-08 04:47:45 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_dns application
22-12-08 04:47:46 INFO (SyncWorker_1) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1 - 172.30.32.3
22-12-08 04:47:46 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-12-08 04:47:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
22-12-08 04:47:46 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-12-08 04:47:46 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
22-12-08 04:47:47 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0 - 172.30.32.4
22-12-08 04:47:47 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2022.10.0
22-12-08 04:47:47 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
22-12-08 04:47:47 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-12-08 04:47:47 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning hassio_multicast application
22-12-08 04:47:47 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0 - Host
22-12-08 04:47:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/beta.json
22-12-08 04:47:49 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
22-12-08 04:47:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2022.11.2
22-12-08 04:47:49 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.3 / BootSlot B
22-12-08 04:47:49 WARNING (SyncWorker_1) [supervisor.store.data] Can't read /data/addons/core/matter_server/config.yaml: Service matter not found @ data['discovery'][0]. Got 'matter'
22-12-08 04:47:50 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-12-08 04:47:50 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
22-12-08 04:47:50 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-12-08 04:47:50 WARNING (SyncWorker_3) [supervisor.store.data] Can't read /data/addons/core/matter_server/config.yaml: Service matter not found @ data['discovery'][0]. Got 'matter'
22-12-08 04:47:50 INFO (MainThread) [supervisor.store] Loading add-ons from store: 67 all - 67 new - 0 remove
22-12-08 04:47:50 INFO (MainThread) [supervisor.addons] Found 2 installed add-ons
22-12-08 04:47:50 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.4.2
22-12-08 04:47:50 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-ssh with version 9.6.1
22-12-08 04:47:50 INFO (MainThread) [supervisor.backups.manager] Found 77 backup files
22-12-08 04:47:50 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-12-08 04:47:50 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-12-08 04:47:50 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-12-08 04:47:50 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-12-08 04:47:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-12-08 04:47:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-12-08 04:47:50 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-12-08 04:47:50 INFO (MainThread) [__main__] Running Supervisor
TypeError: Expected unicode, got RaucState
Exception ignored in: 'dbus_fast._private.marshaller.Marshaller._write_single'
  File "/usr/local/lib/python3.10/site-packages/dbus_fast/aio/message_bus.py", line 103, in buffer_message
    msg._marshall(self.negotiate_unix_fd),
22-12-08 04:47:50 ERROR (MainThread) [supervisor.jobs] Unhandled exception:
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 154, in wrapper
    return await self._method(*args, **kwargs)
  File "/usr/src/supervisor/supervisor/os/manager.py", line 232, in mark_healthy
    response = await self.sys_dbus.rauc.mark(RaucState.GOOD, "booted")
  File "/usr/src/supervisor/supervisor/dbus/rauc.py", line 98, in mark
    return await self.dbus.Installer.call_mark(state, slot_identifier)
  File "/usr/src/supervisor/supervisor/utils/dbus.py", line 100, in call_dbus
    return await getattr(proxy_interface, method)(
  File "/usr/local/lib/python3.10/site-packages/dbus_fast/aio/proxy_object.py", line 90, in method_fn
    msg = await self.bus.call(
  File "/usr/local/lib/python3.10/site-packages/dbus_fast/aio/message_bus.py", line 370, in call
    await future
  File "src/dbus_fast/aio/message_reader.py", line 24, in dbus_fast.aio.message_reader.build_message_reader._message_reader
  File "src/dbus_fast/_private/unmarshaller.py", line 641, in dbus_fast._private.unmarshaller.Unmarshaller._unmarshall
  File "src/dbus_fast/_private/unmarshaller.py", line 524, in dbus_fast._private.unmarshaller.Unmarshaller._read_header
  File "src/dbus_fast/_private/unmarshaller.py", line 276, in dbus_fast._private.unmarshaller.Unmarshaller._read_to_pos
EOFError
22-12-08 04:47:50 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-204' coro=<Core.start() done, defined at /usr/src/supervisor/supervisor/core.py:171> exception=JobException()>
    await future
EOFError
  File "/usr/src/supervisor/supervisor/core.py", line 184, in start
    await self.sys_os.mark_healthy()
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 160, in wrapper
    raise JobException() from err
supervisor.exceptions.JobException
22-12-08 05:02:47 INFO (SyncWorker_4) [supervisor.docker.manager] Runing command 'python3 -m homeassistant -c /config --script check_config' on ghcr.io/home-assistant/qemux86-64-homeassistant
22-12-08 05:04:09 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant config is valid
Does anybody have any idea what is going on, or why HA is “healthy”, but I can’t access the web UI anymore?
Thanks,
Victor
Just a quick update here.
I wasn’t able to SSH to my HomeAssistant instance - even though I had the SSH plugin enabled. (I assume this is because whatever broke HomeAssistant, also meant the SSH plugin didn’t run properly?).
Which means I can’t do things like try to SCP over snapshot/backup files - scary!
I should probably look at how to do automatic remote backups with HomeAssistant etc.
Anyhow, I found this other post on the forums:
which referenced another post:
This had the instructions to fix my issue - namely:
curl -o - https://version.home-assistant.io/update-supervisor.txt | sh
After I ran this, it seemed to pull some new Docker containers, which updated my HomeAssistant supervisor - and then I was able to connect to the HomeAssistant web UI again (port 8123).
