Ok, but nothing changes, I couldn’t select any camera in the last drop down selection.
I’m unable to scroll on my phone to cameras off the screen, anyone else have this issue?
Yep, I discovered that issue yesterday…
Release v0.5.6
This is a general maintenance release.
Changes
- Updates jinja2 to v2.10.3 (#53)
- Updates pillow to v6.2.1 (#55)
- Upgrades add-on base image to v5.0.2
- Removes unneeded access to config folder
- Upgrades curl to 7.66.0-r0
- Upgrades nginx to 1.16.1-r1
- Updates six to v1.13.0 (#59)
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work: https://patreon.com/frenck
I have a hard drive dedicated to my camera recordings. What is the prefered way to add this volume to the motioneye addon? Do I need to do it as a network share? Or is it possible to specify a volume in the config options? I also do not mind mounting it to the main homeassistant container if that is accessible to motioneye since I am assuming that would make it easier to incorporate the videos into lovelace (eg. a page for the last 5 motion events on each camera).
My Pi3 B+ is getting fried with motioneye running as a HASSIO add-on, so installed Motioneye on Ubuntu in a virtualbox on a WIN10 machine on the same network as my HASSIO Pi. Is there any way to integrate that new Motioneye instance into HASSIO “as if” it were an add-on?
Have look here…there is my webhook used in motioneye and node-red
Any news to this?
Great help!
Update: please ignore I found the link you referenced earlier
Hi Carlo,
Would you mind elaborating a little on how you fixed the issue with your reolink cameras in motioneye. I just installed 2 of the 420 POE cameras and it is really making my CPU work hard just from streaming. I have turned off video recording and the CPU is going to 100%. I used the standard rtsp link to set it up.
These are the 5mp versions but I have selected 1920x1080. Any tips would be welcomed.
Cheers
Can anybody tell me if it’s possible to have the motion detection get turned on when I enable my alarm?
I did find something about enabling motion_webcontrol
and then use something like wget -O- "http://192.168.1.14:7999/1/detection/start" >/dev/null
to start it, but when I enable motion_webcontrol
, I can’t reach any webserver on port 7999.
Hi
I have same problem
you success??
I’m afraid not
Does someone success connect esp32 cam to motionEye ?
I used ESPHOME addon.
this my code :
substitutions:
# Modify variables based on your settings
hostname: 'camesp'
ssid: '123'
password: '123'
esphome:
platform: ESP32
board: esp32dev
wifi:
ssid: $ssid
password: $password
fast_connect: True
api:
reboot_timeout: 0s
ota:
logger:
# ESP32-CAM
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
Try something like this as stream URL:
http://<my_ha_server>/api/camera_proxy_stream/camera.<my_esphome_device_name>?token=<my_ha_token_for_the_device>
In addition
The Api key its always changing
Why it’s happen?
You can use arduino Camera Example code with motionEye, it works perfect for me.
I do it to
When it’s on MotionEye
I cant add the camera at the HA dashboard
It’s or Motioneye or HA dashboard
I want see the camera in HA + Motioneye
