Home Assistant Community Add-on: motionEye
Hi caroline,
Can you please explain how?
regards
Hans
I run Hassos 5.6 on a Rasp 4 with ssd.
Can anyone help, I canā€™t find the configuration path, I only see /share/motioneye, but no files, only empty dirs (Camer1, Camera2, etc.). I need to restore my configuration but donā€™t know how.
Please check : Xiaomi Camera model no MJSXJ02CM Integration
I explained how i hack the camera :slight_smile:
I noticed today that my motion eye general settings dropdown is missing. Checking the log file no issues seem to show up and i have reset the addon with no changes. Here is what i am seeing. How can i get the general settings back to add more cameras.
Iā€™m not that familiar with it but what your seeing is what I get on the mobile platform. I assuming your looking on a PC/Mac?
The screenshot circled in red is the general settings I am needing to re-appear to make changes from my computer. I am unsure why it would be gone. My currently configured cameras still work.
I have a camera with a different resolution, which MotionEye does not recognize. It is only on the gray screen, and after about 10 seconds, it recharges all cameras. The camera resolution is: 2304x1296 or 640x352.
I have other cameras of the same brand and that use the same URL (with another IP), but with standard resolutions and I have no problems.
In VLC and BlueIris these resolutions normally work.
My installation is via HA add-on.
Does anyone know how to solve?
Could it be because you are not logged in as admin?
Thank you Frits!. In logged out and then back in as Admin and all settings were back. Not sure how that would have changed but definitely did not think to check if the account was logged in as admin.
Hello team,
i have Motion Eye working in Hassio. Now i have 2 surroundings. One Motion EYe outside hassio. THere works an camera. But when i do the same in the motion eye in Hassio, it gives me the error: **Unable to open video device **
Has anyone an idea?
Any more info you are able to give? What is the connection method? An IP cam? A USB device?
Hi guys. Can anybody give me an advice about blank page?
Iā€™m using supervised HA, kubuntu 18 with regular docker.
As I can see itā€™s container started in host network, and probably with 80 port for web ui. Maybe thatā€™s the problem? Iā€™m pretty sure that 80 port is busy on my host machine.
What are you seeing for configuration settings and the log file? Below are settings for me that are working.
I see the same config. I tried ssl enable \ disable - doesnā€™t help
What version of Motioneye are you running and can you post the log file that is generated when motion eye starts? Im not sure how you would tell port 80 is busy as no ports were changed on my network to get this functioning.
You didnā€™t specified what the OS you using. I think it depends.
 Add-on: motionEye
 Simple, elegant and feature-rich CCTV/NVR for your cameras
 Add-on version: 0.10.2
 You are running the latest version of this add-on.
 System: Ubuntu 20.04.1 LTS  (amd64 / qemux86-64)
 Home Assistant Core: 2020.12.1
 Home Assistant Supervisor: 2020.12.7
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] motioneye.sh: executing...
backing up /data/motioneye/motioneye.conf
[18:11:52] INFO: Enabling motion webcontrol...
[18:11:52] WARNING: This opens up an UNSECURE port to the outside world!
[18:11:52] WARNING: This port has NO SSL & NO AUTHENICATION!
[18:11:52] WARNING: YOU HAVE BEEN WARNED!
[cont-init.d] motioneye.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[18:11:54] INFO: Starting motionEye...
    INFO: hello! this is motionEye server 0.42.1
    INFO: cleanup started
    INFO: wsswitch started
    INFO: tasks started
    INFO: mjpg client garbage collector started
    INFO: smb mounts started
    INFO: server started
[18:11:58] INFO: Starting NGinx...
Hi, did you find out if it is possible? I canā€™t make the onboard camera work on RPI 4. I get the ā€œUnable to start deviceā€ error using Pi Noir V2 camera.
there were some discussions above on how to access saved video and it looks like motionEye map there directories by default.
        "Mounts": [
                "Type": "bind",
                "Source": "/usr/share/hassio/addons/data/a0d7b954_motioneye",
                "Destination": "/data",
                "Mode": "rw",
                "RW": true,
                "Propagation": "rprivate"
                "Type": "bind",
                "Source": "/usr/share/hassio/ssl",
                "Destination": "/ssl",
                "Mode": "ro",
                "RW": false,
                "Type": "bind",
                "Source": "/usr/share/hassio/share",
                "Destination": "/share",
                "Mode": "rw",
                "RW": true,
                "Type": "bind",
                "Source": "/usr/share/hassio/media",
                "Destination": "/media",
                "Mode": "rw",
                "RW": true,
If motionEye to work as NVR then we will need a dedicated drive (say 2TB drive) to store the videos. But the problem is that, all the predefined mapped directories are pointing to /usr/share/hassio/* and we should have larger volume for /usr/share in order it to work. I couldnā€™t find a workaround as softlinks doesnā€™t work with docker.
As I dig further, it looks like config.json file defined all the mapped directories and if itā€™s possible for us to map these during container startup time in the Supervisor then we can map our own volume.
Is this possible. Any help on this subject highly appreciated.
Hi @frenck and @all,
Iā€™m trying to refine motion parameters on my setup. Reading through official documentation of MotionEye, I came to see this:
Use the -s (setup mode) command line option and/or the text_changes config file option to experiment to find the right threshold value. If you do not get small movements detected (see the mouse on the kitchen floor) lower the value. If motion detects too many birds or moving trees, increase the number. (Unless of course you are one of the many many users who use Motion to bird watch!) Practical values would be from a few hundred to thousands.
Anybody knows how to run command line commands if motioneye has been installed as an add-on?
thanks!
Iā€™ve set up MotionEye to do what I set out to do, and it seems to be working well. My only ā€œissueā€ is that that I attempt to set up HA and itā€™s alarm system to run without constant interaction and monitoring. In order to do that I have error handling and warnings/alerts on possible issues. I can however not find a way to get an alert if a video feed fail. MotionEye has the data as it seems to throw error messages on top of video when video is failing. Examples: ā€œunable to open video deviceā€ or ā€œconnection to camera lostā€. This information doesnā€™t seem to be logged or available from HA? Can I retrieve it with a REST command or something similar? Perhaps configure MotionEye to trigger webhooks at error? Probably an obvious solution I missed somewhereā€¦? Added ping sensors for the cameras, but that only cover a fraction of possible issues.
(Iā€™ve been searching the web and scrolling through the last ~150 posts here without finding anything about error-handling.)
