Try Hassos Addon - Cloudflare Argo Tunnel
This allows exposing your HA instance under a domain (or subdomain) and to apply security (including 2FA).
Sadly there is no official addon, but hopefully, it will be added at some point
I played around with ZeroTier over night and was quite impressed with it.
My LAN IP range is 192.168.2.x
My brothers LAN IP range is 192.168.1.x
I installed ZeroTier on his Plex server (where Wireguard is also installed). and added him to the network. I installed ZeroTier on my Raspberry Pi (where Wireguard is installed) and added that to the network.
Then I made his assigned ZeroTier IP static, 10.241.x.1
And then I added a new route: 192.168.1.0/24 via 10.241.x.1
And sure enough now I can access anything on his LAN from my LAN (to do this with Wireguard, I would typically have to tell Wireguard to send ALL traffic over the VPN, meaning while connected I would lose access to my own network resources)
EDIT: There is a wee bit more work involved in making that work, but a chunk of it was already done when I set up Wireguard. There are some firewall rules that need to be added to the āexitā node.
So, Iām in need of some help hereā¦
I live in the Netherlands and I am trying to manage an HA install in the USA.
Iāve installed Zerotier on the HA instance in the USA and created an account on the ZeroTier webpage.
There, I created a new network and let the HA instance connect to it.
Iāve installed the Zerotier client on my Windows PC here in NL and let that client connect to the created Zerotier network.
When I type in the assigned Zerotier address from the HA instance in my browser in NL I can connect to the frontend of HA. So one might think it works!
However, when I try to FTP / SMB into the HA instance it refuses me to.
Tried a lot and even disabled my Windows Firewall without any luck.
Anyone who can help me on this case?
Can anyone give me a little guidance on how (or even if) I can send an HTTP POST webhook trigger to my HomeAssistant which is configured to be part of a ZeroTier network?
In the past, I could configure Port-forwarding in my router and with a DDNS service, I could trigger a HomeAssistant webhook Automation to run by sending an HTTP POST request (eg. something like http://myddns.com:8123/api/webhook/<webhook_id>)
However, my current ISP uses CGNAT so my home network is not allocated an external IP address on the internet, so Port Forwarding is useless to me. Iāve got the ZeroTier add-on working in my HomeAssistant and I can access it remotely using the ZeroTier network allocated local IP address from any client that also is part of my ZeroTier network, but I want to know if I can trigger a HomeAssistant webhook Automation using some sort of ZeroTier public URL for my configured ZeroTier network (if that makes sense?)
Basically, I want to run a HomeAssistant Automation from a device like Amazon Alexa by sending a webhook HTTP POST request via my ZeroTier network.
Is this possible?
Hi All, I have a question about routing between zeroteir and physical lan using HA.
I have several tasmota devices and some other devices with a web interface on my LAN, and would like to access them from my phone while away from home.
in the Zeroteir documentation there are instructions on how to setup a raspberry pi to do exactly this, however I donāt want to setup another device just to do this. https://zerotier.atlassian.net/wiki/spaces/SD/pages/224395274/Route+between+ZeroTier+and+Physical+Networks
Is there a way to add rules to iptables in HA? can it be done from the zerotier Addon config?
for those interestedā¦ i figured this out and it wasnāt to daunting. Iāve added step by step to the other thread
https://community.home-assistant.io/t/zerotier-one-bridging/132436/4
Hi all
so super wierd issue. I got zerotier
working well on the iPad (s) , iPhone etc.
for some weird reason on the Mac it just wonāt connect to Home assistant.
The Mac zerotier
app says its connected. and the web interface shows the Mac connected
but I cannot connect to my Home assistant not via the Mac app or the browserā¦again works perfectly on iOS
what am I missing here
thx
Z
My iphone has problems with zerotier over Wifi, but it works well over 4G. I suspect it has something to do with the ZT+Wifi+Apple combo, not with the zerotier HA-addon.
thx @nilux !
I tried with both wifi and 4/5Gā¦still cant connect
any other things I can try?
best
Z
My brain doesnāt compute with anything appleā¦ i remember trying to print some tickets from my wifes macbook once! i tried until she was ready to leave 3hrs laterā¦ she did it in 30seconds. i still dont understand why the print button for the word app is in the start menu for the whole computer
But anyway, I have had a few times where it just wont work, it shows connected but doesnāt allow network access, but disconnecting Zerotier and reconnecting seems to fix the problem.
is it just home assistant you cant access on the remote network? or can you not connect to any devices on the remote network?
Noticed my HA instance was inaccessible via ZeroTier, but the host was still showing as ONLINE on the ZeroTier website. I locked in the logs for the addon and it was JUST solid:
recv: Connection reset by peer
so I restarted and now I get:-
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] zerotier.sh: executing...
[10:20:40] INFO: ZeroTier node address: x
[10:20:43] INFO: Configuring network: x
[cont-init.d] zerotier.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[10:20:43] INFO: Starting ZeroTier One...
Hi all
Iāve installed and activated Zerotier as addon and installed client on an android phone and I can reach HA.
HA is installed as VM in Proxmox.
How is it possible to see also Proxmox (and all other VMs and LXCs) in that network using Zerotier?
I lost connection via ZeroTier since last week. The last time I was connecting was on Wednesday 08/03 - with no issue. Yesterday I tried with no success. On ZeroTier panel both nodes are online, but mobile app canāt connect. Today I spotted that in the meanwhile was update of this add-on. Any one has similar issue?
I restarted system several times, installed all system updates - no result. In the log there is nothing at all.
[18:34:10] INFO: Starting ZeroTier Oneā¦
s6-rc: info: service legacy-services successfully started
best
Andrzej
Iāve noticed the same behaviour. After update ( v. 0.16.1 ) the component keeps reporting
connect: Operation timed out
Restart seems to resolve the problem but after sono time it disconnect again
In my log appeared there after:
connect: Host is unreachable
I lost my zerotier connection on Archlinux after the latest upgrade (1.10.5), and had to downgrade to 1.10.4. Maybe itās related.
Both nodes was version 1.10.4, so it is not that case, probably.
At my side issue solved with next add-on update.
Thank you.
Hi all
This addon is the server or client side of Zerotier?
I tried setting up remote monitoring and operation of my HAOS using ZeroTier, by following this guide.
Everything went smoothly but I still cannot reach HA, i.e. no reply from the web browser.
Is there anyone who could get ZeroTier working with the latest HAOS?
Home Assistant Configuration:
- HAOS host: Ubuntu 22.04 amd64 running on a MacBookAir
- HA Core: 2024.8.2
- HA Supervisor: 2024.08.0
- Operating System: 13.1
- Frontend: 20240809.0
- ZeroTier One Addon: 0.18.0
- ZeroTier Client Version: 1.12.2
Phone Configuration:
- Phone: iPhone 13 128GB
- ZeroTier App: 1.14.0
- ZeroTier Client Version: 1.14.0
