Mine is working. Only difference to your setup is Android phone, not iphone.
@nickrout
Thanks for the feedback.
Edit 1
I think the problem is related to SSL certification. So I created a self signed certificate like shown in this post.
Then I tried to connect to ZeroTier with an Android phone and a Windows PC and both of them could access HA with just a certificate warning.
So the problem is with my iPhone. A quick google search unearthed many issues between iPhone, SSL and HA but I am still looking for a solution.
Edit 2
By reinstalling the ZeroTier App on my iPhone I could finally access HA while connected to my WiFi network.
However, I lost access as soon as I switched to Mobile internet.
I have same kind of problem, did you get it solved?
i have an android phone and everything work like it should, but my wifes iphone (SE20) works when it is on WIFI and local network, but when itâs connected on mobile network with Zerotier, HA companion app is barely working. it keeps on loading very very very long time and sometimes it will get connected to home assistant and some times it throw error about lovelace. When accessing through safari browser, everything works like should up to login screen, after login same thing like with companion app. I think HA version 2024.7.x was last whn companion app was working on iphone.
Here is a short caption from companion app log
2024-09-05 21:10:54.369 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 6)
2024-09-05 21:10:54.370 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 6)
2024-09-05 21:10:54.412 [Info] [main] [Environment.swift:54] init() > PromiseKit:cauterized-error: missingPerson
2024-09-05 21:10:54.607 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 6)
2024-09-05 21:10:54.618 [Info] [main] [Environment.swift:54] init() > PromiseKit:cauterized-error: missingPerson
2024-09-05 21:10:55.367 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 6)
2024-09-05 21:10:55.368 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 6)
2024-09-05 21:10:55.369 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 6)
2024-09-05 21:10:55.370 [Info] [hakit-work-queue] [Environment.swift:71] init() > WebSocket: Received: event: for HARequestIdentifier(rawValue: 6)
2024-09-05 21:10:55.410 [Info] [main] [Environment.swift:54] init() > PromiseKit:cauterized-error: missingPerson
2024-09-05 21:10:55.411 [Info] [main] [Environment.swift:54] init() > PromiseKit:cauterized-error: missingPerson
Hello. Just trying ZeroTier plugin on HA for the 1st time.
The plugin version is: 0.19.0
For the last few hours, I am trying to configure the plugin.
When I try to save the configuration, either in the GUI, or in YAML, i get the following:
Failed to save add-on configuration, does not match regular expression ^!secret [a-zA-Z0-9_-]+$|[0-9a-z]{16}. Got {ânetworksâ: [âXXXXXXXXXXXXâ], âapi_auth_tokenâ: â'}
(the XXXX is my network)
Can you please help?
change letters in XXXXXXXXXXXX to low xxxxxxxxxxxx.
That help me.
I encountered the same issue as @montechristos.
I added it in lowercase, as @irekfpl suggested, before removing the uppercase one. That did not work.
I then removed both and added the network in lowercase again and it worked.
Hoping it can help others.
Thanks.
Hello everyone. Iâm having a problem. After updating the add-on, my access to haos has stopped working properly. On the ZeroTire website, haos is visible as active and authorized, and my Android phone is also active and authorized, but I canât access haos from my phone. The log shows the following entry:
[14:44:53] INFO: Starting ZeroTier OneâŚ
Starting Control PlaneâŚ
Starting V6 Control PlaneâŚ
connect: Host is unreachable
What should I do? Help!
