Home Assistant Green Keeps Crashing
For the past couple of months my HA Green keeps crashing. It started out happening once every couple of weeks and now its happening every day. I havent made any major changes in this timeframe. I notice that I’m unable to load the UI via the app/webpage so I restart the HA Green and am able to connect. Here’s my log from today since I was able to access it this morning before it crashed:
2024-10-10 15:28:17.076 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration wyzeapi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:28:17.080 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bedjet which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:28:17.083 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration midea_dehumidifier_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:28:17.086 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:28:17.088 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:28:19.911 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-10-10 15:28:20.001 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=80 from 2024-10-10 19:24:42.966573)
2024-10-10 15:28:44.575 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0xffff8a0a8350>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) inside the event loop by custom integration 'smartthinq_sensors' at custom_components/smartthinq_sensors/wideq/core_async.py, line 149: context = ssl.create_default_context() (offender: /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose)), please create a bug report at https://github.com/ollo69/ha-smartthinq-sensors/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_default_certs
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
    return loop.run_until_complete(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
    self.run_forever()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
    self._run_once()
  File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
    handle._run()
  File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
    self._context.run(self._callback, *self._args)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 165, in async_setup_component
    result = await _async_setup_component(hass, domain, config)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 461, in _async_setup_component
    await asyncio.gather(
  File "/usr/src/homeassistant/homeassistant/setup.py", line 463, in <genexpr>
    create_eager_task(
  File "/usr/src/homeassistant/homeassistant/util/async_.py", line 45, in create_eager_task
    return Task(coro, loop=loop, name=name, eager_start=True)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 742, in async_setup_locked
    await self.async_setup(hass, integration=integration)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/smartthinq_sensors/__init__.py", line 269, in async_setup_entry
    client = await lge_auth.create_client_from_token(
  File "/config/custom_components/smartthinq_sensors/__init__.py", line 153, in create_client_from_token
    return await ClientAsync.from_token(
  File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 1597, in from_token
    gateway = await Gateway.discover(core)
  File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 750, in discover
    gw_info = await core.gateway_info()
  File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 456, in gateway_info
    result = await self.thinq2_get(V2_GATEWAY_URL)
  File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 338, in thinq2_get
    async with self._get_session().get(
  File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 223, in _get_session
    self._session = lg_client_session()
  File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 149, in lg_client_session
2024-10-10 15:28:44.731 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'bedjet' calls async_forward_entry_setup for integration, bedjet with title: BedJet and entry_id: 01J431E108NRMHTWEXFY69K93S, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/bedjet/__init__.py, line 7: hass.async_create_task(, please report it to the author of the 'bedjet' custom integration
2024-10-10 15:28:58.787 WARNING (MainThread) [homeassistant.components.rachio] 1 Rachio device(s) found; The url https://hooks.nabu.casa/gAAAAABmpmjhekd4nMD1Ww8i1bukJLH1CoVIOKbRbzlaVLhZNLf7A6RrBEQcEYx3RVTmXe6JKl-S8SnV1T2DCJ7weECRGM4UoY50q51o4uqGmdB2dOTESpS6sTeMApb9X608wUriBn-iqarPvIaJ4Wx2f925-KCq2xcL0WSHxQNsU15uypocf40= must be accessible from the internet in order to receive updates
2024-10-10 15:28:59.106 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
Stack (most recent call last):
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
  File "/usr/src/homeassistant/homeassistant/core.py", line 829, in async_create_task_internal
    task = create_eager_task(target, name=name, loop=self.loop)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2200, in async_forward_entry_setup
    report(
  File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 155, in report
    _LOGGER.warning(msg, stack_info=True)
2024-10-10 15:28:59.111 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:28:59.128 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:28:59.141 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:28:59.146 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:28:59.163 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:28:59.169 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:29:15.691 WARNING (MainThread) [homeassistant.components.fan] Entity None (<class 'custom_components.midea_dehumidifier_lan.fan.DehumidiferFan'>) does not set FanEntityFeature.TURN_OFF but implements the turn_off method. Please create a bug report at https://github.com/nbogojevic/homeassistant-midea-air-appliances-lan/issues
log continued:
2024-10-10 15:29:15.692 WARNING (MainThread) [homeassistant.components.fan] Entity None (<class 'custom_components.midea_dehumidifier_lan.fan.DehumidiferFan'>) does not set FanEntityFeature.TURN_ON but implements the turn_on method. Please create a bug report at https://github.com/nbogojevic/homeassistant-midea-air-appliances-lan/issues
2024-10-10 15:29:15.700 WARNING (MainThread) [homeassistant.components.fan] Entity None (<class 'custom_components.midea_dehumidifier_lan.fan.DehumidiferFan'>) does not set FanEntityFeature.TURN_OFF but implements the turn_off method. Please create a bug report at https://github.com/nbogojevic/homeassistant-midea-air-appliances-lan/issues
2024-10-10 15:29:15.700 WARNING (MainThread) [homeassistant.components.fan] Entity None (<class 'custom_components.midea_dehumidifier_lan.fan.DehumidiferFan'>) does not set FanEntityFeature.TURN_ON but implements the turn_on method. Please create a bug report at https://github.com/nbogojevic/homeassistant-midea-air-appliances-lan/issues
2024-10-10 15:29:15.945 WARNING (MainThread) [custom_components.bedjet.climate] No BedJet devices were discovered.
2024-10-10 15:29:16.094 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'smartthinq_sensors' registers an entity service with a non entity service schema which will stop working in HA Core 2025.9 at custom_components/smartthinq_sensors/humidifier.py, line 67: platform.async_register_entity_service(, please create a bug report at https://github.com/ollo69/ha-smartthinq-sensors/issues
2024-10-10 15:29:16.561 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2223, in async_forward_entry_setup
    _report_non_awaited_platform_forwards(entry, "async_forward_entry_setup")
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1192, in _report_non_awaited_platform_forwards
    report(
2024-10-10 15:29:16.580 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:29:16.584 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:29:16.590 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:29:16.602 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:29:18.085 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:29:18.426 WARNING (SyncWorker_5) [pybotvac.account] Your robot Floor Slut is offline.
2024-10-10 15:29:18.712 WARNING (SyncWorker_5) [pybotvac.account] Your robot Floor Slut is offline.
2024-10-10 15:29:19.043 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:29:23.090 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('zha', '01J3KQ15Y7JHS5BB5F26RXZC2W'): 211.073139145, ('bedjet', '01J431E108NRMHTWEXFY69K93S'): 243.093770691, ('homekit_controller', '01J2RB0YJK4QK3D92A4RTC3SM5'): 247.194150739, ('homekit_controller', '01J3QZS57GVG9MW3QKZ6A7F438'): 247.197179056, ('homekit_controller', '01J58KY7PP5W8C4QV6MPS1B031'): 247.201365311, ('homekit_controller', '01J58KZMYMX5F8XWBAK7KT2PT1'): 247.203116951}
2024-10-10 15:29:25.529 WARNING (MainThread) [zigpy.application] Zigbee channel 20 utilization is 76.47%!
2024-10-10 15:29:25.529 WARNING (MainThread) [zigpy.application] If you are having problems joining new devices, are missing sensor updates, or have issues keeping devices joined, ensure your coordinator is away from interference sources such as USB 3.0 devices, SSDs, WiFi routers, etc.
2024-10-10 15:29:27.291 WARNING (MainThread) [homeassistant.components.climate] Setup of climate platform bedjet is taking over 10 seconds.
2024-10-10 15:30:15.951 ERROR (MainThread) [homeassistant.components.climate] Setup of platform bedjet is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2024-10-10 15:30:15.954 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration bedjet with title: BedJet and entry_id: 01J431E108NRMHTWEXFY69K93S, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:30:50.246 ERROR (SyncWorker_4) [homeassistant] Error doing job: Task exception was never retrieved (None)
  File "/usr/src/homeassistant/homeassistant/components/assist_pipeline/__init__.py", line 134, in async_pipeline_from_audio_stream
    await pipeline_input.validate()
  File "/usr/src/homeassistant/homeassistant/components/assist_pipeline/pipeline.py", line 1445, in validate
    raise PipelineRunValidationError(
homeassistant.components.assist_pipeline.pipeline.PipelineRunValidationError: the pipeline does not support speech-to-text
2024-10-10 15:31:23.301 ERROR (MainThread) [pyhap.hap_handler] Roku Express 4K: Client ('192.168.1.37', 51653) with uuid ebfa8caf-95d0-4b08-be36-ecb66211d90b attempted pair verify without being paired first (public_key=083f302e2726146330c853da20df1a728ece59ae515dde7bb94bcd55af392e5b, paired clients={UUID('702dfe09-c2b2-48f1-a4e0-7318dbe8a0a2'): '645670eea8497ce66412d383354b5b1a7ef51b1cfaadb7f3134ae05e2a7e741e'}).
2024-10-10 15:31:23.306 ERROR (MainThread) [pyhap.hap_handler] Cleaning map: Client ('192.168.1.37', 51654) with uuid ebfa8caf-95d0-4b08-be36-ecb66211d90b attempted pair verify without being paired first (public_key=ae8d6e610b8c3d528278681d153a9fbf5177231f211ed5351da45d636206614f, paired clients={UUID('702dfe09-c2b2-48f1-a4e0-7318dbe8a0a2'): '645670eea8497ce66412d383354b5b1a7ef51b1cfaadb7f3134ae05e2a7e741e'}).
2024-10-10 15:33:31.122 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities input_datetime.first_alarm_example are missing or not currently available
Hi Connor,
Are you running AMP, Alexa Media Player? There is a very broken version out there that that group released…
PSA: Alexa Media Player v4.13.3 breaks all versions of Home Assistant - Configuration - Home Assistant Community.
Try to post the content of the homeassistant.log.1 file in your config library.
It is the log filefrom the previous run.
2024-10-10 15:24:40.199 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration wyzeapi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:24:40.203 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bedjet which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:24:40.206 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration midea_dehumidifier_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:24:40.209 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:24:40.212 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-10 15:24:43.060 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-10-10 15:24:43.148 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=79 from 2024-10-09 21:26:34.560753)
2024-10-10 15:24:54.952 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:24:55.004 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:24:55.015 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:24:55.026 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:24:55.047 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:24:55.056 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:24:55.061 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration, wyzeapi with title:  and entry_id: 01J43ZMV6TV47VD4QJM9YAZPAZ, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead. Please report this issue.
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    report(
2024-10-10 15:24:55.695 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0xffff5a19c0d0>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) inside the event loop by custom integration 'smartthinq_sensors' at custom_components/smartthinq_sensors/wideq/core_async.py, line 149: context = ssl.create_default_context() (offender: /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose)), please create a bug report at https://github.com/ollo69/ha-smartthinq-sensors/issues
    sys.exit(main())
    self.run_forever()
    self._run_once()
    handle._run()
    create_eager_task(
2024-10-10 15:24:59.402 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'bedjet' calls async_forward_entry_setup for integration, bedjet with title: BedJet and entry_id: 01J431E108NRMHTWEXFY69K93S, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/bedjet/__init__.py, line 7: hass.async_create_task(, please report it to the author of the 'bedjet' custom integration
2024-10-10 15:25:00.516 WARNING (MainThread) [homeassistant.components.rachio] 1 Rachio device(s) found; The url https://hooks.nabu.casa/gAAAAABmpmjhekd4nMD1Ww8i1bukJLH1CoVIOKbRbzlaVLhZNLf7A6RrBEQcEYx3RVTmXe6JKl-S8SnV1T2DCJ7weECRGM4UoY50q51o4uqGmdB2dOTESpS6sTeMApb9X608wUriBn-iqarPvIaJ4Wx2f925-KCq2xcL0WSHxQNsU15uypocf40= must be accessible from the internet in order to receive updates
No I’m not using AMP
It looks like SmartThings is crashing, but if it the cause or a symptom I do not know.
Try to disable the SmartThings integration and see if it helps.
