That is not correct. With a local OpenThread border router, you can commission through the Matter Server add-on Web UI.
This is not the preferred option, as the Companion app is preferred, but it is possible and it works, as long as you also have a compatible bluetooth controller.
When I look at that OpenThread page, the choices for āCommission new WiFi deviceā and āCommission new Thread deviceā are both greyed out. Iām guessing because I donāt have Bluetooth on my HA server.
Iām not sure what the situation on the Apple side is, but on Android the Home Assistant app seems to be using software from Google to handle the registration process. I bought a Thread/Matter device a while back to try out, and I thought it was communicating through my Skyconnect. But after a few weeks, I realized that it was actually communicating through my Google Hub. That confused me at first because the Google Hub shouldnāt have even been aware of the device registration. But I later realized it was the registration process was actually going through Google and it associated the Google Hub thread border router with my Google account.
The Home Assistant app on Android has got to get Google out of the picture. And I hope we can get some method of registering through a web browser. If thatās not possible because of Bluetooth then we need some kind of registration app that can be run from a laptop. Registering a device from the HA server could be an issue if the Matter device is far from the server and hardwired into the house.
Congratulationsā:love_you_gesture:![]()
Wish that could also commission Matter devices without companion apps by connecting a web camera to the computer running Home Assistant OS and scanning the device QR code that way.
Could such a feature with local native QR code scanning via HA OS be possible to add?
Congrats! A major milestone.
Congrats, and thanks for all the hard work to make this happen.
I have a HA Yellow and use the internal Zigbee device. As I understand the yellow is only in theory dual protocol.
What I donāt understand is if I add a Matter USB stick (is there such a thing?) to the Yellow Iāll be able to run Zigbee and Matter side-by-side.
Does the new certified add-on change anything in this regard?
Congratulations to the Home Assistant and the Resillion Team to archive this mammoth project.
Thatās really awesome! Well done!
Is is not the only shortcoming (contacting apple/google cloud and tell them about the existence of your device) ![]()
Matter certified devices seem to allow to put functions into a walled garden/ecosystem (for example only accessible via vendor hub/bridge/app/platform/cloud) and to expose only basic functions (like on/off) via matter ![]()
It was supposed to make things better but matter at this point does not allow full ownership and depending on the device only limited local control (after initally contacting apple/google cloud services) ![]()
Itās quite a joke the matter doesnāt seem to enforce basic/simple (vendors might brand it āspecialā) features (power on state/detaching/etc.) or even OTA updates to be available without vendor cloud/app/registration ![]()
MINI Dry Wi-Fi Smart Switch (Dry Contact Relay) | MINI-D - SONOFF Official
The matter server hasnāt been released since December: when can we expect this certified version to be released?
That version IS the certified version. If HA would update that version, it would need to re-certify.
Hence it has been developed as a separate add-on instead of being part of HA core. In that case, it would need to recertify every month with the HA core update
Itās good to see support for Matter, even though I have serious issues with the protocol. I plan to write about that in more detail. For now, the key point is that it is inscrutable in that there is no provenance in the sense that I canāt go from the identifier on the device to the Matter device. For now, I carefully update the label, and it sort of works.
Now, to the specific bug. Fortunately, the device info for this device show me
MAC address: c0:5d:89:43:0e:a4
IP address(es): 172.20.5.140
But at some point the IP address changed! I could only find it because I periodically scan all 2000 (OK, 2046) of my IP addresses and found:
172.20.5.141,c0:5d:89:43:0e:a4,,1314
but HA has not updated the information. The fact that Matter commands still work is that the protocol pays only lip service to standards. I plan to learn more about why. Itās a reminder of the dangers of allowing hardware engineers to design protocols to sell chips. But, again, a topic in its own right.
In the meantime, can Home Assistant maintain a mapping of the device to the IP address?
Closely related is the difficulty in finding the IP address using the IP ā it does not appear at all in core.device_registry.json.
I decided to ask Gemini for help in explaining why Mattter is so terrible. This is a raw transcript with an essay that the end. I plan to write real essay but you can read this temporary version in the menatime (on OneDrive) GeminiMatter.pdf
This pdf is missing half the text, especially on the right and between pages.
I donāt understand what you want to express here. Do you mean the IP listed on āDevice infoā in homeassistant is not updated when it changes? Do you want to say this is a general matter issue? All my matter devices have the correct IP information listed - so at least for me this is not happening.
From scanning this thread, is it best to assume keeping with Zigbee or Zwave or Tuya Wifi (which I already have all of these) is better than adding in a Matter network just to support a few Tapo power outlets?
