I had noted this on a separate thread, but my Raspbery Pi 3 Version B would not boot version 8.1. No green status light flashes, no video output. I reflashed version 8.0 and it booted. A reflashed 8.1, no boot. Reflashed 8.0 and it booted.
-Eric
-Eric
Now on 8.1 and the front usb-s on my NUC wont work anymore. I can only use the backside onesā¦ WHICH SUX! i now have 2 less usbs. And usb hubs wont work either
BOXNUC7I3BNH
x86 installation on a Dell Micro Optiplex.
After installing 8.1 initiating a reboot from HA the system wonāt boot, it just hangs.
Power down and eventually itāll boot after what seems an eternity.
Hopefully the next update sorts this otherwise Iāll have to go back a version or two as I seem to have lost the QNAP resource module now.
@JeromeO @zagnuts @smarthomelawyer @Insearchofth1ngs @vynsane @bobloadmire @Tuomas did you get your issues resolved?
Iām running fine on 8.0. Think Iāll try updating again during the weekend.
Yes, I stayed on Home Assistant OS 8.0 eventually and was able to flash my Conbee II stick on Windows to have it back up and running on HA.
Iām still not sure what caused the mess with my stick, the upgrade from HA OS 7.x to 8.0 and/or the update of the Deconz add-on that I triggered on the same day
Iām staying away from HA OS 8.1 for now, too scared to break something else
Home Assistant OS 8.1 64 bit fails to boot on CM4 with PCIE connected NVME drive.
Just a black screen and M.2 LED flashes.
32bit version boots ok.
i upgraded from I think 7.6 to 8.1 this morning. And now nothing works any more. I have x86 vim hosted with virt manager. For the initial installation I used the official container for Virt manager so I guess there is a real problem below this.
After a host restart HAOS came back. Now Iām super confused. Maybe the VM used an updated kernel module and I hadnāt restarted the host after updating that module.
I have a Odroid XU4. It looks like one of the USB ports have stopped working after upgrading to OS 8. I have upgraded tot 8.1 meanwhile, but unfortunately without success.
7.6 ā 8.1 upgraded fine for me on a RPI 8gb. Did two full hardware reboots to be safe
Upgrading to core-2022.6.4 fixed the issue. Interesting, because the release notes do not seem to mention anything relatedā¦
Coming back to this, I did have a day of teething problems but also updated 2022.5 ā 2022.6 the same day.
After several hard reboots and changing the default wifi reconnect tries it seems stable again
Still after 8.2 not loading zha using Sonoff Zigbee 3.0 USB Dongle.
ha os update --version 8.0
will do the job
Not that it helps you, but my son off ZigBee has worked on all 8.0 releases. Other issues but no issues with ZigBee. I can check firmware version when I get home if you want to compare.
Since update (last night) the integration London Underground no longer works
Regards,
M
Nevermind. Deactivated the zha-integration and activeted afterwards. And some host reboots laterā¦
It seems to work now
I had no problem whatsoever with version 8 until I updated to 8.2, after that my intel NUC (BKNUC8CCHKR2) would no longer boot. It couldnāt find anything to boot.
Long story short, used an old SSD with an USB adapter to live boot linux mint, copied my last backup elsewhere and then re-installed 8.2 from scratch (wrote the latest home assistant image to the on-board emmc) and restored the backup again. Although the whole thing was annoying and cost me a few hours, I was surprised to see how well the update restore works.
And the more I think about it, the issue must have been with the update/upgrade because otherwise the fresh 8.2 install wouldnāt have run eitherā¦
last night is not a version. Nor do you provide logs.
Just to give an update. Just upgraded to 8.2 and everything went smoothly!
this might be a more generic question, but running HAOS in dev nightlyās in a Virtual box, I have a perfect instance, which cant update however, because the partition (10GB) is fully used.
Donāt understand with what exactly, but it seems I need the resize that partition.
How can I proceed doing that? Didnt find any related option in the Instance itself, so take it is is an OS option?
thanks for having a look!
