Not yet using MQTT or automations first HA needs to be stable
Where in HA do you do this Service_call nowadays? i can not find it A few years ago there was an option for this in the left site
Left-hand side, Developer Tools > Services
Hi Frederik,
Was the Hass.io Package removed from Syno Community? I don’t find it! Have added Syno Community and also Beta releases are enabled.
Thanks & regards,
Carsten
It sometimes takes a LONG time for list of packages to update. Really long time.
Also, make sure you are trying to install it on device that supports Docker.
Hi Frederike,
First of all: thank you for this awesome package you’ve made.
Had some troubles lately with my hassio not responding anymore. Every phew hours it stops working…
Now I am gonna have a clean install. Gonne try step by step extra addons to research where the problem lies. Could be my synology that is starting to have some cpu problems… DS713+ running here
Now the new line up is about to release I’m going to purchase a new one.
Let’s hope they keep up the linux support, otherwise I fear we will have to start running it on a VM.
Kind greetings and once again: thanks!
Thank you. I have managed to install it manually
Runs well. Will now play a bit with the solution. First impression is really good. You guys have built a good solution with a nice UX
Cheers
Help!!!
Unable to load the panel source: /api/hassio/app/entrypoint.js
I have tried to do your magic trick (as described above) zillion times and it keeps given me the same message when I click on the supervisor tab within Home Assistant. I am using your package that I downloaded from Syn community. Having a Synology DSM 412+. Restarted DSM several times as well. Can you please help me , I am desperate!!
Thanks in advance!!
Can you please check status of Docker containers in Synology and try to see if you get anything in Supervisor log file?
Hi!
Thanks for coming back so quickly. The supervisor container goes on and of. Only home assistant and supervisor are running as container in the docker. the other containers do not run.
This is the log file from the supervisor container:
Can you help me please? Also I cannot connect to host via Home assistant cloud inside Home assistant page, I have Nabucasa trial subscription.
date | stream | content |
2020-05-18 08:33:44 | stdout | [s6-finish] sending all processes the KILL signal and exiting. |
2020-05-18 08:33:41 | stdout | [s6-finish] sending all processes the TERM signal. |
2020-05-18 08:33:40 | stdout | [s6-finish] waiting for services. |
2020-05-18 08:33:40 | stdout | [cont-finish.d] done. |
2020-05-18 08:33:40 | stdout | [cont-finish.d] executing container finish scripts… |
2020-05-18 08:33:38 | stdout | client_session: <aiohttp.client.ClientSession object at 0x7f714f4cc610>e[0m |
2020-05-18 08:33:38 | stdout | e[31m20-05-18 08:33:38 ERROR (MainThread) [asyncio] Unclosed client session |
2020-05-18 08:33:38 | stdout | client_session: <aiohttp.client.ClientSession object at 0x7f714f71a350>e[0m |
2020-05-18 08:33:38 | stdout | docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:33:38 | stdout | ‘Error while fetching server API version: {0}’.format(e) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 215, in _retrieve_server_version |
2020-05-18 08:33:38 | stdout | self._version = self._retrieve_server_version() |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 190, in init |
2020-05-18 08:33:38 | stdout | self.api = APIClient(*args, **kwargs) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/client.py”, line 40, in init |
2020-05-18 08:33:38 | stdout | base_url=“unix:/{}”.format(str(SOCKET_DOCKER)), version=“auto”, timeout=900 |
2020-05-18 08:33:38 | stdout | File “/usr/src/supervisor/supervisor/docker/init.py”, line 34, in init |
2020-05-18 08:33:38 | stdout | self._docker: DockerAPI = DockerAPI() |
2020-05-18 08:33:38 | stdout | File “/usr/src/supervisor/supervisor/coresys.py”, line 56, in init |
2020-05-18 08:33:38 | stdout | coresys = CoreSys() |
2020-05-18 08:33:38 | stdout | File “/usr/src/supervisor/supervisor/bootstrap.py”, line 50, in initialize_coresys |
2020-05-18 08:33:38 | stdout | File “uvloop/loop.pyx”, line 1456, in uvloop.loop.Loop.run_until_complete |
2020-05-18 08:33:38 | stdout | coresys = loop.run_until_complete(bootstrap.initialize_coresys()) |
2020-05-18 08:33:38 | stdout | File “/usr/src/supervisor/supervisor/main.py”, line 40, in |
2020-05-18 08:33:38 | stdout | exec(code, run_globals) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/runpy.py”, line 85, in _run_code |
2020-05-18 08:33:38 | stdout | “main”, mod_spec) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/runpy.py”, line 193, in _run_module_as_main |
2020-05-18 08:33:38 | stdout | Traceback (most recent call last): |
2020-05-18 08:33:38 | stdout | |
2020-05-18 08:33:38 | stdout | During handling of the above exception, another exception occurred: |
2020-05-18 08:33:38 | stdout | requests.exceptions.ConnectionError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:33:38 | stdout | raise ConnectionError(err, request=request) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 498, in send |
2020-05-18 08:33:38 | stdout | r = adapter.send(request, **kwargs) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 643, in send |
2020-05-18 08:33:38 | stdout | resp = self.send(prep, **send_kwargs) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 530, in request |
2020-05-18 08:33:38 | stdout | return self.request(‘GET’, url, **kwargs) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 543, in get |
2020-05-18 08:33:38 | stdout | return self.get(url, **self._set_request_timeout(kwargs)) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 230, in _get |
2020-05-18 08:33:38 | stdout | return f(self, *args, **kwargs) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/utils/decorators.py”, line 46, in inner |
2020-05-18 08:33:38 | stdout | return self._result(self._get(url), json=True) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/daemon.py”, line 181, in version |
2020-05-18 08:33:38 | stdout | return self.version(api_version=False)[“ApiVersion”] |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 207, in _retrieve_server_version |
2020-05-18 08:33:38 | stdout | urllib3.exceptions.ProtocolError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:33:38 | stdout | sock.connect(self.unix_socket) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/transport/unixconn.py”, line 43, in connect |
2020-05-18 08:33:38 | stdout | self.connect() |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 966, in send |
2020-05-18 08:33:38 | stdout | self.send(msg) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1026, in _send_output |
2020-05-18 08:33:38 | stdout | self._send_output(message_body, encode_chunked=encode_chunked) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1247, in endheaders |
2020-05-18 08:33:38 | stdout | self.endheaders(body, encode_chunked=encode_chunked) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1298, in _send_request |
2020-05-18 08:33:38 | stdout | self._send_request(method, url, body, headers, encode_chunked) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1252, in request |
2020-05-18 08:33:38 | stdout | conn.request(method, url, **httplib_request_kw) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 392, in _make_request |
2020-05-18 08:33:38 | stdout | chunked=chunked, |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 677, in urlopen |
2020-05-18 08:33:38 | stdout | raise value.with_traceback(tb) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py”, line 734, in reraise |
2020-05-18 08:33:38 | stdout | raise six.reraise(type(error), error, _stacktrace) |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 403, in increment |
2020-05-18 08:33:38 | stdout | method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2] |
2020-05-18 08:33:38 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 725, in urlopen |
2020-05-18 08:33:38 | stdout | timeout=timeout |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send |
2020-05-18 08:33:37 | stdout | Traceback (most recent call last): |
2020-05-18 08:33:37 | stdout | |
2020-05-18 08:33:37 | stdout | During handling of the above exception, another exception occurred: |
2020-05-18 08:33:37 | stdout | FileNotFoundError: [Errno 2] No such file or directory |
2020-05-18 08:33:37 | stdout | sock.connect(self.unix_socket) |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/transport/unixconn.py”, line 43, in connect |
2020-05-18 08:33:37 | stdout | self.connect() |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 966, in send |
2020-05-18 08:33:37 | stdout | self.send(msg) |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1026, in _send_output |
2020-05-18 08:33:37 | stdout | self._send_output(message_body, encode_chunked=encode_chunked) |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1247, in endheaders |
2020-05-18 08:33:37 | stdout | self.endheaders(body, encode_chunked=encode_chunked) |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1298, in _send_request |
2020-05-18 08:33:37 | stdout | self._send_request(method, url, body, headers, encode_chunked) |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1252, in request |
2020-05-18 08:33:37 | stdout | conn.request(method, url, **httplib_request_kw) |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 392, in _make_request |
2020-05-18 08:33:37 | stdout | chunked=chunked, |
2020-05-18 08:33:37 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 677, in urlopen |
2020-05-18 08:33:36 | stdout | e[32m20-05-18 08:33:36 INFO (MainThread) [main] Initialize Supervisor setupe[0m |
2020-05-18 08:33:36 | stdout | e[31m20-05-18 08:33:36 CRITICAL (MainThread) [supervisor.bootstrap] Can’t find Docker socket!e[0m |
2020-05-18 08:33:36 | stdout | e[32m20-05-18 08:33:36 INFO (MainThread) [supervisor.bootstrap] Use the old homeassistant repository for machine extractione[0m |
2020-05-18 08:33:08 | stdout | [services.d] done. |
2020-05-18 08:33:08 | stdout | [services.d] starting services |
2020-05-18 08:33:08 | stdout | [cont-init.d] done. |
2020-05-18 08:33:08 | stdout | [cont-init.d] udev.sh: exited 0. |
2020-05-18 08:33:00 | stdout | [08:33:00] INFO: e[32mUpdate udev informationse[0m |
2020-05-18 08:32:57 | stdout | [cont-init.d] udev.sh: executing… |
2020-05-18 08:32:57 | stdout | [cont-init.d] executing container initialization scripts… |
2020-05-18 08:32:57 | stdout | [fix-attrs.d] done. |
2020-05-18 08:32:57 | stdout | [fix-attrs.d] applying ownership & permissions fixes… |
2020-05-18 08:32:57 | stdout | [s6-init] ensuring user provided files have correct perms…exited 0. |
2020-05-18 08:32:54 | stdout | [s6-init] making user provided files available at /var/run/s6/etc…exited 0. |
2020-05-18 08:32:22 | stdout | [s6-finish] sending all processes the KILL signal and exiting. |
2020-05-18 08:32:19 | stdout | [s6-finish] sending all processes the TERM signal. |
2020-05-18 08:32:19 | stdout | [s6-finish] waiting for services. |
2020-05-18 08:32:19 | stdout | [cont-finish.d] done. |
2020-05-18 08:32:19 | stdout | [cont-finish.d] executing container finish scripts… |
2020-05-18 08:32:18 | stdout | client_session: <aiohttp.client.ClientSession object at 0x7f0affaaf7d0>e[0m |
2020-05-18 08:32:18 | stdout | e[31m20-05-18 08:32:18 ERROR (MainThread) [asyncio] Unclosed client session |
2020-05-18 08:32:18 | stdout | client_session: <aiohttp.client.ClientSession object at 0x7f0affcfe4d0>e[0m |
2020-05-18 08:32:18 | stdout | docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:32:18 | stdout | ‘Error while fetching server API version: {0}’.format(e) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 215, in _retrieve_server_version |
2020-05-18 08:32:18 | stdout | self._version = self._retrieve_server_version() |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 190, in init |
2020-05-18 08:32:18 | stdout | self.api = APIClient(*args, **kwargs) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/client.py”, line 40, in init |
2020-05-18 08:32:18 | stdout | base_url=“unix:/{}”.format(str(SOCKET_DOCKER)), version=“auto”, timeout=900 |
2020-05-18 08:32:18 | stdout | File “/usr/src/supervisor/supervisor/docker/init.py”, line 34, in init |
2020-05-18 08:32:18 | stdout | self._docker: DockerAPI = DockerAPI() |
2020-05-18 08:32:18 | stdout | File “/usr/src/supervisor/supervisor/coresys.py”, line 56, in init |
2020-05-18 08:32:18 | stdout | coresys = CoreSys() |
2020-05-18 08:32:18 | stdout | File “/usr/src/supervisor/supervisor/bootstrap.py”, line 50, in initialize_coresys |
2020-05-18 08:32:18 | stdout | File “uvloop/loop.pyx”, line 1456, in uvloop.loop.Loop.run_until_complete |
2020-05-18 08:32:18 | stdout | coresys = loop.run_until_complete(bootstrap.initialize_coresys()) |
2020-05-18 08:32:18 | stdout | File “/usr/src/supervisor/supervisor/main.py”, line 40, in |
2020-05-18 08:32:18 | stdout | exec(code, run_globals) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/runpy.py”, line 85, in _run_code |
2020-05-18 08:32:18 | stdout | “main”, mod_spec) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/runpy.py”, line 193, in _run_module_as_main |
2020-05-18 08:32:18 | stdout | Traceback (most recent call last): |
2020-05-18 08:32:18 | stdout | |
2020-05-18 08:32:18 | stdout | During handling of the above exception, another exception occurred: |
2020-05-18 08:32:18 | stdout | requests.exceptions.ConnectionError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:32:18 | stdout | raise ConnectionError(err, request=request) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 498, in send |
2020-05-18 08:32:18 | stdout | r = adapter.send(request, **kwargs) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 643, in send |
2020-05-18 08:32:18 | stdout | resp = self.send(prep, **send_kwargs) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 530, in request |
2020-05-18 08:32:18 | stdout | return self.request(‘GET’, url, **kwargs) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 543, in get |
2020-05-18 08:32:18 | stdout | return self.get(url, **self._set_request_timeout(kwargs)) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 230, in _get |
2020-05-18 08:32:18 | stdout | return f(self, *args, **kwargs) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/utils/decorators.py”, line 46, in inner |
2020-05-18 08:32:18 | stdout | return self._result(self._get(url), json=True) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/daemon.py”, line 181, in version |
2020-05-18 08:32:18 | stdout | return self.version(api_version=False)[“ApiVersion”] |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 207, in _retrieve_server_version |
2020-05-18 08:32:18 | stdout | urllib3.exceptions.ProtocolError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:32:18 | stdout | sock.connect(self.unix_socket) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/transport/unixconn.py”, line 43, in connect |
2020-05-18 08:32:18 | stdout | self.connect() |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 966, in send |
2020-05-18 08:32:18 | stdout | self.send(msg) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1026, in _send_output |
2020-05-18 08:32:18 | stdout | self._send_output(message_body, encode_chunked=encode_chunked) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1247, in endheaders |
2020-05-18 08:32:18 | stdout | self.endheaders(body, encode_chunked=encode_chunked) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1298, in _send_request |
2020-05-18 08:32:18 | stdout | self._send_request(method, url, body, headers, encode_chunked) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1252, in request |
2020-05-18 08:32:18 | stdout | conn.request(method, url, **httplib_request_kw) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 392, in _make_request |
2020-05-18 08:32:18 | stdout | chunked=chunked, |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 677, in urlopen |
2020-05-18 08:32:18 | stdout | raise value.with_traceback(tb) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py”, line 734, in reraise |
2020-05-18 08:32:18 | stdout | raise six.reraise(type(error), error, _stacktrace) |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 403, in increment |
2020-05-18 08:32:18 | stdout | method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2] |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 725, in urlopen |
2020-05-18 08:32:18 | stdout | timeout=timeout |
2020-05-18 08:32:18 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send |
2020-05-18 08:32:18 | stdout | FileNotFoundError: [Errno 2] No such file or directory |
2020-05-18 08:32:17 | stdout | e[32m20-05-18 08:32:17 INFO (MainThread) [main] Initialize Supervisor setupe[0m |
2020-05-18 08:32:17 | stdout | e[31m20-05-18 08:32:17 CRITICAL (MainThread) [supervisor.bootstrap] Can’t find Docker socket!e[0m |
2020-05-18 08:32:17 | stdout | e[32m20-05-18 08:32:17 INFO (MainThread) [supervisor.bootstrap] Use the old homeassistant repository for machine extractione[0m |
2020-05-18 08:32:01 | stdout | [services.d] done. |
2020-05-18 08:32:01 | stdout | [services.d] starting services |
2020-05-18 08:32:01 | stdout | [cont-init.d] done. |
2020-05-18 08:32:01 | stdout | [cont-init.d] udev.sh: exited 0. |
2020-05-18 08:31:52 | stdout | [08:31:52] INFO: e[32mUpdate udev informationse[0m |
2020-05-18 08:31:50 | stdout | [cont-init.d] udev.sh: executing… |
2020-05-18 08:31:50 | stdout | [cont-init.d] executing container initialization scripts… |
2020-05-18 08:31:50 | stdout | [fix-attrs.d] done. |
2020-05-18 08:31:50 | stdout | [fix-attrs.d] applying ownership & permissions fixes… |
2020-05-18 08:31:50 | stdout | [s6-init] ensuring user provided files have correct perms…exited 0. |
2020-05-18 08:31:48 | stdout | [s6-init] making user provided files available at /var/run/s6/etc…exited 0. |
2020-05-18 08:31:13 | stdout | [s6-finish] sending all processes the KILL signal and exiting. |
2020-05-18 08:31:10 | stdout | [s6-finish] sending all processes the TERM signal. |
2020-05-18 08:31:10 | stdout | [s6-finish] waiting for services. |
2020-05-18 08:31:10 | stdout | [cont-finish.d] done. |
2020-05-18 08:31:10 | stdout | [cont-finish.d] executing container finish scripts… |
2020-05-18 08:31:08 | stdout | client_session: <aiohttp.client.ClientSession object at 0x7f64f37fe690>e[0m |
2020-05-18 08:31:08 | stdout | e[31m20-05-18 08:31:08 ERROR (MainThread) [asyncio] Unclosed client session |
2020-05-18 08:31:08 | stdout | client_session: <aiohttp.client.ClientSession object at 0x7f64f3a4db10>e[0m |
2020-05-18 08:31:08 | stdout | docker.errors.DockerException: Error while fetching server API version: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:31:08 | stdout | ‘Error while fetching server API version: {0}’.format(e) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 215, in _retrieve_server_version |
2020-05-18 08:31:08 | stdout | self._version = self._retrieve_server_version() |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 190, in init |
2020-05-18 08:31:08 | stdout | self.api = APIClient(*args, **kwargs) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/client.py”, line 40, in init |
2020-05-18 08:31:08 | stdout | base_url=“unix:/{}”.format(str(SOCKET_DOCKER)), version=“auto”, timeout=900 |
2020-05-18 08:31:08 | stdout | File “/usr/src/supervisor/supervisor/docker/init.py”, line 34, in init |
2020-05-18 08:31:08 | stdout | self._docker: DockerAPI = DockerAPI() |
2020-05-18 08:31:08 | stdout | File “/usr/src/supervisor/supervisor/coresys.py”, line 56, in init |
2020-05-18 08:31:08 | stdout | coresys = CoreSys() |
2020-05-18 08:31:08 | stdout | File “/usr/src/supervisor/supervisor/bootstrap.py”, line 50, in initialize_coresys |
2020-05-18 08:31:08 | stdout | File “uvloop/loop.pyx”, line 1456, in uvloop.loop.Loop.run_until_complete |
2020-05-18 08:31:08 | stdout | coresys = loop.run_until_complete(bootstrap.initialize_coresys()) |
2020-05-18 08:31:08 | stdout | File “/usr/src/supervisor/supervisor/main.py”, line 40, in |
2020-05-18 08:31:08 | stdout | exec(code, run_globals) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/runpy.py”, line 85, in _run_code |
2020-05-18 08:31:08 | stdout | “main”, mod_spec) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/runpy.py”, line 193, in _run_module_as_main |
2020-05-18 08:31:08 | stdout | Traceback (most recent call last): |
2020-05-18 08:31:08 | stdout | |
2020-05-18 08:31:08 | stdout | During handling of the above exception, another exception occurred: |
2020-05-18 08:31:08 | stdout | requests.exceptions.ConnectionError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:31:08 | stdout | raise ConnectionError(err, request=request) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 498, in send |
2020-05-18 08:31:08 | stdout | r = adapter.send(request, **kwargs) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 643, in send |
2020-05-18 08:31:08 | stdout | resp = self.send(prep, **send_kwargs) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 530, in request |
2020-05-18 08:31:08 | stdout | return self.request(‘GET’, url, **kwargs) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 543, in get |
2020-05-18 08:31:08 | stdout | return self.get(url, **self._set_request_timeout(kwargs)) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 230, in _get |
2020-05-18 08:31:08 | stdout | return f(self, *args, **kwargs) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/utils/decorators.py”, line 46, in inner |
2020-05-18 08:31:08 | stdout | return self._result(self._get(url), json=True) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/daemon.py”, line 181, in version |
2020-05-18 08:31:08 | stdout | return self.version(api_version=False)[“ApiVersion”] |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/api/client.py”, line 207, in _retrieve_server_version |
2020-05-18 08:31:08 | stdout | urllib3.exceptions.ProtocolError: (‘Connection aborted.’, FileNotFoundError(2, ‘No such file or directory’)) |
2020-05-18 08:31:08 | stdout | sock.connect(self.unix_socket) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/docker/transport/unixconn.py”, line 43, in connect |
2020-05-18 08:31:08 | stdout | self.connect() |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 966, in send |
2020-05-18 08:31:08 | stdout | self.send(msg) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1026, in _send_output |
2020-05-18 08:31:08 | stdout | self._send_output(message_body, encode_chunked=encode_chunked) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1247, in endheaders |
2020-05-18 08:31:08 | stdout | self.endheaders(body, encode_chunked=encode_chunked) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1298, in _send_request |
2020-05-18 08:31:08 | stdout | self._send_request(method, url, body, headers, encode_chunked) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/http/client.py”, line 1252, in request |
2020-05-18 08:31:08 | stdout | conn.request(method, url, **httplib_request_kw) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 392, in _make_request |
2020-05-18 08:31:08 | stdout | chunked=chunked, |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 677, in urlopen |
2020-05-18 08:31:08 | stdout | raise value.with_traceback(tb) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/packages/six.py”, line 734, in reraise |
2020-05-18 08:31:08 | stdout | raise six.reraise(type(error), error, _stacktrace) |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 403, in increment |
2020-05-18 08:31:08 | stdout | method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2] |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 725, in urlopen |
2020-05-18 08:31:08 | stdout | timeout=timeout |
2020-05-18 08:31:08 | stdout | File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send |
2020-05-18 08:31:08 | stdout | FileNotFoundError: [Errno 2] No such file or directory |
2020-05-18 08:31:07 | stdout | e[32m20-05-18 08:31:07 INFO (MainThread) [main] Initialize Supervisor setupe[0m |
2020-05-18 08:31:07 | stdout | e[31m20-05-18 08:31:07 CRITICAL (MainThread) [supervisor.bootstrap] Can’t find Docker socket!e[0m |
2020-05-18 08:31:07 | stdout | e[32m20-05-18 08:31:07 INFO (MainThread) [supervisor.bootstrap] Use the old homeassistant repository for machine extractione[0m |
2020-05-18 08:30:46 | stdout | [services.d] done. |
2020-05-18 08:30:46 | stdout | [services.d] starting services |
2020-05-18 08:30:46 | stdout | [cont-init.d] done. |
2020-05-18 08:30:46 | stdout | [cont-init.d] udev.sh: exited 0. |
2020-05-18 08:30:33 | stdout | [08:30:33] INFO: e[32mUpdate udev informationse[0m |
2020-05-18 08:30:31 | stdout | [cont-init.d] udev.sh: executing… |
2020-05-18 08:30:31 | stdout | [cont-init.d] executing container initialization scripts… |
2020-05-18 08:30:31 | stdout | [fix-attrs.d] done. |
2020-05-18 08:30:31 | stdout | [fix-attrs.d] applying ownership & permissions fixes… |
2020-05-18 08:30:31 | stdout | [s6-init] ensuring user provided files have correct perms…exited 0. |
2020-05-18 08:30:31 | stdout | [s6-init] making user provided files available at /var/run/s6/etc…exited 0. |
Thanks for posting this - first thing I have to say that I’m no developer.
But by locking at the logs, there looks like there is an error with API and sockets while trying to communicate with Docker.
Can you please check what version of Synology Docker are you running because I know that at one point there was an issue with this. Also, check if there is an update for Docker available.
I’m currently running on version 18.09.0-0513
If everything is OK, you need to see following containers running, after Supervisor restarts:
- hassio_audio
- hassio_cli
- hassio_dns
- hassio_multicast
Those containers are directly controlled by hassio_supervisor.
Plus of course homeassistant and any addon_* containers you have
Hi there, I am using the same Docker version as you.
the 4 dockers you mention are not running.
home assistant version is 109.6
when I start those manually, I get this message:
Start container hassio_audio failed: {“message”:"Bind mount failed: ‘/dev/snd’ does not exists
Do you have Audio Station installed?
I still think there is an issue with Docker sockets/API - but it’s above my knowledge on how to debug further.
You can try this one to fix audio
And this too:
Hi @Tina_De_Feyter. @ashscott and I had a similar issue with the supervisor restarting after about a minute and we found that we needed to uninstall and reinstall the docker package and then the hassio package. We both (hopefully) are running well since, our instructions are up above if you would like to try that as option.
Hi Ezekiel thanks for replying… I have done that several times already… and I keep getting the same message that supervisor is unable to open the page.
Did you try installing Audio Station? HASSIO will not work without this issue solved.
I’m running the container without any issues. Must say here that prior installing your package I setup the dedicated hassio
docker network via Docker GUI in DSM as per instructions in the community forum. It starts and I really forgot that it exists. I’m running DSM 6.2 on DS216+II
That’s a big relief
Hi there,
I have a huge smile on my face… I got my supervisor finally running… I do’t know how I did it exactly . All of a sudden it worked. the audiostation was already installed but stopped even after restarting it again the supervisor did not work. then you posted something on the google devices in the meantime and you made reference to firewall! This got me thinking… I added some extra ports and bam all of a sudden this thing worked on a duckdns + let’s encrypt, following your instructions on your youtube. So proud of myself, as I am not an IT-er. Thanks Frederike for this packageand thanks Bearded Thinker for your clear and conscise youtube videos and assistanc on this community platform. Have a great day and Stay Safe!
