@nickrout if you mean CM4 external antenna, I don’t think you can use it for zigbee
Y’know I think I was confused over the antenna.
The pics on crowd supply some some headers near the zigbee chip, maybe worth investigating.
Has anyone designed a wall mount option yet?
When will this thing be available? 2055?
@sygys I believe that is the best estimate so far
I see that there is an antenna plug next to the zigbee radio, I will try connecting an external one to this
No, I was looking at the picture of the board, when I checked my board it has no plug
But perhaps a place to solder one?
Yes could be an option, however I just fried my Sonoff panel when soldering on leads
Hi. I bought a 1 TB Samsung 980, I plugged in but now my Home Assistant Yellow wont boot it seems, I never see it on the network, so I took out the SSD expecting it to boot as normal, but no, still not appearing. So now I don’t know if I have a Yellow issue or not.
Now trying to work out how I can troubleshoot this, if anyone has any pointers?
ah, I have just had a look, and gave the heatsink a push and I suspect the CM might have come loose, really hoping, if it comes back I’ll try the SSD again!
and SSD now working as my data drive, so that was painless in the end once I sussed I hadn’t actually killed my Yellow!
To confirm, this is the drive I installed: Amazon.co.uk
do you know if this is working now?
I have never bought the Homatic module so no idea
https://wiki.fhem.de/wiki/Datei:Hm-uart_trx1.png; should fit ;).
I just tried : Identifying Homematic RF-Hardware: …HmRF: HM-MOD-RPI-PCB/[email protected], HmIP: n/a, OK
Updating Homematic RF-Hardware: HM-MOD-RPI-PCB: 1.2.1=>2.8.6, OK.
Has anyone got Yellow from this new batch?
Nope. 6 month late here
Nothing either but it seems that the order is being processed. Under my address there’s now a This order is being processed. To change the shipping address, please contact support as soon as possible. which I don’t remember seeing before.
I have zero experience with the following Z-Wave solution for the Home Assistant Yellow (or Raspberry Pi). But, it does seem like a pretty inexpensive way to add Z-Wave, and it is using the latest 800 series Z-Wave controller chip. Nice that it should fit inside the Yellow’s case.
Still waiting for my PoE Yellow to hopefully ship soon…
